Woody
(Woody)
October 10, 2012, 4:56am
15
BanglaBob:
[quote=bose301
Or get a better version of it from a US dealer who posts on this site regularly for $18 more.[/quote]
I would if I could, but shipping costs from the USA is a killer! Something in the region of 50 bucks
Just had a quote myself - $98 shipped to UK.
dlbelcher
(dlbelcher)
October 10, 2012, 8:57pm
16
Where do I get this light for $108?
I want one…
Bwolcott
(Bwolcott)
October 10, 2012, 9:05pm
17
Sbflashlights with the coupon code
way too many similarities with thrunite tn31. check out the pix from:
ThruNite is on a roll lately, first the Flood King and now the Thrower King. They have made a name for themselves with the throwing ability of their Catapult series but the competition has stepped up their game so ThruNite has gone back to the drawing boards and released this monster with a massive 79mm (3.11in) head and super smooth and deep reflector to take on all challengers. Let's see what they have in store for us. [image]
[image]
ThruNite is on a roll lately, first the Flood King…
and
http://www.forolinternas.com/viewtopic.php?f=5&t=4509
i’m starting to believe that supbeam is the OEM for thrunite. of course both parties probably won’t admit it. and of course supbeam will have to tweak around a bit with the CNC program so that the two won’t look too similar. the internals seem to be fundamentally the same, just tweaked a bit…
is this a K40 or a TN31??? don’t be misled by the color LOL
what about the MCPCB and plastic centering disc?
BTW i just received my K40. quality is excellent, easily at par with fenix, 4sevens, et al. way way way above XXX-fire levels. i would even dare say it’s a bit better than 4sevens…
Woody
(Woody)
October 12, 2012, 5:43pm
21
I think I agree. Supbeam states their OEM capabilities here . I realise that just because someone on the internet says something doesn’t make it true, but there’s too much of a similarity for it to just be a rip-off. Anyway, I’ve taken the plunge and ordered a Supbeam. Just need a bit of black duct tape to block out the horrible name
here’s another supbeam product, the scorpion LOL
view of the tail. someone please tell me this isn’t a Scorpion LOL
i’m convinced now. supbeam is indeed the OEM for a lot of thrunite stuff :nerd_face:
aka the Thrunite T10
http://www.thrunite.com/en/ProductsView.aspx?id=121
Specifications:
1:Cree XP-G LED (R5) with lifespan of 50,000 hours
2:Four modes of output: firefly(0.09lumens 147hours) -> Low (30 lumens,
13hrs ) -> High (120 lumens, 1.5hrs) ->Strobe(120lumes,2.5hrs) without
memory (Tested with Ni-mh battery with actual capacity 2500mAh)
3:Stable current regulated circuit, stable brightness
4:Uses one 1.5V AA battery (ni-mh, alkaline ). 14500 batteries are not
recommeded, because they heat up quickly.
5:20-gram weight (excluding batteries)
6:Made of durable aircraft-grade aluminum
7:Premium Type III hard-anodized anti-abrasive finish
8:Waterproof to IPX-8 Standard
9:Toughened double ultra-clear glass lens
10:Reliable twist switch
11:Candle mode (Capable of standing up securely on a flat surface to serve
as a candle)
12Size: 79mm(length)x17.1mm(dia)
Mode switch:
At tighten station of head.Screw the head(loosen then tighten)to have the
output from firefly/low brightness/middle brightness/high brightness and
strobe
T10 Specifications:
- Cree XP-G LED (R5) with lifespan of 50,000 hours
- Three modes of output:High (115 lumens, 1.5hrs) -> Low (9 lumens, 39hrs ) -> firefly(0.09lumens 147hours) with
- Stable current regulated circuit, stable brightness
- Uses one 1.5V AA battery (ni-mh, alkaline ). 14500 batteries are not recommeded, because they heat up quickly.
- 17-gram weight (excluding batteries)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Waterproof to IPX-8 Standard
- Toughened double ultra-clear glass lens
- Reliable twist switch
- Candle mode (Capable of standing up securely on a flat surface to serve as a candle)
- Accessories: key ring.
even the product descriptions are almost identical :nerd_face:
Woody
(Woody)
October 12, 2012, 6:20pm
25
The Supbeam L10 isn’t a million miles away from the Thrunite T10 either. I think the firefly modes in many of their lights is a bit of a giveaway.
eddit>> woops, you are on the case!
Bwolcott
(Bwolcott)
October 13, 2012, 2:26am
27
I posted a couple size comparisons in this thread
. Test sample showed 80k lux @ 1m but that was at a lower drive current. We’re hoping for 90k in the retail model or maybe even more
[image]
The Supbeam / k3 illumination k40 look like a tn30 reflector and led with a tn31 body and head the only difference I noticed was the tail cap
Bwolcott
(Bwolcott)
October 13, 2012, 2:29am
28
AlexGT
(AlexGT)
October 13, 2012, 3:47am
29
is the reflector of the TN-31 and K40 the same size and depth?
MosesM
(MosesM)
October 13, 2012, 8:51am
30
Nope. The K40’s reflector measures approximately 69mm wide and 52mm deep, so while the diameter is almost the same, it’s not as deep as the TN31’s (64mm according to turboBB’s review).
how2
(how2)
October 13, 2012, 11:35am
31
Similar light ?
L3 Illumination K40
No same as. Specs are almost the same.
atbglenn
(atbglenn)
October 13, 2012, 3:24pm
32
I'm seriously considering the L3 Illumination K40 for $18 more. I like supporting US sellers whenever I can.
How long is blf10 discount code good for?
joa
(joa)
November 27, 2012, 2:55pm
33
Has anyone comapred the Supbeam with the L3 Illumination. How much does the extra 0.5A give in terms of throw for example? OR can it be stated just by looking at the reviews done so far….?
Glenn,
That is a must have light.
I probably would give it a 10.
