That was where i bought it - its $67 plus shipping which was around $19 to NY.
You can see that in the review dialog box.
This looks kinda cool I admit.
Thanks for the beamshots & reviews. It’s huge difference between skyray & m8. Skyray stings my eyes.
Updated with temp info and battery tests. When the light cools down im going to try getting to that pill.
That's one hot light. You could nearly use it to boil water.
Good job man! Hope you keep the reviews comin’
Thanks very much for the review! Frontpage’d and Sticky’d.
whats next light gonna be ? 12x XML ?
Great review. Now I’m going to have to purchase it since it should easily outshine my Trustfire TR-J12.
very nice review, and ive been waiting for a review like this for the past 3 months.
ive been highly considering purchasing one but always past it up.
hay does this have more flood than the king?
Tonight when I get home from work I will post the reflector and other measurements since I just got a caliper.
And I will do a beam shot vs. The king for you.
Mine is NW though.
Just placed my order with Ric for one of these. Also ordered 3 X TrustFire Protected TF 26650 3.7V 5000mAh Li-ions from Manafont to go with it. The Trustfire batteries work so great in my J12, I see no reason they won’t perform just as well in this light.
only scared they are fakes and are not 5000mah as advertised. its about same price as king kongs raised cap 4000mah why not get them instead. ?
Manafont has been the place to purchase them from in the past. My original set of 3 were real and performed fantastic in my Trustfire TR-J12. The Trustfire 26650’s were never actually 5000mAh, but always tested from forum reports at 40000-43000mAh consistant. They are also protected cells, but I will look into the King Kong’s for my next purchase since they are getting good reviews. Thanks.
For Reference, below are the tests for the Trustfire 26650 cells as reported from members, Benckie and HKJ
Review Protected Trustfire 26650 5000 mAh Battery Test from Manafont Ordered: 26/3/12 Dispatched: 27/3/12 Received: 17/4/12 [image] Lenght 68.73mm from button top + to base - Width 26.11mm Will work in multi cell lights with out adding magnets Charged at 1.5 amps to 4.2 volt then discharged to 2.75 volt at 3 amps Data table: [image] A quick discription of the above data table Zenit [s] is time of the charge, it is updated every 2 seconds. Input [V] is how much volts my power supply i…
TrustFire TF26650 5000mAh (Flame) I have tested this battery from two different sources. [image] Official specifications: Brand: TrustFire Model: 26650 Voltage: 3.7V Capacity: 5000mAh (actual 4000mAh) Rechargeable Li-ion battery Built-in protection circuit Great batteries for your flashlight or other devices Dimensions: 2.68 in x 1.02 in x 1.02 in (6.8 cm x 2.6 cm x 2.6 cm) Weight: 6.38 oz (181 g) [image] Notice the difference in weight between the two tested batteries. The cha…
That reflector is outrageous
its actually not that much bigger then mag 2D which is decent size.
any beam shots comparison to the skyray king pease
Also interested in seeing this too since I own the king and been looking at the 9x for the while now, wondering if I should pull the trigger on it
First thing tomorrow morning I will post it.
Sorry guys!!
Updated with SKYRAY KING Beamshot comparison and caliper measurements.
Let me know of any other requests, & thanks for the kind words everyone!
