fatlokwok has a Ti Olight and says this is also Ti.
BTW, fatlokwok, do you have a DMM to test current draw?
Low 50 mA DC
High 415 mA or 0.415 A DC
1.2 V Ni-MH battery
Optimised for 10440
Or alkalines. Higher draw (>>1A) from a AAA kills them dead in a few min. I would like to know if anyone finds 10440’s to fit in these though (or if 10440’s work at all). Seems like the blue trustfires or whatever don’t.
My reported 415mA still falls comfortably in the measuring range of my analog multimeter but near the highest 500mA limit. I am lucky to have this Medium value measured or otherwise would damage the meter. While I could recall a BLF member shared a High 500mA for a Klarus NT20 among others with his new DMM, Kreisler’s doubt might reflects a depleted Ni-MH AAA (less than USD 40cents) adopted by me. Although an affordable DMM with 20A DC is common nowadays, I want one could measure up to 50A for 3 or 4x18650 scenario and, imagine it is technically feasible, clamp type for a direct trouble free measurement. I need so time to check it out. I spot small affordable clamp type DDMs but not even up to 250mA max.
I have one coming for review.
Let’s see if it’s worth!
The UF-T1 is now on cnqualitygoods for 19,50. They claim it is made of stainless steel:
First it was listed by manufacturer as Titanium, then DX said it’s Aluminium, now CNQG states Stainless Steel…
I’ve one coming from china, but will still take 3 or even 4 weeks to arrive, if everything goes well.
fatlokwok:Got one today in clear plastic gift box secured on foam recess and tied with red ribbon. No spare O’ring and operation or instruction is non-exist. Try to use the ribbon as lanyard? Put the empty cell holder body to reach for strong magnet, absolutely immunity. Found the tissue free of aluminum/metallic dirts after rubbing the lubricated thread; a vague touch of friction typical to titanium felt. Overall polishing work is O.K. but with extreme fine hairline traces, tail portion with very small lanyard hole is surprisingly good up to perfect mirror finish grade. Normal dry AAA cell works fine with small diameter positive pole. LiIon cell on hand has large top and the rim strikes on the raised up electronic components on the driver board and therefore impossible to make contact. Unless one could find LiIon cell of proper pole size or with proper modification, do not push hard. No spring found on head and tail ends inside except a sponge ring perhaps for protecting the driver board.
Fatlokwok, can you post a link to the one you purchased? Was it the $38 version from the official site? the $20 version from the official site? or the KD version for $20.44?
Fatlokwok, you never said where you got yours from. This light still interests me if only for it’s diminutive size but especially if it’s really titanium.
A street deal (in the great Apliu street Ultrafire outlet) is USD22.00. List is USD24.00.
fatlokwok:A street deal (in the great Apliu street Ultrafire outlet) is USD22.00. List is USD24.00.
I wasn’t sure if he was saying he bought it there or that it can be had for $22 street price locally.
You’re right JohnnyMac, after re-reading the post I’m not sure neither…
That is, I gave the sales lady HK$200 cash and she was pleased to give me back HK$30 despite the normal price HK$188.
ApLiu street at Shamshuipo of Kowloon, Hong Kong.
For your informatio:
Hey guys. Kinda promised more pics, so here they are: Welcome to Ap Liu street, a mecca for lights, LED's, new and used anything, and tourist junk! [image] Starting with the main street stall for ultrafire's: [image] [image] [image]
Received my UF-T1 yesterday. My first impressions: A fine torch. Nice smooth threads. Imho it is not titan, but I’m not a professional.
From left to right: DQG III Ti, III SS, UF-T1
What's it like compared to DQA III Ti, III SS?
What the light output like?
Can it take 10440 batteries?
It looks slightly bigger than the other two.
Does DQA III Ti has a clicky?
It’s a magnet
I have a UF-T1 on the way from DX to be reviewed. Looking forward to this one. Might just end up on my neck lanyard instead of my Ti.
Yes, it’s greater than the DQA III. Notably longer…
Specs from UF-Shop: 5.9cm(L) x 1.3cm(Diameter)
DQA Ti: 57.5mmx12.6mmx12mm
Hello Infinite,
Could you be more specific when you say greater (disregarding dimensions or weight) ?
