Tint, Binning, and CRI Explained (For XM-L LEDs)
I do too, but its already in the one stop mod reference shop, so easy to find. :wink:
Excellent resource. Now if you could do one on the meaning of “XM-L” vs “XP-G” etc. It would be neat to know more behind the naming and designation of each.
What do you mean? The number of bond wires, size, efficiency, etc? Maybe if I get a chance I'll do that but this one was prompted by a few people PMing me in the past about tint, along with Nitro's question about where to get a neutral LED.
What surprises me is I was able to do 90% of this with out having to look anything up, I guess that's what happens when I spend so much time here.
I’m beginning to worry about how much I soak up on something I take an interest in, six months ago, I didn’t know what an xm-l was….know I’m growing bored of them…not bored as in not using them, just want to play with other things, I’m going backwards though, starting playing with xp-g’s etc. Bothering about modes and tint more than total output.
Sometimes a q5 in a suitable host with a good 1.4a driver is more usefull than an over driven xm-l lumen monster.
I’m a heretic, stone me :*
Ok, a comparison LED post is in the works.
I think I’m in the same boat as you. I have drawers full of lumens and sheer output isn’t a real big deal to me any more. I’m now more drawn to different tints and their visual relation with different beam profiles. If I see a flashlight with a choice of an XP-G 4C - 450Lm or an XM-L U2 - 800Lm, I will probably go with the XP-G 4C.
…And thanks so much Scaru. I hope you don’t mind that I copied and pasted your post right into my Evernote flashlight file.
Ouchyfoot, I don't mind in the least and am happy to be able to contribute back to the forum in this way. :)
I noticed you don’t have any links for 4C tints, which is my favorite right now, although I have yet to try a 5C.
The bad thing is, I should get a p60 host, build many pills, then its half scientific. That’s not going to happen though, I just don’t like p60’s so common sense is out the window…
WOW! Great info Scaru!!! THANKS!!! That is the best I have ever seen the information laid out!!!
Dan.
Not quite. CW XML typical CRI is 65. Typical CRI for CW XPE, XPG, XRE, Rebel, and most other current gen 3.45mm square emitters is between 70 and 75. Typical CRI for NW and WW emitters depends a lot on the specific model of emitter. For NW, it ranges from 70 to 80 depending on the type of emitter (not including "high CRI" emitters), and for WW, it ranges from 75-85 (also not including "high CRI" emitters).
Nice thread along with your other comparison thread.
Question - XM-L led's include a high CRI bin. I dont see this or anything about it..Sure, its for sale somewhere. I think its an S2 bin although i may be wrong in regards to the bin
Yes, to find that type of LED you need the model number. This is listed in the datasheet. Then simply take the model number and google it. (In this case:
XMLAWT-00-0000-000US60E7)
Then you come up with the Mouser link.
http://ca.mouser.com/ProductDetail/Cree-Inc/XMLAWT-00-0000-000US60E7/?qs=sGAEpiMZZMvmVP6pKcvh1c7ty4GjCwvt
I think I have responded to all of the questions/comments/errors in my post. If I missed any or you find any more just tell me.
Lots of info and nicely explained. I will probably have to come back to it later after I can wrap my head around all this a little bit better.
good point! I’ve spent most of my time poring over XM-L datasheets and I’m much less familiar with the other types :slight_smile:
Thank you scaru.
I am a newbie and have been reading this forum for a while trying to get myself educated. Your work on the XM-L LEDs has been most helpful for my to get a little better understanding of some of the technical aspects of these magic flashlights that I am so intrigued with.
I have purchased a few different lights and am now at the point where I want to build my first one. With this info I will be able to settle on at least one element of the new build.
Glad I could help! If you have any other questions just post! :)
I would not speak of the 5C1 or 5B3 as they were 1A or 1C, writing them like 5C and 5B. Starting with the number 5, CREE gets more "precise" with the tint that is offered. It's not like 1C which has a bigger quadrangle and it's not as precise as those.
CREE does not consider "2" tints to be Neutral White, they are still Cool White. Number "5" is considered Neutral White by CREE, not Warm White.
XM-L bins can go lower that T, like S6 is the lowest mentioned by CREE. Also I have not seen T1 anywhere mentioned by CREE so far. For example we have XP-G R5 then S2, XM-L S6 then T2, XM-L T6 then U2. Bot no S1, T1 and U1.
This may be true, but I see no reason the 5 bins have to be more precise than the 1A bins. If more people say I should change it then I will. :)
Good point, I will add that 2 is CW, however if you have ever seen a 5 it is quite warm... So do you guys think it should be based strictly off the spec sheet or reality?
Just checked on the sheet and you’re right. I’m changing that now. I don’t think the S bins need to be added because, well have you ever seen a S bin XM-L for sale? :stuck_out_tongue: The only place they are found is Mouser or Digikey, a place that also would have the same tint in a T bin.
