We’d have to get one and disassemble to get the measurements of everything but TIR lenses are plentiful and had in many beam angles. Even a reflector might be easily had for it depending on the sizes of the components.
What sort of beam will it give?
Shadow SL3 XM-L2 4-mode just $55.87 and $53.07 after BLF code is applied
SHADOW JM26 XM-L U2 4-mode $47.80 or just $45.41 after BLF code
SHADOW VG20 for $39.79 or just $37.80 after BLF code
SHADOW VG10 for $35.17 or just $33.41 after BLF code
nice! glad to see them stocking Shadow
UF-K21 Cree XM-L U2 1-Mode 700-Lumen LED Flashlight
$14.39 or just $13.67 after BLF code
Authentic Ultrafire XM-L 5-mode 14500
$18.64 or just $17.70 after BLF code
Xeno E03 clone. Super thick walled body should make for great heat management on high. Clip is nice to have as well.
And a CR123/16340 version of the same light.
$18.29 or just $17.37 after BLF code
Those Shadows look really nice! the JM26 and SL3... and arent that expensive.
And dont forget the Jetbeam I4 pro charger for only $18.. before coupon.
And dont forget the Jetbeam I4 pro charger for only $18… before coupon.
That’s expensive, it’s cheaper domestically (USA).
... I thought they usually went for 20+
but maybe a good deal for international buyers!?
This one looks interesting. I wonder if it also works with NiMH/Alkalines?
JohnnyMac:Authentic Ultrafire XM-L 5-mode 14500
I doubt it or it would have been listed. Even the Xeno is only a good light when a 14500 is in it.
… I thought they usually went for 20+
You can get them here (USA) for $13.50
i wonder if the shadows are really that dark or if its the lighting? all the other sites show them not as dark
that is a great price on the sl3
Wish they had the shadow jm26 and sl3 available in NW like intl outdoor
ChibiM:… I thought they usually went for 20+
got link mate, thanks beforehand
IS with the coupon code, otherwise it’s still only $15
Exquisite Candy!!
What makes these so tasty? Two modes, 4 lumens low. So that might be like my Preon P0. Wonder what the beam is like.
Two levels of constant output: twisting the light head in counter-clockwise direction to tighten the head for high output and twist it in clockwise direction to loosen the head a little for low output:
High output: 66 lumens (1.5hrs)
Low output: 4 lumens (16hrs)
I don’t like the look of the emitter. Something a bit off (sorry, SWM):
looks like the bezel is fixed, but hard to tell from that pic
