Review: BTU Shocker (3 x XM-L T6 NW | 3 x 18650)
254 posts / 0 new
_the_
_the_'s picture
Last seen: 45 min 59 sec ago
BTU Shocker (3 x XM-L | 3 x 18650)
Reviewer's Overall Rating: ★★★
Summary:
Battery: 3 x 18650
Switch: Tail switch, Reverse clicky
Modes: 4: Low, Med, High, Turbo
LED Type: 3 x XM-L T6 3C (NW)
Lens: Glass
Tailstands: Yes
Price Payed: Introductory price $150 (retail price $180)
Date Ordered: November 2012
Pros:
  • Bright (CW U2 would be even brighter)
  • Insane throw (about 80kcd as NW)
  • Ability to choose DRY driver for even more output
  • Very solid build
  • Available as NW
  • Good runtime with three cells
  • Current regulated -> No PWM on any mode
  • Well spaced modes
  • No blinky modes
  • Tailstands well (and can be used to illuminate the whole room Cool)
  • Good thermal characteristics - temperature raised only to 53°C during a 1h25min run indoors (ambient temp 23°C)
  • Great design & build quality, also in battery carrier
  • Lanyard is long enough to be used as a handle
  • "Lanyard handle" is not cold in low temperatures (it was -18°C yesterday when I was testing this - yes, it's about 0°F)
  • Flat bezel
  • Comes in a nice box, lanyard included, very good for gifting!
Cons:
  • Not exactly lightweight at 1200g
  • No option for lock-out
Features / Value: ★★★★
The light comes in a plain black box which contains the light itself and good long lanyard (and optional & extra DRY driver)
Features are good: Four well spaced, current regulated modes. No blinky modes, that would just annoy the user.
UI is pretty normal: Reverse clicky tail switch, with working memory. The light always starts on the last mode used.
Turbo mode has an automatic step-down feature: If the turbo mode is used over 3 minutes, the light steps down to High mode to prevent overheating. If you still want to continue with turbo, you can go back to turbo with a single half-click.
Value for money: Good!
Design / Build Quality: ★★★
Design is very nice. You can think of TK70, but much shorter. Short, thick, good handle, and large head for maximal throw.
Color of anodizing is good in my eyes and to top of it, bezel is flat. Just I like'em!
The anodization is very good overall, and glass lens looks & feels nice and durable. It doesn't seem to be AR-coated though.
Let's see some details..
Cooling fins, serial number, and just about perfect knurling in the body:
Tailcap switch, or actually only the rubber boot covering the real switch, which is integral part of the battery carrier. Tailcap has also two holes for attaching the lanyard.
Here we can see the switch, which is indeed attached to the very well built battery carrier.
Four basic parts of the light: Head, body, battery carrier, and tailcap.
All threads are square cut and anodized. Here's threads of the head, note how long those are. Very good for durability!
There is also dual O-rings to make sure that the light is water proof.
Tailcap threads are not only sqare and anodized, but also well lubed. Good job at BTU factory! Dual O-rings also here.
The battery carrier is very well built and feels secure for heavy use. Even larger cells, like XTAR 18700s, fit well.The tail end has the switch:
..and the other end as two springs, delivering the current to the head / driver:
All of the springs feel suitable for the job of delivering high amperage. The springs inside the carrier are reversed, which feels like a good solution. They are also soldered very well.
Positive terminals are covered with copper plates:
Heres the business end. Looks great! Emitters are well centered and reflectors spotless.
Thick plate holding the driver can be screwed out pretty easily, allowing access to a screw holding the reflector tightly in place:
Closeup on the driver. Says "LD-34"
Here's the reflector. It's made of aluminum and pretty heavy.
Under the reflector we can see three emitters glued to hefty heat sink and wired in series with beefy leads. Plastic centering rings make sure that the emitters stay perfectly centered also in the future.
Here's the whole light disassembled in a group shot:
The included lanyard is long, thick, and robust enough to be used as a handle. This made it easier to carry the light, especially in cold conditions when metallic body can make your hands cold in a short time.
