Excellent review! Can’t wait to see the outdoor beamshots! Are the led bases 14 or 16mm? What is your take on the tint?
Off topic, What do you use to sharpen your khukuri’s, besides your finger? :bigsmile:
I have used the sanding paper over a mouse pad method on my 21” Chitlangi but It has not produced a very sharp blade, I was using 2000 grit automotive sandpaper maybe I should use coarser sandpaper, what do you recommend?
I contacted BS before about this U3 and was told it won’t be anytime soon as they can’t get hold on enough U3.
U3 is definitely more attractive, but I am afraid BS might raise price for U3.
Right now you cannot order the U3 specifically. Originally their plan was to release it this month but supply issues, if Dengoh is correct, will delay things. From what I understand, the U3 will have stainless bolts holding the handle to the body while U2 and Neutral versions have black steel bolts.
Dengoh, can you double check that link? I keep getting a page not found error. I cant imagine any way that could look good with the handle cut down. Is it just a stump cut off after the switch?
Nevermind. Triedit again and this time the link worked. Cant view images without an account. Can you just post the pics?I
