You could do like a friend of mine would do back when we were teenagers - wrap the blown fuse in aluminum foil. However, I would not suggest this!
-Garry
(This was a joke, do not do this!)
-Garry
Strange …
Some thing is up if the 10A fuse is blowing at 3A , so the MM reading is 3A when the fuse blows
1/ Dont have a second MM to check Amps [ Flashlight ]
This sounds very strange indeed, the only thing i could think of is that the fuse is rated at 1.0A and the printing looks like 10A, as i’ve had bulbs and fuses that are very hard to read. Also is the fuse actually blown? Maybe the action of changing the fuse can disturb a bad solder joint in the meter which makes connection for a while until the current flowing breaks the dodgy connection and makes things appear like the fuse has blown.
here are some pictures of the fuse in question
The link on these fast burn fuses are so skinny…
and as you can see it is a 10A fuse
ok i’ll shut up this is way over my head! Strange indeed.
So, is it acceptable to run non fast-burn fuses in this DMM?
Are the fast-burn fuses the root of my issue?
I think the fuses are for CAT rating safety incase one does something stupid or accidental. Two of my old DMM’s dont have a fuse at all on the 10A range. I’ve measured 15A in the past! The leads get warm but the meter handles the power no problem! I would try the slow blow fuse and see if it makes any difference. What i’m trying to say is, replacing the fuse might alter the safety rating slightly if you work with mains electricity, but for flashlight measuring nothing bad will happen at all.
Thank you for this information! To be honest, the only time I use the 10A setting os for flashlight related testing….
Maybe I will use Garry’s idea and wrap it in foil!
Something else is going on here… Fast or slow, 3A doesn’t blow a 10A fuse…
You must have a light that spikes to over 10A… That’s really the only possibility. 10A fuses simply do not blow with 3A of current… They just don’t…
any issues with that MRTdriver
I don't recommend my Ideal DMM. I was just saying it looks like we use the same fuse. When we were doing some electrical work I was getting some funny readings.
I'm currently looking for a DMM that will give reliable tail cap readings w/out spending retail $$ for a Fluke.
Makes sense. But even with this, could the batteries used during tail cap readings provide over 10A? I used some Protected Angelfire “3200mAh” (yeah right) and some salvaged Sanyo UR18650A cells from a laptop battery.
What could cause the light to spike to such a high current?
Sure, for a short spike, it's easy to do 10A. Add to that factor your fuse is also fast burning. Maybe the two comes together and causes this.
But what light were you measuring? Single/double/triple battery in series etc?
For very brief duration, absolutely. I would bet they can provide 50 or 100A for somewhere between a few microseconds and a few milliseconds - maybe more…
[/quote]
The only lights that I have measured are P60 hosts.
PilotPTK;
If you change to a slow blow fuse, or a higher rated fuse, the worst that I would assume could happen is you might fry the DMM. Certainly do NOT remove (and short) the fuse completely though!
My first suspicion is something to do with the driver.
I won’t bypass the fuse (I was kidding earlier).
I will however, try a slow-blow fuse once I can get my hands on some.
Maybe because of this, a fast-blowing fuse would be too quick to blow as it would be more sensitive to very brief spikes above 10A. I would think that a slow-blow fuse might not blow on these same occurances. (Correct me if I am wrong)
I don’t mean to fuel any flames but my Fluke 179 blew the 10 amp fuse a while ago and all I ever test with it is drop ins under 5 amps. It is almost ten years old and Fluke charged me $12 bucks for a new fuse which sucked but I assumed the fuse wore out after a while since I definitely didn’t spike it recently.
Fuses shouldn’t really ‘wear out’. Cars have fuses - would people tolerate their engine controller fuse ‘wearing out’ while they’re on the freeway?
Something spiked it. I promise.
