Its 7:50PM now and still light. It should be dark by about 8:30-9PM and Ill go for a drive and take some beamshots.
Also some of the threads and plastic ring that I was talking about and if anything else comes to mind.
Hmm, I had “XM-L T6 (unconfirmed)” written but it does indicate its a warm U2 on the bottom of the box as well.
Maybe Ill ask Nitecore, I didn’t think they were made either because I have never seen them offered before.
Great! Now waiting for some more pics!
Def not a T6 I have quite a few T6 3c and compared to them this emitter is slightly rose coloured.
Hank Wang says its a T6 3C. All the boxes say U2 on them. I think you’ll see a sticker covering that on newer batches.
It will have to be a sticker covering a sticker then :bigsmile:
Very nice review and very nice light. I want this light, but I can not afford it…
1 beamshot up, working on the other one now and should be posted in 30 mins or less.
2nd beamshot added.
How many lumens ultra-low has?
I think it wasnt advertised at first that this light has ultra low, no?
Thanks for the pictures ezarc. Is there that much difference between the two different lights in actuallity? You must have a very understanding sister in law.
The “ultra low” is 65 lumens, its what Nitecore call it in the manual.
And yeah there is quit a big difference in light output, the PA40 puts out enough light to see pretty much anything in viewing distance.
I prefer PA40 but I’ll try to make myself use the EA4 more and maybe Ill warm up to it a little more.
It feels like the EA4 is made for baby hands (my hand takes up just about the whole handle of the PA40) and thats probably the biggest reason I prefer the PA40 over it, but it does pack a lot of punch for its size.
I hope there isnt another clone to be born lol
Great, thx for the comparing beamshots, very illuminating! :) def. pun intended! ;)
My EA4 CW is on its way from HKequipment…
Star mode is like nite mode. I can’t tell the shutter speed on those because there is no info.
But nice review.
Can it run on on four NiZn cells, or on two LiFePo4 with 2 dummy cells, or a single 14500 with 3 dummy cells?
It sure it will run on 4 NiZn cells fine.
Whit the other batteries you are asking about I don’t think it it would but I could be wrong, its not something I would consider trying.
If it runs on 4xAA it will work just fine on 2xLiFePO4 cells.
Couldn't two LiFePo4 cells be to much? I.e. with a 7135 driver it will run fine off 4 AAs, but two LiFePo4s would kill it. (Since they're 3.4 fully charged)
my lifepo4s come off the charger higher than 3.4v. usually its right in the 3.57-3.59v range. i wouldnt risk it personally.
