Johnny - I'll tell you what; if this light of yours does compare well with the 980L, Foy will be eating some crow for more reasons than one. The F15 is $20 less expensive so, other than the strobe mode (which I do not like) it would represent a better value.
I'm interested in that head-to-head between this F15 and the 980L. They both have pills that screw into the body, which is a feature I'm looking for. I like the idea of p60 drop-in modules, but having to wrap foil or what-have-you around the modules doesn't excite me. I'd rather just swap stars on well-heat-sinked lights. Are there any other contenders for good heatsinking and easily-swappable stars in the 1x18650 category? I have an MTE M3-2 that also has a screw-in pill (and the star is screwed onto the pill--another good feature), but its beam is so perfect for me that I don't want to swap the LED.
The Trustfire T2 pill screws into the body, so does my palight C8. I think the M8's are the same: most of the budget lights with oversized reflectors have the pill that screws into the body.
Somebody with some math skills could work out the spread based on posts and comments on BLF and come up with betting odds. I'm guessing because much had been said already about the 980L, it might be favored . . . but by how much? Hope Manafont ships fast this time. (been pretty good lately) Will be a fun shootout for us.
LOL! It might or it might say “from Dibbles with love, HappyFathers Day 2011” which is on the other side. She gave it to me early since i couldn’t wait.
i opened up the pill today and the led die is attached to a round plate with thermal grease and tht plate is then thermal greased onto the aluminum heatsink. I stuck a rigid wire in the hole and pushed the driver/holder down from the top. so mine is not screwed in but snapped into the aluminum heatsink through the bottom. when i tried to turn it led from the top i severed the wires and saw that it was screwed on. simple fix but will probably get some thermal adhesive. will try to take pics later.
I hope it doesn't, because I'm waiting for more reports. I've been also promised a reply from Manafont regarding the chance of having F-15 lights in SMO version soon, so there would be two SMO reflectors to choose from.
From Johnnys pics on top hes got a red driver board while the one i got was a green one. dont know if theres much difference but mine does flicker on low when the battery voltage gets lower. after opening the pill and severing the wires i figured ill try this XML on my sk68. i soldered the led to the sk68 stock driver and it is much brighter on 14500. i got 1.56amps on a partially charged battery. after putting an oring spacer to show a clear die on spot mode, its basically a big bright square which throws quite far. maybe a better driver with more amps but the sk68 is so small im not sure if it can handle the heat. its just fun shining a small light projecting a square beam where you can see the whole beam from the lens to where it is shining.
Honestly, no matter which comes out on top they are both winners. I happen to like the looks of the F15 over the 980L except for that awesome tailpiece the 980 has. That and the extra feeling of reliability I have with the F15 makes it worth having a few less lumen that won’t be noticed anyway unless you had both in your hands at the same time.
