I was just messing around with a clicky switch and ended up taking off the little rubber end cap. And now I can’t get it back in for the life off me! Anyone have any tricks for this?
Just the boot. I mean, I can get it back in, but in there’s a small part of the edge which is bunched up and that makes it very easy to accidentaly move it back out.
What light is this? On all of mine you simply drop it in, make sure it is properly seated, (sticks out the back) and then screw in the switch. The only one I know of that is different is the ultrafire 2100.
Then, I'm not quite sure. It looks like it shouldn't be to hard. Just shove it in there and screw down the switch with a pair of pliers. Sorry I can't be more helpful. :(
Sintro, take the tailcap off the light and in the switch you should see two little indents. Take some needle nose pliers and stick them in there. Then twist. The switch should come out and you will be able to place the boot back in. If you need pics just tell me.
