If you have a three-phase supply , you can treble the apparent flicker frequency by using different phases … You do need three times as many light units though.
Very interesting discussion here. I use exclusively CFLs due to the high cost of electricity where I live. I’m very interested in LED lighting, but from what I can tell, none of the LED bulbs can give me the brightness that I need. I like a very bright room in most circumstances, and so I use 26W CFLs that are approximately equivalent to a 100W inca, if not a bit more. Light output is somewhere over 1600 lumens for these bulbs. I don’t think there’s any LED bulb that can match that. Please give me links if I’m wrong.
That being said, CFLs aren’t ideal. Where I live, they cost around $3/ea, and they don’t last all that long. Most of the locally available CFLs have a putrid, vile, repulsive, sickening, hideous, repugnant, detestable, depressing stark white color. I don’t have enough adjectives to express how much I hate the tint of the CFLs that most people use here. The color is positively depressing. They are just recently starting to import warm light CFLs, but almost nobody here uses them yet. So I’ve been using warm color GE bulbs from the United States, which I really like. They last fairly long, but nothing like the 6 years they advertise. I’ve also had a few duds. The locally available CFLs also burn out quickly, and worse yet, are a fire hazard. In many cases I have been startled by the sound of popping and crackling from up above, followed by sparks and electrical smoke. Not very nice to think what could happen while nobody is at home with a CFL left turned on.
This thread is a good reference, and I think it should be in the LED Light Bulbs category. Anybody mind if I move it there?
It’s a little Suzuki sj, I value reliability and capability over some idea its best because its British. :bigsmile:
The japs have been fairly whuppin the landy bum for a long time with both. Plus, Landrover = British Leyland, I can’t think of a worse example of British manufacturing, I can’t think of one good car they ever made. I’m either Ford’s if its saloon cars or jap if its 4 x 4.
I think its safe to say we trust you moving threads
SB, if you’ve had your CFLs for awhile, you may find there are much warmer tinted versions available now (I hadn’t seen them before but bought some new bulbs since i just moved).
They work in pretty cold temperatures, and once they warm up (which they do at any ambient temp) they really pump out some good light. Great for garages/shops, etc. - especially for renters that don’t want to waste money/time on new fixtures.
A very nice 24W LED bulb. I have the Sylvania branded versions (both made by Lighting Science Group). They claim 1300 lumens, but I measure over 1400 lumens. They will beat the pants off any CFL bulb. I suspect that even a decent 18W LED bulb will provide more effective light than you CFL.
Plot of light output and CCT as it warms up. My CRI number is rather bogus. That little bobble in the light output at the end of the curve was me trying to put a thermometer on the bulb and moving it around:
I have 3 light fixtures that use candelabra base bulbs. I have yet to see a candelabra base CFL bulb that didn’t look ugly as sin in such a fixture. I’m gradually working on switching them all over to LED bulbs, buying a couple of bulbs when I run across something newer, better, brighter, cheaper.
I’ve been using CCFLs for years now, energy saving is good, but they are annoying in CRI, short lifetime and slow startup. I’ve bought a couple 40w and 60w LED bulbs, but I will be extremely glad when bright 75w and 100w equivalent LED edison base bulbs show up at reasonable prices. Longer life, better CRI and instant on make LEDs worth a premium over CCFL prices, but they still need to get down to the $10/bulb range for me to switch over completely.
It’s a little annoying that the power company here subsidizes CCFL bulbs, but not LED bulbs. The CCFL era can’t die soon enough for me.
I’m wondering why there’s all these people claiming CFL’s don’t last long. I’m thinking wrong use. One thing CFL bulbs don’t like is heat. It’s bad for their cheap electronics and that’s what’s causing them to break down, the electronics go bad. And because price point is the biggest consideration people are using for the purchase of their CFL’s obviously it’s a you get what you pay for purchase which compounds the problem, cheap electronics will fail earlier. As for me my room uses a single 45 watt CFL for light, yes it’s insanely bright but I like a bright room. I’ve replaced it one time and the previous one lasted 6 years. A 45 watt CFL isn’t a bargain basement offering either since that’s a more specialty CFL, they cost me 30 bucks like 10 years ago, now they’re down to $12 but that’s still more than the $3-4 of bargain CFL’s and the higher cost is evident in better overall construction and they never flicker and are instant on. The difference is the fixture it’s in keeps the base exposed to cooling air. Many people put these CFL’s in small glass enclosed domes or fixtures designed for incandescents. When you do that they get baked in their own heat and the electronics fail.
