So, how do you calculate total/individual amperage with LEDs in parallel run off a common output? For example if I used the H6Flex in the triple MTG2 build with 4S cells and LEDs in parallel, vs. the original plan which was HBFlex boost driver with 4S cells & series LEDs.
(numbers with the HB boost: cell voltage 12-16.8v in, total series Vf of ~18.9v; w/H6 buck: 12-16.8v in, parallel LED Vf of 6.3v)
I have no measurements at all as I have only just got my pill together with driver and led but can confirm that this driver will run the MTG-2 hooked up to a couple off trustfire 26650 at 3.8 volts with no load on them. The led is direct to copper and it is the quickest I have ever had a pill get hot. The mode changes still has that pause between them as reported elsewhere.
Crap! :( Was hoping for some actual single cell boost action. Was it you or somebody else who reported that driver didn't like running off a single cell?
This is some really quick testing on the above driver with new Trustfire Flame protected 26650. Good news first.
3 cells 12.48v No load voltage 2.55 amps at the batterys current draw
2 cells 8.34v No load voltage 3.2amps at the batterys current draw
1 cell. No load voltage 4.15. On high battery voltage dropped straight away to 3.74v. Current reading I managed to get was 4.2 amps. Driver immediately dropped to a current draw off .4 amps with a voltage at the battery off 4.11v.
I would suggest this driver for some reason with one cell hits the low voltage cut out on the driver and drops to a lower mode. I dont believe l have enough time to get the correct current reading as this happens very quickly.
This also happened on an XM-L but just not this quick. The experts can chime in off which I am far from but this driver does not run well if used on high with a single led full stop.
If someone can work it out from this information it would be nice to know what current this may be getting at the led.
On an XM-L2 this driver on higher at the tailcap was running 1.39 amps with 4 TF 26650 which should be about 5.56 less efficiencies at the led.
Oh well. I suppose it would've been a minor miracle if it worked. I wonder if it works in boost mode at all (not asking you to run more tests, just thinking out loud!! lol) and under what circumstances. 8.4v in, total Vf of ~9v, 12v?
I'll have one to torture myself someday, that is if SingPost ever decides to look around for my package that must've got dropped behind a shelf somewhere and actually put the damn thing on the airplane... grrrr
Direct drive from 2x 16340s I got 3.6A, but it falls to 2.5A after only about 30 seconds (and keeps falling, and falling...). The little cells really don't like it...
I guess if you could keep the current down to like 1.2-1.4A it would give you more runtime before the driver throws in the towel, but what's the fun in that? A hard driven XML on a single cell would be brighter and run longer. If we ever get ~2000mAh 18350s this'll get a lot easier. :(
Do you have any IMR 16340 or 18350s, comfy? I wonder if two of them could hold their voltage long enough to be of some use with a buck driver. Also, how is your test setup resistance-wise?
for LEDs in parallel, the current per LED is simply the current provided by the driver divided by the number of LEDs. So if you had 2 XM-L in parallel and wanted each to get 3A, you’d have to set the driver to 6A. As long as you fulfill the input voltage requirements of the driver (eg. h6flex needs no. cells in series = no. of 3V LEDs in series + 1, HBflex I’m not as familiar with), that will always hold true. What you may find though is that if the battery you’re using can’t provide that much current, its voltage will sag so much that you’ll get a much shorter run time than you expect. It’s a tricky one - usually it would be better to run the LEDs in series with a boost driver, but then you run into the same voltage sag problem as the current draw from the battery is higher than that seen by the LEDs. You’d have to run the numbers to see which driver type works best for your battery set up.
the above however is for taskled drivers - the ones from China seem to be more variable in their output with respect to input voltage.
Test 'rig' has just been rebuilt, it's a 4P 18650 box, with triple 22AWG wires attached to each end, neg side includes a typical forward clickie. Each cable is around 10" long. I've pulled 15 amps out of it testing other stuff so far...
I've built a p60 pill, MTG2, brainless zombie single mode 105C with only 4 380mA chips, just to see if the 16340s are up to it. The pill is assembled and functional, I just have to modify a reflector & make some kind of insulator/spacer, after that it'll be up and running in a L2P.
Does 2.21A at the tailcap at switch-on, falls to 2A at around 30 seconds (likely the fault of these particular cells, will get some more soon to see if they deal with it better). The 4 7135s are all on the backside of the board, MCU removed, jumper between Vcc & PB1 pads.
None of the reflectors I have are happy with it, any combination of emitter hole size and spacer thickness leaves a yellow area in the middle of the hotspot, which from other MTG2 experiments means the positioning isn't right yet... just can't get there with the parts I have currently. I need some SST50 and/or MC-E p60 reflectors, if such things exist....
LOL, how the hell should I know. The driver is doing something, as the same cells in direct drive do 3.6-3.7A. I haven't compared input current to current at the emitter, but I doubt the driver is eating the amount over the 1520mA it should be doing, as if it were, I expect it would have caught fire by now. Output is steady, unlike when I tried a similar setup with 2x 18650s, which got the driver VERY hot and it started complaining.
I still have the diode in place on the driver so that cuts the voltage down some (doesn't it?) that's being jumpered to the 7135's Vdd pins, but is that safe, or making it do something funny? Should I use a resistor instead of the jumper (and if so, what value)?
The current my be high if there is a semi-high resistance short. The emitter has contact pads the top of the pcb along the whole of two sides. Some current may be flowing through those pads into the reflector.
