Got the Nichia 219 in it:
Moon: .05 lumens
Low: 9.5 lumens
High: 86 lumens
CCT: 4200K
CRI: oh my!
Moon: .05 lumens
Low: 9.5 lumens
High: 86 lumens
CCT: 4200K
CRI: oh my!
I just occurred to me that the “Saber 1A” is sold as “Spirit” by Fasttech, for $22.00.
I wonder who really makes those things?
Mine, too (BLF “special”). I finally took some 400 grit sandpaper and roughed up the bottom of the tube. Seems to have helped.
[quote=texaspyro]
Look familiar?
I wish the spirit was an xpg2.
despite all of the ‘issues’ with TN and the BLF 1A, I have to say that my copy (from fleabay, $25 bo) has been great! On 14500 it is a great little light… keeps moonlight mode as well…
Hope those who are having issues get the details sorted…
i assume that is easily fixed
I tried a couple of NiMH cells. They would not fit in the tube. Tube is 14.3mm ID. NoMem 2500 mAh cell is 14.3 mm, goes in half way. Imedion 2200 mAh is 14.28 mm, goes in about 3/4 way and then seems like air pressure is keeping it from going in the rest of the way. I’m not going to force the issue…
I got around to testing my Fasttech Spirit light ($20). It did 115/12/.06 lumens… actually more than advertised and more than the Thrunite Saber.
Then I put a Nichia ’219 in it. It gives the same output as the stock XPG R5 (and around 15% more than the mod’ed Thrunite Saber).
Does the spirit support a 14500? and for how long on high
It should, it is identical to the Thrunite (down to tooling marks on the LED centering ring). Nowhere does either say that it supports lithium rechargeables, but people say they do.
Hadn’t seen the spirit until now, it looks indeed identical.
Here a link if someone else want to take a look http://www.fasttech.com/products/1601/10003046/1227900
The spirit appears to come with a lithium battery. Does that mean the circuit officially supports lithium?
Appears with a primary lithium battery (Lithium NICE), only 1.8V (soon drops to 1.5-1.6V)
It’s an alkaline battery…
Sorry, I think it’s much better than an alkaline
I checked it again, and it does say Lithium on it. Somewhere I did receive a Nice AA alkaline in a light. Looks the same.
Hi,
I just bought Saber 1A, but frankly I’m not impressed with the performance.
I find 169 lumens on High is hardly believable because it looks so much dimmer compared to my old mini torch, Ultrafire single mode at 200 lumens (factory claim). It uses XPG Q5 & CR123A. I bought it for $9 on sale.
It’s exactly like here:
http://dx.com/p/ultrafire-w610-cree-xp-g-q5-200lm-white-flashlight-black-1-x-16430-186192
Sure at 200 lm, the Ultrafire is supposed to be brighter, but the brightness difference between the 2 flashlight is too massive for 31 lm difference. The Ultrafire looks like almost twice brighter (at 200 lm) vs Saber 1A (169 lm).
When doing wall test from 9 meters away, the Ultrafire is still showing a bright hotspot with spill. The Saber fail to show any hotspot at this distance. It’s just a reasonably bright spill.
Is Saber 1A lumens inflated too much ?
I know some people use 14500 in this torch. Does the drive actually support 14500 ? Will it blow the led or something ?
Comparing a 3 volt light to a 1.2-1.5 volt light, I wouldn’t be surprised if the 3 volt light is brighter because it should be.
The Saber 1A is also a floody light so it doesn’t have a tight hotspot, that may be one reason why your “200 lumen” light appears a lot brighter.
I have no way to measure the actual lumens but it is rated at 169 ANSI lumens which means it really should be 169 lumens, where the UltraFire don’t use ANSI lumens so its anyones guess how many lumens its putting out. Not often but sometimes they put out more than factory lumen specs but usually they over rate it.
The voltages and a reflector that looks huge on the UltraFire pretty much make them uncomparable. It seems to me like flood vs throw and twice the voltage so its not surprising that the UltraFire is appears a lot brighter and has a brighter hotspot.
Which battery have you used? Have you tried a eneloop?
14500 make a huge differents in brightness, with a AA it is to dim for me too.
But with a lion you will have the hassle with thickness…
