are these worth buying
9 posts / 0 new
scruffy dog
Last seen: 4 years 5 months ago
i can get batteries from my work for nothing  9 Volt 6 LED Pocket Flashlight FLD-12667 my work services security door locks systems as well as anything else that will make them money
some of the Lock's have a battery backup and the batteries are changed on servicing there are boxes of these and other batteries that just get sent away to be disposed of but most still have lots of life left in them
Edited by: scruffy dog on 02/16/2011 - 14:18
Don
Don's picture
Last seen: 2 years 6 months ago
I'd reckon they are worth it - you can make your own but these look neater. They can run for a very long time even with near-dead cells.
Since you can get the batteries for free, I'd certainly give one a try. Wonder if they would work with batteries once my meters start complaining.
I definitely want to hear how you get on with one if you decide to buy one.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Hrvoje
Last seen: 11 hours 5 min ago
Interesting. I have some Nichia GS and a dozen of 5 mm warm white leds. One row of GS and one row of warm white... but only if the head is easy to open.
scruffy dog
ordered 2 from e-bay HK £2.99 each
now the long wait for the ultra slow postal services to do there work
fishinfool
fishinfool's picture
That's pretty cool how the 9v battery becomes the body of the flashlight.  The 9v battery thing would be a deterent for me but since you have access to a bunch of them batteries (for as long as you work for that companyTongue out)--I'd say go for it also.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
sb56637
sb56637's picture
Last seen: 3 hours 23 min ago
Good eye Barrie! I've been looking at that same item myself. Reminds me of the Paklite. I always used to want a Paklite, until I realized that in these parts 9V batteries are prohibitively expensive. But yes, if you can get them from your work or salvage them from a smoke detector, it's probably worth it.
scruffy dog
Hi to all
my 2 lights arrived a few days back i am very happy with them and will be doing some run-time tests over the next few days
so far i have tried them on a few batteries of 4-9v at 9v down to around 6v there is a noticeable difference in hi and low (Hi-6 leds low- 2 leds)
 below 6v there is not as big a difference to the eye between Hi and low the 2 leds burn brighter switch to Hi and you get 6 leds burning dimer with around the same light output
on the ceiling bounce test i guess around 15 lumen on low and 40-50 on Hi on a fresh eveready 9v zebra-light H31 and fenix L0D used for comparison i will let you know how i get on over the next few days
scruffy dog
Hi i have been using this light over the last few days 20 hours of use give or take 15 mins
i have been using one of these lithium batts  Product Details the cell is one of the salviged ones i got
starting voltage was 8.9v ( after 20 hours of use on full power 6 leds ) it is 8.3v with very little drop in light output
 i think these would make good emegincy light to store around the place
i will carry on using it untill the light output has dropped and report back with the readings
okwchin
okwchin's picture
little more expensive though.. but a decent backup.  Although Id still rather leave a normal torch with a normal 16430, LSD NiMH around.
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
