But those are triple and quad. This is 7. Huge difference! I say if you can do it go for it.
In XM-L? Really? I looked around and can't seem to find any, if you can find one I'd be interested to see a link.
Over at CPF, there have been some conversations about reducing the forward voltage of LED’s by shocking them with high current pulses. I believe it was a SST-90 though.
Can’t wait to see how this project works out!
Also, my search for batteries is over.
A123 LiFePO4 cells will give you much longer times above 3.1V, but max voltage will be around 3.3V Plus the 26650 cells can do over 200 amps into a short… 70 amps won’t faze them.
7 is the max for flat positions if you make a 3d board there’s more space…
I wish I could get a board like that for my 4 ez900 LEDs
Why do you need all the current to go through the springs?
You could use copper braid inside them, as described in this thread:
Woaaahh. Did you say 7?
Is someone attempting to wind me up? Even the quad that was built was dead soon after it powered up.
3 is noteworthy. Keeping 4 alive and yourself is honorable.
You say 7? Even if you combined the modding capacity of Scaru & JohnnyMac you would get SMacRu....literally
When was there a quad built? I keep hearing of other multi XM-L P60 drop ins but have not seen any links or threads.
But yeah, 7 is insane. You wouldn't believe the number of people who have PMed me suggesting active cooling.
Scaru - You scare me.
One request please. Find someone with a video recorder and when you turn it on the first time, have then record it for posterity. It may be the only few seconds to ever see it.
Four most well known last words in the South - "Hey Y'all, Watch This!"
Will do OL, I'll attach a note to it. "In Case of Death, Upload to BLF" :D
There might be a problem with overexposure. Try looking up techniques for filming atomic blasts, shielded underwear, etc.
here lies scaru… tried to go where no flashaholic dared to go before
but there will be one hell of a video to follow :bigsmile:
edit: first time using gimp… go easy on my graphic editing skillz :weary:
My only question is why go the whole nine yards and use XM-L2?, sure they cost more but 5% less heat, U4 equivalent, probably very slightly lower forward voltage…
First of all they actually have a higher forward voltage which is a definite problem for me. But ignoring that, I'd much rather just use 7 U2 that I can get for 6.50 each.
First of all they actually have a higher forward voltage which is a definite problem for me. But ignoring that, I’d much rather just use 7 U2 that I can get for 6.50 each.
I was thing like 4 T6 3C and 3 U2 1B, would be cool
Any combo really, with so many LEDs, you can really customize your tint
to use the starter relais of a car for this one.
you might derail a freight train with that thing
Thatninjaguy, you can't mix different LEDs like that, or at least I don't think you can. As I understand it they may have different forward voltages and then that leads to some getting more power (since in parallel) and eventually killing them.
I don’t think forward voltage depends on tint. It’s pure lottery, if I’m not mistaken. I.e. you can have three LEDs of same tint with different forward voltages, or three LEDs of different tints with same forward voltage - depending on how lucky you are.
