Test / Review: Efest 18650 3400mAh (Black)
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 24 min 13 sec ago
Protected button top
DSC_1357
Official specifications:
  • Nominal Capacity: 3400mAh (0.2C, 2.50V discharge)
  • Minimum Capacity: 3250mAh(0.2C, 2.50V discharge)
  • Charging Voltage: 4.2 ±0.05 V
  • Nominal Voltage: 3.6V
  • Charging Method CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 170mA, Rapid charge : 3400mA
  • Charging Time: Standard charge : 3hours, Rapid charge : 2.5hours
  • Max. Charge Current: 3400mA(ambient temperature 25°)
  • Max. Discharge Current: 6800mA(ambient temperature 25°)
  • Discharge Cut-off Voltage: 2.50V
  • Cell Weight: 55g max
  • Cell Dimension: Height : 69.75mm max, Diameter : 18.57mm max
  • Operating Temperature: Charge : 0 to 45°, Discharge: -20 to 60°
Efest%2018650%203400mAh%20bt%20(Black)-info
DSC_1340
DSC_1358DSC_1359
DSC_1360
DSC_1361
DSC_1362
Efest%2018650%203400mAh%20bt%20(Black)-Capacity
The protection does prevent a full 5A discharge curve on one of the batteries. The difference in protection between the batteries is also the reason for the curves not overlapping at the higher currents.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Efest%2018650%203400mAh%20bt%20(Black)-CapacityTimeHours
Efest%2018650%203400mAh%20bt%20(Black)-Energy
Efest%2018650%203400mAh%20bt%20(Black)-PowerLoadTime
Efest%2018650%203400mAh%20bt%20(Black)-TripCurrent
Efest%2018650%203400mAh%20bt%20(Black)-Charge
Unprotected flat top
DSC_1351
  • none found
Efest%2018650%203400mAh%20ft%20(Black)-info
DSC_1340
DSC_1352DSC_1353
DSC_1354
DSC_1355
DSC_1356
Efest%2018650%203400mAh%20ft%20(Black)-Capacity
The unprotected version has exactly the same very good performance as other batteries with the same cell.
Efest%2018650%203400mAh%20ft%20(Black)-CapacityTimeHours
Efest%2018650%203400mAh%20ft%20(Black)-Energy
Efest%2018650%203400mAh%20ft%20(Black)-PowerLoadTime
Efest%2018650%203400mAh%20ft%20(Black)-TripCurrent
Efest%2018650%203400mAh%20ft%20(Black)-Charge
Conclusion
Both batteries are very good, the slightly low protection limit is only a problem in special applications (Discharing a 3400mAh battery in less than 40 minutes is not normal usage), not for regular usage.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
Ramblings
Ramblings's picture
Whatever would we do without your battery reviews.
Much appreciation from just the average flashaholic.
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
CM2010
Last seen: 36 min 39 sec ago
Good work, as always.
kreisler
kreisler's picture
Last seen: 5 years 4 months ago
thanks!! Smile
*FMI* i got 4 i/o sh
vēer
vēer's picture
Thanks, good to see that Efest are making ,as Ezarc corrected my wrong choice of words, distributing decent batteries, makes me much more confident in my protected 2600mAh ones :D!
HKJ, youre at your best, as usual ;)!
SashiX
SashiX's picture
Last seen: 5 years 1 month ago
vēer wrote:
Thanks, good to see that Efest are making decent batteries, makes me much more confident in my protected 2600mAh ones :D!
I’d say they (as many others brands too, of course) “choose” decent batts to put their wrap on them :bigsmile:
Anyhow, good cell and good review as always WinkBeer
sb56637
sb56637's picture
Last seen: 1 day 14 hours ago
Thanks a lot! Frontpage’d and Sticky’d.
Suncoaster
Suncoaster's picture
Last seen: 3 hours 56 min ago
Location: Where the girls are green and the grass is pretty.
Thanks HKJ.
Appreciate all your reviews.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
balloonix
Last seen: 6 years 3 months ago
Like everytime a perfect review. I ordered 2 pcs of those batteries some weeks ago and made some tests with the same results. Maximum current was 5.8 Amps and cut off was 2,30V. For user im EU it is a good choice because the batteries where delivered from a warehouse in the EU.
applevalleyjoe
Last seen: 2 months 4 weeks ago
Can you get these batteries in the US and if so, where and how much?
