I’m guessing that when people say they can’t get it that sharp that they are not going long enough with the coarse stage?
I think if you keep going in the first stage until you get a burr along the edge and if you keep getting finer with the proceeding stages you’re bound to get a razor sharp edge.
What a riot, just last night we watched “The Butter Shave” (Kramer discovers shaving with butter)
I think Seinfeld was the best comedic show of all time.
BTW, for my light beard, I have always used Noxema Skin Cream to shave.
I was beginning to suspect that my problem has been patience, and this thread reinforces that. More strokes,folks, is what I’ve needed (the right kind, that is).
I would, but I have almost no hair on my forearms anyway.. I just see them on the knife. :D
@Hokum: There are tools for that. Little chocks of metal or wood work well, but its best to train a lot until you can do it by hand/with your fingers to keep the distance. I sharpened 8 cheap knives from almost numb to razor-sharp before I started with the expensive ones. I got faster from knife to knife and had to remove less and less material.
Oh, and sharpening knives is really satisfying. People always give me that weird look until they feel the knife and cut something.. or shave. :D
I would say if you have never been able to shave with the edge more than likely you need to work with the coarse stone some more.
If you have previously been able to shave and now can’t you can probably just strop it back into shape or at most go to the fine stone.
I know that’s how it worked for me. As far as keeping the same angle I just lock off my wrist and quickly use the same motion. Your body remembers this motion fairly easily.
I would say it’s like anything else. It seems hard until the first time you are able to do it. After that it’s easy.
Murry Carter is the guy I attribute my sharpening knowledge to. http://www.cartercutlery.com/ I bought a sharpmaker a couple years before and and couldn’t get knives ‘shaving sharp’ every time but, after watching Murry’s videos, I can do it easily with varying girts of wet/dry sandpaper. NightCrawl, it’s my opinion that the burr IS necessary even if it’s barely detectable. How else would you ensure that one side of the blade meets the other and that you’re creating a sharp edge?
I don’t know if it makes a difference. But I clear my stone and edge as much as possible. I just think grinding the knife edge against little pieces of itself will dull it.
It works via two hard elements (tungsten carbide?) at some angle (I think 30deg on real one) and it removes material until the edge conforms with the profile. Just slide knife through and insta-sharp.
Ah I see, Accusharp is the angled carbide ones. I already have a few of those imitation ones.
They do get the job done fast, but takes too much metal off. And the sharpness is limited to paper cutting sharp. Also, this seem to work better for thinner steel knives (kitchen) but not as good for thicker blades.
Anyhow, for quick sharpening of kitchen knives this works really well.
That’s my impression as well. They take too much metal off and it’s a coarse approach to the problem. It leaves the “micro” serrations too large and therefore they dull more quickly.
You could use a strop on them afterward I suppose but as mentioned they still take too much metal off.
I have a two stage Kitchen Chef sharpener that would be similar I suppose (except for the second stage) but I think it wears the knife blade out too quickly as well (and therefore don’t use it).
There’s nothing cheaper or much easier than an oil stone and a piece of leather.
The original accusharp tends to work better than the cheapos. The easy way is just pull it through, but I get even better results by slowly working both sides seperately (without letting the “edge” touch the bottom).
Decent carbide edges are if anything finer than stone. The “secret” is more in the technique than anything (like, don’t pull/push too hard for already moderately sharp edges). The accusharp commercial product just makes it harder to screw up.
There are also sharpeners with variable angle to minimize removal if you know the exact grind the original edge has.
Also, steel edges are never permanently sharp. For best results, hone before usage to align the serration because steel will always get out of perfect shape after any usage.
