I truthfully do not know, I can tell you when I have taken the phosphor off the LED in the past (while dedoming) it becomes a deep blue.
Based on that chart, I would say it was around 8000k. (general estimate)
Edit:
As ryan pointed out, their blue XM-L is 450-465 nm so it would be a royal blue.
However, for what ever reason it seems that the blue LED in their colored XM-L is much less efficient than a white one. So now I am doubting myself. :( The white die produces 100 lumens at 350 mah and the blue one produces 13.9 lumens at 350 mah.
nice run through scaru. Only niggle is that CW Cree LEDs are generally 65CRI, although the newer XM-L2 CW seem to be 70CRI. NW and warmer are 75CRI, one reason so many people like them over CW
That’s what I don’t understand. If it is more blue and brighter the less phosphor, why are blue xml dimmer? I don’t think there is any way to “redome” an led after stripping the phosphor is there?
"For example, the efficiency of a typical...yellow phosphor based white LED ranges from 3 to 5 times the efficiency of the original blue LED because of the greater luminous efficacy of yellow compared to blue light."
Basically, human eyes are much more sensitive to white (or yellow) light which is the cause of all this.
http://en.wikipedia.org/wiki/Luminosity_function
The blue light produced is at 450 nm while the white light (after going through the phosphor) is around 575-600. So if you look at the graph, the human eye is very sensitive to white light, but not the blue light.
Excellent resource. Now if you could do one on the meaning of “XM-L” vs “XP-G” etc. It would be neat to know more behind the naming and designation of each.
