dave_ Scratch made (by hand) - update 16th July (local) finished - sort of
32 posts / 0 new
dave_
Last seen: 1 year 3 months ago
It’ll be a while until I can start actually building something, but that’s no reason to don’t collect ideas in the tea breaks, right? Big Smile
I think I want something small and floody in an interesting form factor. Can’t be to complex mechanically, I don’t have a bench vice or something like that. (Yes, it’s going to be somewhat ugly. :P)
I wanted to try out these Nicha NS2L757AT-V1 for quite some time, why not now? Not the typical flashlight emitter, but all those small mid-power LEDs have a special place in my heart. Wink
Some specs: (is it possible to force line breaks somehow?) 3×3×.5mm package size; 2700k color temp; 83Ra; 120° angle of radiation;
At 180mA, they will deliver 60lm @25°C (107lm/w)
Or at least the datasheet says so. Silly
I think 5 or 6 in series would be nice.
I have some of those 50×31×7mm 850mAh Lithium polymer batteries here. Including driver (maybe LM3410+µC(tiny10?)+ maybe battery controller) it should all fit in a match box.
I am actually thinking about a box shaped light. I always liked that, but they stopped making them some time before I was born. Wink
Maybe I can make a housing out of brass sheets, have to look if I can handle that with my very basic tools. ^^
I’m looking forward to start building! Smile
Update: 28th June 2013:
Afte a long and annoying week of exams, I rewarded myself with a few hours of fun. Smile
So I built the power part of the driver:
That LM3410 is really nice. Few parts needed and takes not much space even when built on veroboard. Btw, that’s my index finger, not thumb. Smile (Yeah, I know, not exactly a good design practice for a smps, but it’s fast, and this is a quick&dirty after all.)
It works quite nice, you can see it drive 5 LEDs in series @~125mA from 3.2V here
Maybe I find the time to build the microcontroller part later this Weekend.
I still have not found my brass sheets. But since I messed up the LEDs a little (thankfully, they are to bright in the picture to see it ;-)), I may have to come up with a different idea anyway.
I think I’ll go with the ‘big’ battery
Nice weekend, everyone! Smile
30th June 2013
Now, time to share my failures. Smile
Last time I used the glue, I had quite some time to position the parts.
Problem is, we have a very high air humidity at the moment, significantly reducing the curing time of the cyanoacrylate glue.
But see for yourself:
The emitter boards stuck while I was positioning them, leaving them glued all over the place.
I guess I have to change from polished brass reflector to diffusor screen then. Silly
(And please excuse the crude soldering job, next time I better get some sleep before working. ;-))
I thougt, adding an emitter with a small optic would be nice as an optional light for a little throw.
I found this beautiful 9mm optic in my parts box:
I ordered it as an 20° beam angle, but instead it is this:
Some kind of a bright bar with oval spill around it. Thank you RS components, exactly what I wanted. Silly
I still have no idea what this optic might be useful for. ^^
More as a note to myself:
A rotary encoder would be much nicer for dimming than buttons.
I would need a bigger controller though, and the casing would have to e a little thicker.
I have to think about that . . .
3rd July 2013
I was searching for something to feel better about the oversized controller I have to use . . . and I think I have just found it. Wink
It is a LTC2942, a ‘battery gas gauge’. It can measure the battery voltage, charge/discharge current and temperature. (And calculates the charge in the cell)
The 2mm by 3mm DFN package may not look that hobbyist friendly, but since it has only 6 pins I got away with a sharp knife and a piece of PCB. Wink
It looks a little wild, but after sanding with fine paper and tinning with enough flux, the edges will be nice and clean
The nice thing about small pieces of 0.5mm RF4: you can reflow the parts by pressing the soldering iron tip on the back.
I like the little guy, looks even small next to the current shunt resistor. Wink
I hope that I can get startet with the casing on the weekend.
4th July
I just quickly put the Attiny44a on a board.
Now I actually need to invest a little thought in how I will put it all together. Big Smile
I found my brass sheets, but that stuff (0.5mm) is actually a little more tough than I remembered. (I hear you metal guys already laughing. :P)
We’ll see if I can actually get it in the shape I want. Wink
6th July
So, I tried to build the first part of the housing.
As promised, it is not very pretty. If you cannot stand seeing crooked constructs and unclean cuts and edges, please look away. Silly
The brass sheet metal is really unpleasant to cut without decent tinsnips or something like that, so I traded a couple of cutting disks for my rotary tool.
Still difficult to bend into shape without a bench vice or at least some strong clamps. So I bent it between two tables.
I guess claping to a piece of wood in the centre would have prevented the buckle it now has. ^^
It also got a little bigger than what I was aiming for.
The edges are soldered with a standard soldering iron btw. Brazing would have been nicer, but it actually feels quite sturdy.
I hope I can polish the soldering somehow to look a little nicer. ^^
That is more or less how I want the stuff inside. I don’t want a knob for the encoder but will try to make a wheel stick out on the longer side.