This is actually a good practice even for led’s. Keep the led fixture cool. Even though they may run a little cooler than CFL’s they’ll benefit from having more cooling. Because even though the led’s may last a long time, if kept at elevated temperatures everyone here knows led’s will dim quite severely from extended high temperature operation.
The OSRAM facility CLF bulbs seem to managed that problem pretty well, I know an apartment manager who switched from incandescents to this special CLF bulb, he even uses them in on-demand switches in staircases in large apartment buildings.... which would normally lead to certain death for standard CFLs within weeks. He has 200 of them running for over two years now and I think he replaced one of them. They are expensive in small quantities, but if you order them in large quantities they are doable. And yes he did the math upfront and yes they are profitable over their life expectancy vs. incandescents and LEDs ... at least with German Energy prices of 26-27 €-cent ( isn't that insane?) per kWh this year and the projected development in the future.
Last time I bought some in a sale they went for €6.99~$9 (18W~80W inca) and in larger quantaties they can be bought closer to €4-5. They have been my go-to recommendation ever since. If they would come up with a way to make them mercury-free... they would be pretty much perfect.
It appears that there is a wide variety in the quality of cfl’s sold and their ability to tolerate dirty AC current. Some here have had good forune with them, I have not. In my experience they turn on slowly(sometimes dangerously slowly), don’t last long even in a fully exposed ceiling fixture where excess heat is not an issue, and have poor color rendition. Even so, being green means to me that I’m not going to throw out working units until they fail and cfl’s don’t go in the trash.
Don’t buy 99 cent CFL’s go for quality ones if you don’t know how to spot specifically good CFL construction, often times I’ll take one of the light bulbs in a multipack I just bought apart to see if it’s built good. A good way to generally figure out how good something is I’ve found is to simply look it up on Amazon and sort it by average rating. If something can maintain a good 4-5 star rating with at least 50 reviews generally you’re gonna stand a good chance it’s not a piece of crap.
I’ve had nothing but good luck with the GE Energy SmartTM bulbs even in harsher enclosed fixtures. They definitely last me at least 4 years on average. Not as much as my specialty 45 watt monster CFL’s but considering the price they definitely pay for themselves in energy savings.
I understand that marketers spin specs to present their product in the best light (no pun intended) but bullet points like this really chap my hide for several of reasons.
1) Requiring up to 20 seconds to achieve 60% of its rated brightness strains the connotation of “quick light”. Especially for a society raised on incandescent light where full output was almost instantaneous.
2) How bright will it be after 1 second at 25C? How bright after 1 second at, say, –10C? That is, is the light suitable to be used in a porch fixture? If it takes even 5 seconds to achieve a reasonable brightness in the winter, then it’s not going to help you identify who or what is scratching at the window at 3am…
I’ve been switching to LED’s since CFL’s are generally less durable and don’t offer drastically higher light output. I know LED’s still have a long way to go but at the moment it’s more useful to have a few light fixtures that can take a good knock or two rather than the fragile glass that CFL’s and incandescent’s are often housed in.
I’ve seen some CFL’s fail dramatically but never in a way that would have caused some harm (One made a burning smell when it was on but no access heat or smoke was emitted, had the fire dept a bit confused since they couldn’t find it) and as of now no bad results from LED bulbs. Light output is generally not crucial since most fixtures generally have more than enough places for bulbs so a bunch of 650+ lumen LED’s generally work just fine.
Best thing is not having to change the bubs all the time and that they aren’t major health/safely issues when disposing. Heck I can probably salvage the HS’s and all that from them when they finally do bite the dust and possibly reuse them (Safety in mind when working with mains power).
