it made a significant increase in lux when I de-domed an sst-90 - but its late and can’t recall the % gained :weary:
same w/ green xp-e - but I think that tiny little emitter has enough problems w/ artifacts before a de-dome and I might not do anymore. at least w/ those you don’t have to worry about phosphor damage…
We were thinking that 0D would would warm up nice, hoping next day or two. Little backed up now . Just de-domed it because I was doing the other light.
Finished this mod. Tested it out in the C8 pill and it warmed up nicely. I'm a bad judge of tints though and don't think my pics would do it justice. Compared to a 3C? Maybe close - think it warmed up quite a bit, maybe warmer than 2A or 2B.
Thats good news TomE. Thanks was wondering the same thing as AlexGT
I soaked a xre in gas for about 24 hours and the dome was gone. Then I tried to pop off the ring and upon doing so I damaged the led someway and it doesnt work. I then did another for about the same amount of time soaking and popped off the ring this time and it still works! Success with the xre! Thanks for whoever posted about popping the ring off after soaking in gas, I tried to pop it off after a dedome with out gas and it wouldnt come off.
I am now soaking a green xre with hopefully good results.
Wish they had something like a sinkpad for these. Might have to make it a direct bond to a copper disc and try to over power it to see what power it can take.
Has anyone sent a dedomed LED to Craig at LEDMuseum?
(I’m not sure if he’s got a photometer right now, but I’d sure be curious to see a spectrum of the output.
I wonder if the dome is doing any significant filtering of light at the UV end of the spectrum, for example)
Haven't heard but I don't think I've heard of LEDMuseum either. I could certainly spare a T6 to de-dome, got quite a few laying around from all the upgrades.
Hm…
I never took a close look at my de-domed XM’L since it JustWorks™, but this thread got me interested, and…
looks like my emitter, that is working completely fine, is supposed to be royally f**ed?! (look at the bond wires)
Here’s a full pic, not like it contains any extra things to see, but I’m just throwing it in since it looks kind of cool: http://shadowww.eu/blf/DSC_0014.jpg
Edit: took a pic of fully lit emitter (taking a pic of emitter in a ~5A direct-drive flashlight wasn’t as easy as I expected!), seems to look somewhat normal. Hm.
That was a truly dirty job, the led should not be working at all, it only has one of the bond wires left ?????? I now officially believe in magic (it seems there's always things left to know about leds)
Unless I'm mistaken those wires are only used for positive, all 3 of them and negative comes from below the phosphor, so that should work just fine (but at lower currents as there will be more resistance).
The missing bond wire must be still attached to the die, but laid over and getting power from the one next door. Each bond wire powers a pair of strips, if the lower two weren't getting power you'd only have 4 of the 6 lit up.
Yes, but technically speaking those strips aren't needed. After all the XM-L2 doesn't use them (and that is how they increased efficiency according to one post I read).
I dunked an XRE in Coleman fuel for 24 hours and the dome came off clean. I popped the ring off by using a pair of diagonal cutters at the base as a wedge. The LED worked fine, but the color temp went from 6000K to over 35,000 K! Looks like most of the phosphor came off with the dome.