7th July
I tried for quite some time to make a good enough working reflector, but it doesn’t work like I wanted.
Since I will barely have the time to write te software next week, I decided to use a glass lens I had lying around instead. The beam looks interesting with multiple emitters, but not as bad as I feared. Wink
I probably will have to thange the LiPo for this Li-ion battery since it’s format works better now.
I whish I had more time to make my original idea work, but I simply don’t. ^^
11th July
I got a little time to work on the light today. Most mechanical work is done now. I still have to cut out the back, I think I will do that on sunday.
I soldered two of those threaded tubes (don’t know how they are called) to mount the LEDs on the lens. (And I should have brought my center punch. ^^)
Thermal contact is not great that way, but seems to work better than I feared. The battery will last on full power only 3/4h anyway. Wink
There you can see the emitters throug the lens. Looks a little strange I have to admit, and the soldering doesn’t gain beauty magnified. Silly
But it works ok. Nice and floody, I can barely see the artefacts.
Near the wall the artefacts are clearly visible.
I think I am ok with them since I feared they would be much worse, and they don’t limit the usability that much.
The battery monitor got wired up and taped down on the battery to measure more or less accurate it’s temperature.
(This is the good Chinese high temperature PTFE tape. One of the most useful utilities for soldering these sellers offer, seriously. Smile )
Besides cutting the backside and mounting all the stuff, I have a little software work to do on sunday. But I am quite confident now that I can meet the deadline. Smile
(BTW, the beam looks really beautiful with a single emitter. I will order another one for that purpose with my next FT order. ^^)
16th July
Sadly I didn’t got the time I needed today.
I implemented the basic functions and the light works, the only mechanical work not done is the leather strap I planned.
The stuff fits barely in if you pack it correctly.
But it doesn’t anymore when you let fall it on the ground and have only 10 minutes left to take pictures and post results. ^^
LEDs are also misaligned now. Sad
But al least it still works. Smile
Edited by: dave_ on 07/15/2013 - 19:55
ryansoh3
ryansoh3's picture
Last seen: 4 weeks 1 day ago
Great, I’d love to see what you come up with. Keep us posted! Smile
BLF ≠ B-grade Flashlight Forum
Pavithra_uk
Pavithra_uk's picture
Last seen: 3 months 3 days ago
Keep us posted
RaceR86
RaceR86's picture
Last seen: 4 years 4 months ago
Looking forward to see what you come up with.
For all of us who are not familiar with the LEDs. Any specs?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
dave_
Thank you, good idea to add some basic specs.! Smile
Looks horrible though, is there any way to force line breaks in the text?
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 4 months ago
Hit the paragraph button or hit return twice and type “p.”
Scott
MRsDNF
MRsDNF's picture
Last seen: 10 hours 49 min ago
I’m glad I’m one off the judges dave and not competing with you guys. I get to kick back like OL and enjoy seeing the creativity here. Good luck.
relic38
relic38's picture
Last seen: 2 years 6 months ago
Nice work on the boost driver Dave, really like how small that is. Would be good for driving Nichia 119s too.
You should be able to get those emitters off the plate if you scrape under them with a razor blade. I’ve done that with no problem before.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
dave_
Thank you! Smile
On a proper board it would be even smaller. Especially if you use a proper inductor. This is a ~5A shielded inductor I had lying around. Very much overkill. Wink
Good idea! I will try to remove the emitters. Thing is, it is only 0.5mm RF4 and quite thin where I filed through the copper layer. (As I said, I have very limited tools. Had to use a key file to cut the aliminium profile also. ;-))
I better do this when I am fully awake. ^^
FlashPilot
FlashPilot's picture
Last seen: 2 min 44 sec ago
Hey Dave,
Its great to see you back in full swing. The beam profile does look a bit odd with that optic.:bigsmile: Maybe you could make a cap light of some sort. It certainly looks light-weight enough for the task. How did finals go?
dave_
Cap light – that’s actually a great idea! I have to keep that in mind. It is indeed very lightweight. The Oslon SSL emitters it is made for are a bit dated now, maybe I will try it with different LEDs.
Thank you, finals went quite good. The next weeks I will be busy with finishing my thesis and it’s defense, but I will hopefully have some time for building stuff. Big Smile
nickelflipper
nickelflipper's picture
Last seen: 2 hours 36 min ago
Love the encoder idea. I went so far as to buy a panasonic 9mm one for a future project, and haven’t got around to implementing any software either. PIC has the 18f4×31 line with hardware QEI module.
Kent
dave_
9mm encoder sounds sweet! My Alps is 12×15mm I think. Not small, but it’s decent quality and only around 1€.
But sadly no pushbutton . . .
