Normally, I would say that looks like a terrible emitter base because it appears to have no real heat disbursement layer extending out under the thermal pad. But, it looks perfect for what you converted it to. Big spread out copper layers going out from the emitter’s electrical contact points. Just guessing, but that should disburse the 700ma of heat from that emitter good enough.
I borrowed this picture from FT. Its the underside of the Nichia 119 (for those who are not familiar with it)
If using these emitters in a single AA light and such I am sure a modified xp-g board will be more than good enough for the typically 300-500mA…
If upping the juice, one could just use a modified Noctigon , Id guess that would be better than a proper aluminium nichia 119 mcpcb.
Using a Noctigion would still be a dirt cheap combo with one of those emitters.
High CRI copper mounted emitters for the win!
A “regular” mcpcb and emitter have 3 connection points to the emitter. Positive, heatsinking in the middle, and negative.
The Nichia 119 only have two larger connection points. Positive and negative. If you tried to put the Nichia 119 on a stock xp-g mcpcb both the positive and negative connection would be connected in the middle. Making a short circuit. In order to avoid that, I just used a Dremel and made two quick small cuts to lower the middle part.Thereby, no short circuit.
Okay, I think I get it. You gound down the heat sink pad in the middle so it doesn’t touch the bottom of the MCPCB. I wasn’t sure what the pic was showing me. I’d like to try this. I’d feel more secure if there was a non conductive film of some sort to be safe.
So, if this LED has no thermal pad, how does it transfer the heat? Also, what are these 119s rated at, current wise.
Should work just as nice there.
Ill try with a Noctigon some time… Ill try a drop of fujick into the trace/traces that were cut.
Should improve heat transfer a tad, and also make it more short circuit proof. Ill assume it will handle the heat when re-flowing, not 100% sure though…
I looked up the Noctigon seem to be same as the sinkpads.
This is good news as I still have a few 119 samples left and couldn’t find a good copper base.
I built up two today, using this method. I used an Xacto knife to scrape off the center pad, leaving behind the dielectric layer. Basically the same result, with a different method. To be honest, I was too lazy to go (20 steps) to the workshop and break out the Dremel
I put one in a C3 that has been sitting around for a while waiting for a change. The result is a ringy high CRI beam. I think I need to adjust the emitter height, or swap the reflector (has an XM-L reflector right now).
The other went into a BBQBuy SK68 clone. The pill was solid, so the star has a good seat. The beam is near perfect, although the output is a little lower than the XP-E it replaced. The tint is waaaay better. It has a nice smooth flood with great color rendition.
I have three more 119 emitters on hand. I have some small hosts kicking around that might get a high CRI upgrade.
bit of an old thread, but I was wondering what peoples views are on the tint with these 119s from FT? I’m thinking of building a cheap light bar for my garage/ workshop with a 3-5x1-2W 110V driver (any ideas on that front?) and these would be a great option.
They’d also work well for small closet lights too, another thing the wife has been bugging me about
Tints are subjective, but I really like the tint, its WW but not super warm. Its not that yellow/orange looking as the typical 3000K Cree emitters. Color rendering is good.
I like it. They are so cheap that you might as well just buy one and try out it, buy in quantity if you like them…
They are a quite nice tint, warm but not overly yellow. I have bought 10 so far (I get them five at a time) and have plans for them in flashlights and other projects.
sweet, thanks guys! I have a couple of WW XR-Es that are just too yellow for me, so knowing that these are not overly yellow is a big plus. I might as well get 5 and have a play
did the reflow last night after cutting out the centre thermal pad on my XP-G stars (10 for $1.xx from FT!) and it worked a dream. I could even grind off the copper trace but leave the dialectric layer intact. All 5 lit up fine, now I just have to make the light bar. Thanks RaceR86!
