I'm watching with interest. Are you going to detail the driver mod again for the people as unfortunate as myself who did not understand it the first time you did this and whats the actual size of the batteries? I love the comedian OL. Quote, ''It's so ugly I had to slap it when it looked at me'' unquote. Not quiet sure what your referring to here but for some reason I'm still laughing. Thinking about it should I be worried? Cheers.
Being that you're swapping emitters you get a lot more flexibility to set the spacing the way you want, much easier than dealing with 3 on a single PCB. Cutting the p60 reflectors it might be less fiddly to spread them out so that the only cut you have to make is at the outside edge so each reflector only needs one cut. The one I'm working on is with a 3-up board, and the reflectors are gonna have to be cut to match the cut on their two neighbors...
Well crap... mine has thwarted everything I've thrown at it. Strap wrench, heat, you name it. Another user mentioned theirs had red loctite, there must be two different batches of these things.
Thanks. I think you know that I have an idea floating around in my head and it may involve this driver if I can nut it out. Thanks for the offer of translating it but its just me. I understand the principle but making that principle work, well, we'll leave it there. Cheers.
I have floating things in my head too. The doctors say surgery won’t fix them. Sometimes I have to tilt my head to the left and other times I have to tilt it to the right, just to get the ideas to float close to where I can grab them. My wife says it looks mighty odd, but hey, it works!
I've been doing some measuring and overall, I would go with either the stock reflector plate (stippled because it's in such bad shape) or TIR optics. I still have a locator already made for three TIR optics, from a failed Mag mod. It sits in the head perfectly. The only catch was that the TIR optics were 14mm deep and the original reflector is 19mm deep. Well, I flipped over the bottom plate that holds the leds and now it leaves 14mm space instead of 19mm space. How much more perfect can I ask for. I can use either 15 degree TIR or 30 degree TIR. I can test them both and I could even supply both sets with the light. Cool
The other option would be to fab three Mini-Mag LED reflectors to fit. It could be done and I imagine the light would throw like hell with those. At least I think it would. It's another option, but I am favoring the TIR option. I like the way they fit right in and the ability to change the degree of the optic.
I might test one of the Mag LED reflectors, to see what it would do with an XM-L.
AFAICT, I dont think there are any “bad” 3 terroid driver versions for the SRK. They typically suck 6.5A from 4 good 18650’s and deliver 2A to each emitter. Resistor mods are reported to provide as much as 4A to each emitter.
There are NIMH batteries that are the same size as 18650?
I’ve wanted to play with some lights that use those batteries, but am trying to stay away from rechargeable lithium (and the hazards that come with them).
Now I’m more interested in 18650 lights.