QEI hardware interface can certainly be useful! For my manual operated encoder, a slow timer interrupt and a couple of if-then-else style conditional statements will do. Wink
Nothing time critical going on. Only monitoring battery voltage, some buttons and/or an encoder and a timer for the dimming output. The attiny10 sadly has not enough pins for that. I think I don’t have any so8 parts left, so i’ll have to take one of my attiny44. I don’t know much about those Microchip parts, but some of them have really nice specs! Have to try them out some time. Smile
nickelflipper
The price is right on your encoder. Sometimes the hardware modules are overrated Smile . And your right on the load factor, just about any flashlight driver is going to be next to nil.
The form and size of the flashlight is really cool, look forward to the build.
Kent
dave_
Thank you! Smile
If you ever come across your encoder, could you tell me maybe the part number please?
I was looking for a smaller one for a non-flashlight related project some time ago. Smile
nickelflipper
Beg your pardon, it is a Bourns Inc. part no. PEC09-2320F-S0015. Check out the data sheet for all the different options.
Kent
Rufusbduck
That looks like the Ledil Lisa 2 oval. Nice choice for a cap light. Making your iwn driver, priceless.
Scott
Microa
Last seen: 4 hours 30 min ago
Very interesting. I mainly deal with buck driver. I should have a try for LM3410. The Attiny 44 has 8 pins more than SO8 part, what are the fancy ideas to make use of these pins? Look forward to the new progress built.
dave_
@ nickelflipper
Thank you! That encoder looks really great! It has even a metal axle. Smile
@Rufusbduck Thank you. Smile
Yes, looks very much like that Ledil optic. Good eyes! Wink
@Microna
Well, I planned to use an Attiny10 which I have in sot23-6 package. 3 actually useable pins are not enough if I want to use the encoder. So8 would be perfect, but I don’t have any tiny25/45 left unless I want to ripp them out of other projects. But I have a couple of tiny44 here, so I don’t need to order anything. Smile
relic38
relic38's picture
That is the best handmade DFN PCB I’ve ever seen. I would not have even tried it. Good job! Beer
Welcome the night.
dave_
Thank you! Beer
With a >=8 pin package I probably would have gone with dead bug style.
But this was surprisingly easy, just needed a calm hand, a Stanley blade and a couple of minutes. Wink
If you cut in a slight inwards angle, the copper delamiates really easy.
nickelflipper
The tiny84 lines up real nice on the proto board. Who would have thought cutting the pads in half? not me, great job.
Kent
dave_
Thank you! All those 1.27mm pitched packages like sop fit nicely on splitted pads. Speen and noise are no issue in this build, so why not use a piece of prototyping board? Smile
Only a few days left, I hope I can finish the build on sunday, probably just in time. ^^
Rufusbduck
It’s astounding how fast a month goes by when a deadline looms. You guys making your own drivers deserve a separate catagory based on the time you have to spend on it.
Scott
dave_
Yes, time runs quick when you need it the most. Big Smile
I don’t know, doesn’t make a difference to me if the invested time is used for electronics, software or mechanical work.
MRsDNF
MRsDNF's picture
Nice going dave_. I take my hat off to anyone that can solder, especially those miniature weird looking electrical thingys let alone understand what they do.
JohnnyMac
JohnnyMac's picture
Last seen: 1 month 2 days ago
Very cool, Dave! You guys give me so many ideas watching what you come up with for this contest. I really like this little light you came up with. Wink
dave_
@MRsDNF
Thak you!
I always enjoyed soldering. Takes a little bit of practiceing for the small stuff though.
@JohnnyMac
Thank you too! Smile
I will finish the last work tonight.
I hope I can find a dark enough place to test it and make a short video if my phone cam is able to produce anything better than noise with some shapes in it. ^^
relic38
relic38's picture
Great progress Dave, looking forward to seeing the finished light!
Welcome the night.
dave_
Well, time is over now, and it’s more or less done. ^^
I didn’t got enough time today to finish the build as I wanted and additionally busted it a little in the last minutes, but yeah, that’s life. Wink
I even forgot to add a front shot of the completed light, so I’ll do that when the contest is completed.
In conclusion, this was a lot of fun! Smile
I rarely build mechanical things, and if I do, they are usually not made of metal. So I had the chance to learn quite a lot here! (At least that I still have to learn a lot. :P)
I am also pretty sure I never shared anything I built in a forum which makes this also kind of a novelty to me.
It was a lot of fun to read all those build threads and look at all the cool stuff. That alone made it the most fun time I had in a forum for a long long time, thank you all for that! Smile
Rufusbduck
Any chance you could do a thread on how you built your driver? There were parts like the gas guage that I would like to understand more how it’s used and what it does. Right now it’s like watching Bullwinkle say“Watch me pull a rabbit out of my hat”, I see it happen but except for really basic stuff like linear drivers it’s all Greek to me.
I dropped most of the various parts of mine at one time or another but I think if I dropped the whole thing now it would either blow up or make a hole in the floor(it’s really heavy and solid). As with all the other mods in the contest I’ve really enjoyed reading about yours and the thinking that went into it.
Scott