Some measurements:
Length: 204mm
Head diameter: 106mm
Body diameter: 50mm
Body wall thickness: 4.5mm
Tail diameter: 54mm
Lens diameter: 94mm
Lens thickness: 3mm
Reflector diameter: 42mm
Reflector depth: 47mm
Weight: 1203g with 3 cells (= ready to use), 1062g without
..and here's some pictures confirming the measurements:
Compared to other lights:
Three three emitter lights from the front:
And the bottom line in the quality: Nothing to complain! Very solid and well built light.
Battery Life: ★★★★
Good! Three batteries and good mode arrangement with low enough low will allow very long runtimes.
I measured the tailcap current and got results of 3.6A on Turbo, 1.8A on High, 0.6A on Med and 0.05A on low.
This would give almost 1.5h runtime on High, 4.5h on Med, and over 52h on low!
Light Output: ★★★
Let's make this clear: This light is "only" about as bright as the NW King, if we compare only lumens that is.
But when we take the throw into account, this light wins, hands down. Even as NW, this BTU pushes out very respectable amount of candelas: 80kcd (after 30s, measured at 4m and calculated back to 1m), which is four times as much as my NW King does!
Thermal sag & runtime graph: (with XTAR 18700 2600mAh cells)
The first three minutes are on turbo, rest of the graph on high. This runtime test was done indoors, with ambient temperature of 23°C, without any additional cooling. This light seems to be well regulated and handles the heat very well.
This light has a low voltage warning (blinking the light with low level), which kicked in at about 1:22. Battery voltage after a slight rest was 3.2V.
I estimate (ceiling bounce + "known" references) the light output to:
- way over 2000 lumens OTF on turbo
Please take these values with a grain of salt. I have been underestimating OTF lumens in my last tests (like 650lm for 3.0A driven A8). It's time to get an IS, for sure. Embarassed
White wall beamshots (1/400s, f/4, ISO80, WB: Daylight)
Beam angle:
Compared to King
High with low exposure to show differences in throw: (1/2500s, f/4, ISO80, WB: Daylight)
Left: King NW, Right: BTU NW
High with even more reduced exposure (1/2500s, f/8, ISO80, WB: Daylight)
Outdoor beamshots (1/2s, f/4, ISO200, WB 5000K)
Control:
BTU Shocker Turbo:
Compared to Skyray King NW High (mouse over for BTU Shocker Turbo)
Compared to Thrunite TN31 Turbo (mouse over for BTU Shocker Turbo)
Summary: ★★★★
I have always wanted to have Fenix TK70, but it's too long for my taste and uses D-cells, which I don't like. This light provides the same insane throw levels in a much shorter form and with lighter 18650 batteries.
This is a very throwy multi-emitter flashlight with solid build for anyone who needs a durable work horse, which put out generous amount of neutral white lumens.
Verdict: Highly recommended!
The End (pun intended):
Thanks for reading & watching. Hope you enjoyed the review!
=the=
Edited by: sb56637 on 08/26/2014 - 17:19
dthrckt
dthrckt's picture
Last seen: 2 weeks 5 days ago
I just want to say, before even reading the review, that I’ve been refreshing “recent posts” since I saw you received this light (well…i slept for a few hours), thanks! Beer
____________________
Girls can shoot!
jmpaul320
jmpaul320's picture
Last seen: 3 weeks 3 days ago
I can’t wait for mine. Epic
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
UPz
UPz's picture
Last seen: 1 week 3 days ago
Thanks for the awesome (as always) review =the= Beer
MattSPL
Great review, and the BTU looks great Smile
vēer
vēer's picture
This is monster, this is not a light :D!
Now, how about some outdoor beamshots?!
Thanks, the, for review!
dthrckt
dthrckt's picture
great review.
very nice light. only thing I’d do different is make the emitters mechanically fastened, rather than with adhesive…
as much as I like the side switch on the tk75, if I were in choosing one or the other, I’d go with the BTU, because it is more user serviceable…
Girls can shoot!
JohnnyMac
JohnnyMac's picture
Nice review on a sweet light! Wink
Your lux readings are way off from others I've seen (as high as 130+k).  Is it because yours isn't running the DRY driver?  Just being NW compared to CW shouldn't make a difference of almost 50k.
_the_
_the_'s picture
Well.. My reading for stock TN31 CW is about 95kcd.
But there are couple of reasons for this low reading:
- I measured with the original driver (DRY driver would read higher for sure)
- This light is NW
- I measured at 4m, which is too little for this kind of throwers
- my meter might read a bit low(?)
