It should be possible to make something like that with just hand tools. Myself I'd want the hotspots to come together at around 30-50 metres. Must go looking for some suitable metal....
Nice way for joining them. My idea was to make 2 rubber triangles with u shaped cuts at each corner to fit the flashlights. Then velcro strapped together. Also a rear contraption resembling a cone shaped "cork" to aid the focusing of the heads. To power them i tought to use
I was trying to make it as small as possible, with the top light as close to the bottom two as they are to each other there would be no space for your hand to hold the top light.
Spacing for the handle is neat, but as long as the metal plates are sanded on the edges to prevent cutting of hand, and the gap is big enough. ALternatively, may be possible to just hold the whole thing if it was more compact.
Regardless, Its a cool concept, and creates more room for your protected cells!!
I'll have to give that another go, there are several local engineering firms but they seem a little backward. Last time I tried they stared at me like I was a visitor from the future.
Do you have these blueprints in vectors? CorelDraw, or similar? Or are them scaled already?
Thought of cutting these prints in a vinil plotter, glueing them to 3mm black PVC(have a lot of it laying around) and then just shaping it.
Don't have 3 equal L2, nor 3 dropins of the same LED, but it should be fun to have a R2, XPG, XML all blasting at once in a L2M, L2P and a L2X. (the latest has a shorter rear conector than the first 2)
If it all fails, the all-fixing-all-bonding-duck-tape, will always work.
