Review: Ultrafire C3 Stainless Steel XR-E Q5 1xAA 3-mode
Tailstands huh? Lucky! Mine doesn't.
How do you know?
Which version?
If it died after 1-2 weeks you can probably get it replaced from Manafont?
My C3 SS is the one from lightake. It is the 93mm body. Tailstands very well. Didn't work when I first put a battery in. Discovered that the pill was not screwed in all the way. Tightened that and it worked fine. Definitely the Q5 version. Body is very well made. The pill has an awful lot of solder all over the place though. Doesn't seem much brighter than my ITP c7 on Nimh. It actually arrived within two week of ordering too.
I compared it to a sure Q5. Equal aspect and equal output (with same input obviously).
I finalliy got the C3 SS today from DealExtreme. It works fine, but it is indeed the 98mm long version, not the 93mm length that is shown in the photos on their website. Seems to work well with either AA or 14500 batteries, but the modes are strange.
When you first turn it on, it defaults to Medium, one click takes you to Lo, then High, then Strobe and then SOS.
Sort of makes sense to default to medium, I kind of like that.
Fit and finish and the seams were good. Not highly polished, sort of a satin finish to it, and it does tailstand.
I'd say well worth the $13 I paid for it.
Is quite strange. I have the DX version too. It has 5 mode: H-L-M-STROBE-SOS and it has memory. So when you turn it on, it starts from the last mode you used.
Today I got another SS C3, this one from Tmart, and it is the one-mode light.
It is 93.7mm long, go figure. Doesn't seem as well-made as the MF one, There is a small gap (line) where the headpiece should be totally flush with the body, Other than that and very dry threads, for $10 it's a steal.
Anyone used this light for more than a month? I love the Fullstainless steel body which includes a steel switch. Like to get one but wanted to know if its better than the ordinary stainless steel C3s in terms of quality, output and durability overtime. Have several budget lights that have faulty switch due to accidental drop. Thanks
Neither of mine have steel switches, they both have rubber tail clickys.
And they are brighter with a 14500 battery compared to the AA alkalines.
Your 3 mode C3 from Manafont has a rubber switch?
I have a 5-mode and a 1-mode, neither came from MF
I have the LT C3 prize over half a year and it gets used almost daily. No issues so far. 0 maintenance except switching batteries and lens cleaning.
Aloha and welcome to BLF Ian2381!
What part of the Philippines are you from?
Thanks fishinfool,
I'm from Cainta, Rizal.
Just bought the 3 mode from manafont and hopefully once it arrive i'll be writing my review on the light I will receive.
Aloha Ian! Pinanganak ako sa Olongapo (Subic Naval Base) pero lumaki sa Baguio. Hopefully someday makalik ako ng PI. Ingat.
MLH makes a lot of sense.
But!
It drives me nuts.
I understand why it is an excellent idea - and I want to like it.
But.......
I'd much prefer LMH. Or HML.
But that's just me. For most folks MLH is probably far more sensible.
Maybe you'll find the Philippines a lot different now. Can't imagine how things changed a lot here. are you also a CPF member? Hopefully someday I'll be able to meet flashlight afficionados.
Thanks and Ingat din
Does anyone know where I could get a new Driver with multiple modes that will get an output of about 140 Lumens (on R5/R4) for an Old Ultrafire C3 SS?
Thanks
