Gotcha. On a few driver boards I was a little to aggressive in cleaning off the crap on the edges and the fit is now loose, I’ll have to give that a try when I get around to using them
I have decided to use the solid wire press-fit-only method from now on, as 1) I hate soldering to the pill even though I have figured out how to do it cleanly by now; and 2) I fiddle with things so often, being able to get at the backside of the driver with no soldering? That's like... amazing.
Spring? Who still uses those awful outer springs?! Use a solid spacer instead. Better heat transfer AND better ground path. And swapping dropins is still just as easy, unlike when you wrap them with foil/tape.
Thanks for the link comfychair. I was searching for that tip, but couldn’t remember where I saw it. I may PM you if I have problems with fitting. comfyspacer
I recently used a single strand of copper wire to ground a star on a nanjc driver… i was trying to blob my way to ground out the third star but it was a mess… i stripped the end of a piece of scrap wire and separated the strands of copper wire. Using a single strand I soldered it to both the star and the pill, then trimmed the excess… works much better/cleaner….
i will have to try the press fit… as soon as my new drivers come in…. i just ripped the positive contact right off the board trying to solder a heavier gauge wire on…. |(
When you solder the braid to the traces, how do you get the solder to now flow into the whole braid?
When I working that Tiablo and tried something like this, in just a sec of contact with my soldering iron, about .5 - 1 inch of the braid would get impregnated with solder, so I just had one stiff piece of soldered braid. When I tried to bend that, it pulled the traces off of the edge in several places :(….
Or, if you have too much free time, or need to fit a ~20mm driver in a p60, you can do this:
So would the heat transfer be better, since it has a much better connection to the pill, or worse, since it has less contact with the light body (it's a loose fit, and only sits on the little shelf)? It's definitely less convenient as you'd have to do this for each dropin while the split ring spacer stays in the light.
/end thread hijack
On my first dropin, when I couldn't get the solder to stick I put down the iron and grabbed the butane torch... and melted off all the components on the backside of the driver. :Sp
I lightly tin the small area where the braid is to adhere to, then wipe off any excess solder from the tip of the iron, and press it down on the braid until it sticks to the tinned area.
Actually, you don’t even need to solder it to the top side of the board. You can fold a piece of braid and hang it accross the edge of the pill, press the driver in tight, and trim and fold the braid from the outside of the pill, back over to the trace on the driver. Then flux and solder. It accomplishes the exact same thing.
The trick for doing the stars is this: Put a blob on the star, big enough that the surface tension makes it, well, blobby... do the same on the ground ring. Let it cool, then with just the very tippy tip of the iron, lightly touch the top of the blob on the star, pull the iron across to the blob on the ground ring, and then pull the iron away. Do it in one smooth continuous motion - if you completely melt either blob, it won't work.