=the=
kahvitahra
kahvitahra's picture
Last seen: 2 days 19 hours ago
Thanks! Looks like one well made light. That head is HUGE.
VFMaddict
Last seen: 11 months 2 weeks ago
Product link in OP is wrong. Otherwise a teriffic review. Thanks. Smile
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
makapuu
Last seen: 1 day 1 hour ago
Much thanks for the review.
I was really surprised at the size, it’s the same height as the Thrunite TN31.
Seeing how short it is, and looking at the weight, it must be built like a tank.
I agree with JohnnyMac, I think you numbers are conservative.
how2
Last seen: 4 years 10 months ago
That pill does no have many threads reminds me of the TK35 clone.
dthrckt
dthrckt's picture
its not a pill, afaik – just a driver holder. emitters are mounted on integral part of head.
Girls can shoot!
Pulsar13
Pulsar13's picture
Great review -the-. Sorry I don't follow the general enthusiasm for this $150 light, 80kcd isn't impressive for the price, and the output is just at King's level. Given the hype that this was called "super thrower"... hmmmph... not quite there. Maybe beamshots will tell a different story, but right now I'm not too impressed.
dthrckt
dthrckt's picture
my guess is that we see <$100 by summer
Girls can shoot!
_the_
_the_'s picture
VFMaddict wrote:
Product link in OP is wrong. Otherwise a teriffic review. Thanks. :)
Thanks for informing me. Fixed. Smile
=the=
ObiWan-Kenobi
ObiWan-Kenobi's picture
Wow – great review as always, the
Thanks
Would be interesting to see the difference a CW makes.
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 8 hours ago
Well, it looks like the Shocker is a win in my book. Thanks for ‘the’ review, the! While 80kCd is less than I expected, that’s still up there with the good throwers in the price range, and evidently build quality is right up there as well. A 9.4cm UCL or AR window would net even more output. Not to hassle you or anything, but I’m guessing you tested out measuring lux at further distances like 10m?
-Slim
Tecmo
Tecmo's picture
Last seen: 4 months 1 week ago
If you aren’t impressed, tell me the other 18650 multi-xml that throws even half this well for the price. Xtar S1 at 65k and $200?
d337944
Last seen: 1 year 2 days ago
Wow – Great output and great throw … fantastic combination, and the price is amazing for what you get.
Sounds like this will easily trump the Elektrolumens ST90 (SST-90 direct driven) which I just received, as that one is only giving me approx 2000 lumen with a floody throw easily beat by my Sunwayman T40CS U2!
Will hold off until the price drops though …
Bwolcott
Bwolcott's picture
The tk75 should be close when it comes out
Youtube channel asilaydying1984
DARCANGEL
DARCANGEL's picture
Nice review_the_thanks for doing this.I was wondering if you plan to use the dry diver at some point,as I understand it is more powerful than the digital regulated driver.The BTU is pretty beefy and hard not to want,except for the price.I am anxious to see outdoor shots maybe BTU vs TN31?
rikr
rikr's picture
Thank you for the great review… Beer
 New Collection / Old Collection
tkmckay
Last seen: 6 days 15 hours ago
Great review the, I don’t know if I’m going to sleep tonight after reading it now that customs has finally released mine back to DHL about 3 hours ago. Hopefully tomorrow when i’m off work I will have a nice parcel waiting for me when I get home! I just hope all my camera gear hasn’t sold by then so I can use one of them to take some pictures tomorrow. Silly
ChiggerPepi
ChiggerPepi's picture
Last seen: 3 weeks 1 day ago
Very nice review, and light. Thanks!
blueb8llz
Last seen: 4 hours 11 min ago
thanks for the much awaiting review on this light! when you get the chance, could you post some beamshots up against the tn31 and king please.
jacktheclipper
jacktheclipper's picture
Last seen: 18 hours 26 min ago
Looks awesome .
CouldUseALight
Last seen: 6 years 7 months ago
TK70 vs BTU vs TK75
I want all these together in a ring, and somebody to get killed with a Trident. :bigsmile:
Thanks, been waiting this review!!
Bwolcott
Bwolcott's picture
CouldUseALight wrote:
TK70 vs BTU vs TK75
+1
DarkSide
DarkSide's picture
Last seen: 2 years 3 weeks ago
Thanks for the great review !
