$2 DIY bench power supply for testing emitter and powering a hobby charger.
Nice build! I have an ATX supply I hacked into a bench supply, although I put the banana jacks ad master switch right into the metal case of the PSU.
One thing to note: these power supplies are not current-limited the way a proper lab supply often is. You can easily short many amps through something if you are not careful. Easy to let the magic smoke out.
Oh, and excellent cigar selection as well!
awesome job, love it. 8)
Here is what they claim for an average 300W supply:
Thanks for the information! I have numerous atx supplies in the garage that I couldn’t part with! Now look what i can make. The woman will be so happy that i have another BLF inspired project. Lol
edit
Nice job Johnny!
I have never seen a power supply enclosed in Spanish Cedar. Very creative!
Thanks, guys! Yeah, even my step-son came home last night with his girlfriend and saw it on the kitchen table. He came into the living room where I was and asked, "did you make a power supply inside a cigar box?". I replied, "yeah, man" to which he said, "that's awesome!" :bigsmile:
Very nice project JM Kudos :bigsmile:
Thanks for the link! I actually started Googling and found that link in addition to this one: http://www.instructables.com/id/Convert-an-ATX-Power-Supply-Into-a-Regular-DC-Powe/#intro
-Garry
AT PSU’s are even easier to convert.
If you happen to have them lying around. I think I have about 50 of them so anyone within 3 hours drive of me can have one for free. It’ll help clearing the crap from my house.
Issue of the Resistor
Power supplies need a certain minimum load to work properly. The min. load for mine is around 0.8 amps. Thus if you plan on powering LED’s or other such low-power device exclusively, you’ll need a resistor to provide a load. Otherwise you will damage the PSU.
A meaty 10-Ohm, 10 watt resistor from Radio Shack is a good choice. Wire it across 12 volt and ground.
One of those articles also suggested wiring it so that the cooling fan became the load.
-Garry
Excellent idea!
interesting! I wonder if one of these could be used to do home anodising? Most guides I read specify a certain amount of current per surface area, whereas these are voltage controlled instead. It certainly would make it a whole lot cheaper if it would work.
Current for anodising is best at lots of amps. Preferably more than your typical PC PSU can provide. The more amps the better (generally).
That greatly depends on the size of item being anodized. I have read through post that did use a computer power supply for anodizing with small pieces. I use my automotive battery charger to anodize with. It works well with a small host like a cut down mini mag with very good results. I tried a full sized 2D Maglite one time and didn’t turn out so well. The current wasn’t high enough for the amount of surface area in the mag.
Rit clothes dye from wally world, Sunshine Orange.
WOW! :open_mouth: :bigsmile:
thanks, I’ll have to go back and read the mtbr thread about it and see how much current I would need…
Also, you can easily get voltages that aren't officially supplied by the PSU. For example using the +12v as positive and +5v as negative will give you the difference between them, in that case 7 volts.
Nice work! I like the enclosure!
If you need a bigger power supply with way more amps you can also convert a server power supply.
How many amps would you need to properly annodize a 2C mag? My power supply can deliver up to 150amps at 13.8v, would that be enough?