I see CFL’s becoming less dominant and LED’s becoming more popular but it might take some time yet and who knows if there is going to be a new revelation in that time frame. My LED’s are abused more than my other bulbs and they handle it a lot better than them as well; If I go though 6 CFL’s a year vs 2 LED’s then I think that I’ve had my money’s worth, at least in convenience (Although I wish LED’s were still cheaper/brighter, who doesn’t?).
I had been replacing at least one halogen bulb a week. Since switching to LEDs, I haven’t replaced a single bulb in over two years. And frankly, the LED bulbs that are out there now are plenty bright. Every one that I have puts out more lumens than the halogens that they replaced.
I, for one, would LOVE to know more facts about that!!!
SWMBO and I made the Leap of Faith into CFLs a few years before they became useful as Light Sources. (I sense an echo here: wildly exaggerated claims, tint-color lottery, variable QC, no useful engineering info, etc. — all the same, just concerning CFLs (and tubular FLs “back in the day”) as I hear today over every new LED manufacturer to come along…) She won’t turn lights OFF, I usually have to be reminded to turn them ON. We put CFLs in her “always ON” sockets, and incans where we need occasional light, special light (120W for one), or where the huge pigtails don’t fit. But I digress…
We don’t have government subsidies around here to skew the cost bases & thereby confuse people, although the power co-op did give away dim brown CFLs (“60W-equivalent”) to anyone who wanted any. Our “best” home-LED bulbs run closer to $40USD than $4. And the “best” CFLs don’t even hit $4 if you don’t care what color or quantity of light they put out. That makes it RARE to find anyone actually USING the LEDs…
It’s surprising how many “ordinary” people DO care — a LOT — about the color and quantity (and quality, if any of you remember “flicker” of FL tubes) of light their bulbs emit.
(Full Disclosure: the color-reference-standard a lot of posters here seem to prefer is what I call “60W White” because it seems to my eyes to match the color emitted by a standard 60W incandescent bulb. These bulbs cost us poor folk Zero Dollars and Forty-Two Cents ($0.41667). Each. My preference is “100W White”, just so you’ll know. Top-shelf 3-Mode (dimmable!) ones of these cost a whole $1.24! Even with magick thinking, it takes a LONG time to balance that equation!!!)
I have a friend (believe it or not) who popped on a cheap LED for his workshop. He didn’t keep the package, and doesn’t care about details, so don’t ask. All I can say is, it was the cheapest one Lowe’s had last summer. As a near-to-hand “task light” or as a ‘courtesy light’ so visitors don’t crash into stuff, it’s fine, but here’s what I want you to try with one (1) of yours: Walk across the room and try to read the label on a laptop HDD, or the instructions for microwaving a meal… Now, (sorry, but someone had to say it) leave that one bulb as it sits and walk to the OTHER side of the room and repeat the test… IFF your LEDs make enough Light to do that job, I’m VERY interested, nevermind the cost. (I’ve seen your beamshots… You of all people know what I mean by “throw”.)
I’m just trying to defend the idea that QUALITY and QUANTITY of the ACTUAL LIGHT is at least as important to some of us as the Price Tag (yes, I mean Lifecycle Cost) of the bulb used.
And I do know that CFLs and LEDs are MONOchromatic, where the light I seem to need most is OMNIchromatic Meaning: why only 5000 (whatever)k? What about 5000k AND 3700k AND 14000k (and IR and a little bit of UV) all together like humans are used to seeing??? ALL wavelengths make the best “white” light… So the notion of “cost of light quality” over “price of green hype” will likely rub quite a few people the wrong way. I hope so… I have yet to meet anyone who will commit the effort to think thoroughly about something they feel comfortable believing. Full disclosure: as much as I love the LEDs for flashlights, I can’t see any way they could ever be made AS USEFUL, overall, as plain old point-source burning wires. When they make a small, spherical, BRIGHT (not “…for an LED”) multi-chromatic LED, I will be at the head of the line!!!
