sorry, i just had the nitecore and a couple of batteries in my cartâŠ.but it seems to work on more stuff as well, bought some 3400mah unprotected 18650âs for 8.5$
I just double checked with an EA4 in the cart and it just applied discount to the EA4 when I added a second item. If you then try to do BLF on the second item it cancels out the PRICECONTROL discount.
If you want an EA4 then order it just on its own. Other items canât get discount on the same order.
I just added the EA4 to my cart. I applied the code 'BLF', which gave me 5% off everything. I, then entered the code 'PRICECONTROL'. It kept the 5% off everything, in addition, it reduced the price of the EA4 $7.70 (±14%).
Fasttech said it would go away eventually. I gues CNY was the cutoff. I used it on an order that code âBLFâ didnât hit many of the items.
I think if we tell them that an item is flashlight related, they will add BLF/CPF/whatever codes on that SKU. I picked up some of those sub-1 Ohm resistors and they didnât get a BLF discount.
