Review: ThruNite TN31 (XM-L U2 | 3 x 18650)
42 posts / 0 new
Rusty Joe
Rusty Joe's picture
Can someone explain to me how this monster only throws 700 meters when the Olight M31 Triton with just 800 lumens supposedly throws 700 meters (per factory specs)? If it doesn't surpass that by a good margin, how could it be any kind of monster thrower?
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
turboBB
All whitewall shots added.
Thx DARCANGEL!  I have another vid planned but just need to find a free weekend.  A fellow member has some big guns (SR0, etc.) to bring along.
@Rusty Joe, unless there are independent validations, mfg have some liberty at claiming what they want based on their testing.  In this case, I was able to best ThruNite's claim of max beam intensity (87K vs. 75K), however they had reported 700m throw (which doesn't compute since 75K only translates to 548m) and would've meant the beam intensity would've been higher (122.5K) to reach that goal.
This is where real world measurements come in handy.  =)
PilotPTK
Last seen: 6 years 2 weeks ago
Quote:
The switch itself draws 9.56μA when turned on (again isolated w/just the battery carrier) and measured either through the negative spring or the ground/negative path on the PCB. I however wasn't able to measure any draw when it was off:
That's a damn accurate Fluke you've got there..
10.34 V / 2200000 Ohms = 4.7 uAmps * 2 Resistors = 9.4uAmps
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
flash87lightBB
Last seen: 6 years 10 months ago
Great JOb! Like always
Quick Question
Any one have any thoughts on…
Olight M3X-L2
Sunwayman T40cs XML U2
Armytec Barracuda XML U2
NiteCore MH40 “Thor”
Thanks!
AlexGT
AlexGT's picture
Last seen: 1 day 19 hours ago
Thank you for your review TBB,
I want to add to your review that I opened mine up to upgrade the stock AWG 26 silicon wires to AWG 20 Teflon wires and install arctic silver 5 thermal compound, while I had it dissasembled I noticed what appears to be kapton tape adhered to the underside of the LED PCB, I don’t think that there should be anything besides thermal compound between the copper PCB and the aluminum heatsink, so I removed it and proceded to lap the underside of the PCB to a mirror polish.
After assembly I noticed a significant heat transfer from the LED to the body of the light, I think ThruNite should remove the tape from the stars prior to assembly to improve heat transfer.
Maybe mine was the exception that got sent with tape under the PCB, have you opened yours up? Could you check if yours has tape underneath the PCB?
Thanks!
Handsome
Handsome's picture
Last seen: 6 years 3 months ago
Pok wrote:
2100 wrote:
Been a long time since i have purchased any light, and this is good.  Nice and i was going to email my regular shops till i saw the price. Unfortunately at 220 bucks it’s crazy.   My TK70 with batteries included still is under this and kcd is a wee bit higher.  (of course that’s a bigger light)
But it’s good, time for Trustfire/SkyRay/Ultrafire to come out with 85mm head diameter based lights. The last time that one from cnquality goods was underdriven at 2A.  They already have the host ready (and it’s quite nice), the X7.  Smile
I hope so 2100 Wink
My mod Zhi Jun JD-9668 now is 78,000 lux
(XM-L U2 and driver is about 3.6A to LED)
While stock driver and LED is 37,750 lux
Sorry, din’t take beamshots yet.
However the MSRP is 220 USD, actually the sell price is 145 USD on their Amazon and Ebay store, do you still think they are more expensive than TK70
Handsome
Handsome's picture
I hope so 2100 Wink
However the MSRP is 220 USD, actually the sell price is 145 USD on their Amazon and Ebay store, I do not think they are more expensive than TK70. I do think TN produce quality goods but sell reasonable price, but the price changes quickly during these days. Low – High – Low – ? ?
fullfine
Last seen: 6 years 2 months ago
thanks Turbo BB, great review, I am wanting to buy a flashlight to hunt, the thrunite TN31 is great.
turboBB
Thanks guys!
@flash87lightBB - don't have the others but I just did put up a review of the new M3X XM-L2 here.
@AlexGT - haven't taken it apart but will post results if I get around to it.
Slim Pickens
Slim Pickens's picture
Last seen: 2 days 5 hours ago
I do find that interesting AlexGT. I wonder if it was just an isolated assembly error with your light. At least I hope it is Silly
Tom E
Tom E's picture
Last seen: 6 min 35 sec ago
I'm a little late in getting on board, but just got a new TN31, here's measurements I got:
  • Tailcap w/battery carrier showed 1.3-1.4A or so, that’s 3.9-4.2A to the LED (not sure if this is accurate)
  • Voltage reading on the battery carrier was 12.55v (not connected), not much loss there (stiff springs).
  • Lumens: 1169 at start, 1125 at 30 secs — right there in the ballpark of their specs (1147)
  • Throw: 6900 lux at 4.31m,  = 128 kcd, = 715 meters, also right there what they spec (they say over 700 meters). I did see as high as 7050 lux near the start.
Not sure I can explain diff's between mine and the OP's for lumens and throw, but I seem to be right there for the ThruNite spec, even though their 75 kcd contradicts their 700+ meter spec. My unit's S/N starts with 2012, but TurboBB's was bought much earlier, given the posting in May 2012.
Plan on mod'ing this, of course Smile.
