Nice review.
Which would you recommend out of this and the Sunwayman C15A?
Both look very interesting to me.
Nice review.
In OP it was mentioned “Zebra 14500 and Nitecore NL147 not work with it”. May I ask why? Size problem or other issue? Thank you very much!
Hi
It is a difficult question ; C15A or WK41.
The newest is the WK41, but consider several things.
- Low battery warning light: in Xtar alerts with NiMH, Alkaline. In C15A alerts with 14500.
EDIT: Xtar alerts with NiMH and 14500 (and alkaline and L92)
- Cut to 2.75V battery in Xtar. In sunwayman i do not know.
- Compatibility 14500: In C15A the Nitecore NL147 works well, the 14500 Xtar works well (zebra 14500 not work) … is very compatible. In Wk41 the Nl147 not working, not working Zebra14500, of mine just goes with the XTAR 14500.
- The reflector of the C15A is smooth(more throw), the OP of Xtar more floods.
- Size: the Xtar is lighter and better EDC.
- Interface and sharing modes, better Xtar. Tint is colder in Xtar, in C15A is almost neutral.
For a little, I think I prefer the XTAR WK41. When I have protected 14500 battery that fits well in the Xtar, then be my favorite.
EDIT : VIDEO Sunwayman C15A battery 14500 / Xtar WK41 battery 14500
The problem of “14500 zebra” is that it is “flat button”, and physical protection Xtar is avoiding contact.
About NL147, I’m not sure. I think the size is not the guilty. This is Top Button, but protrudes very little (i think this is the reason). The positive in the Xtar 14500 is the same as in the eneloop or alkalines.
Hey nice review. Good use of text in your pictures.
Thanks for a great review Trevi_lux, very much appreciated
Nice Review! I like that diffuser- I wish every decent light came with one, that was similarly styled. It helps turn them into nice camp lanterns.
Thanks for the video! On a NiMH the 150 lumens seems too low. They should have got it up to atleast 200 lumens
Hi.
True, but they have tried a good balance Lumens-Runtime.
Not a big flashlight to use outdoors, but as EDC is enough.
These 150 Lumens, light as well as 170 Zebra or Sunwayman lumens.
Just wanted to say thank you for the excellent review. I bought one earlier this week specifically because of reading this review and it just arrived today. This is by far the best EDC flashlight I’ve ever owned.
I’ve been using it with the Eneloop XX 2400mah AA, and I wont really get a true opportunity to test it till tonight. But this review hits everything spot on, its small, lightweight. The quality is top notch, one thing I noticed in particular that the threads when removing the battery compartment have INCREDIBLY smooth action. And in event of a zombie apocalypse you’ll have a flashlight that will take any AA battery you find laying around. I may venture to try a 14500 battery at some point but the Eneloop on turbo (4th setting) really does put down a lot of light, so I’m not in any sort of rush.
Two other notes, the Strobe is pretty easy to learn so if you have to use it for self defense; its very accessible with 2 quick taps, and you will hit strobe every-time whether the light is on or off. Also the memory works fantastic too, so if you leave it in high its in high mode when you turn it back on (also great for self defense as well).
Overall this is the best $40.00 i’ve spent in a while. Its probably the most expensive flashlight I’ve bought prior to this I’ve only had crummy nebo & ebay-amazon-generic cree flashlights. And It has absolutely been worth every penny! Xtar has won me over!
The only mild disappointment was the difficulty of finding these, I had to order it on ebay (new), I guess I just get spoiled with ordering with Amazon Prime though!
You’ve been using it a few days. Are you happy with it?, I did not get out of my pocket 8)
Thanks for a terrific review, Trevi_lux. In my country there is a local distributor for Xtar lights and I’ve already ordered the WK40.
However, after reading your review I may have to buy the WK41 as well :8).
I am 99% happy with it, only one pretty minor complaint (see cons)
Pros
Cons
If the C-Clip gives me any trouble aside from what happened already I may try to design one up in CAD to get 3D Printed, maybe something with a screw/set screw based fastner printed in stainless steel. But for now its only fallen off once(which I’m hoping was just an odd unlikely scenario), which I can deal with, its really only a problem if it starts regularly falling off(If that ever happens I’d definitely post an update as well).
Nice review of what looks like very nice light.
Looks like a great light, I want one!
I purchased this light from Mark at MDlightsource a few weeks ago.In my quest for the “perfect” EDC light this has been one of the best I have found.I have been carrying it for about two weeks straight and don’t intend to stop.One thing that this light does well that other AA/14500 lights don’t do well at is to keep the lower modes with a 14500.(Speaking specifically about the Xeno EO3)This light has the same output on the two lower modes with both NiMh and 14500.My favorite EDC lights are now narrowed to the SB S-mini(XP-G) and the Xtar WK41.The advantage of the WK41 is that normal alkaline AA’s are easier to find than charged 18650’s.In a true emergency, the Wk41 will always have a power source.
Thanks a lot for the review! Frontpage’d and Sticky’d.
I hate to sound like the negative nancy here, but I received this light recently and while it’s a decent little AA light it’s not without a few complaints.
Firstly the switch. It is much too small and very very difficult to locate by feel alone. The tiny button sits nearly flush with the surface and its difficult to activate quickly, especially with larger hands and forget about with gloves on. Aligning the pocket clip with the switch helps give some tactile cues as to where to press when it’s pitch black, but its still not very fast or user friendly.
Take the Zebralight SC52 for comparison, it uses a much larger side button which is easier to feel and activate, and then it is recessed so that you can clearly find the button by feel alone very quickly. The pocket clip is bolted in place which means it always helps align you with the button once you get used to it. The same can’t be said for the WK41, although the pocketclip isn’t that big of a deal.
The second issue I have is also related to the switch, but more about the UI and buttons timings. Double clicking to select special modes is fine, however the timing requires you double click the button extremely fast, to the point where I cannot reliably get to the blinks modes. This seems like a bad idea for a feature that may be needed in very dire situations.
Thirdly, and again still on the switch, the amount of time required to turn the light off is annoyingly long at 1.5 seconds. It sounds quick on paper, but in actual EDC use it feels like an eternity, and the thought of waiting on my flashlight is absurd to me. Fenix uses a long click to turn some of their lights off, but their timing seems to be a bit better thought out, or I’m just impatient.
Finally with so many normal modes to cycle through I feel like they missed a real opportunity to do something with a long-click from off, either for momentary on, or direct access to high or some other setting. Cycling through 4 modes to get the one needed is again an exercise in patience with this light, in fact everything about this light feels like it’s testing my patience.
I will give Xtar credit for their beam and tint quality, it is quite good and somewhere between cool and neutral. The beam is fairly floody, and very smooth, a great beam for an EDC light. Support for 14500s from the manufacturer is very welcomed to see, and the low battery indicator is pretty neat, although I haven’t gotten the hang of how many minutes of light are left once it comes on. Overall this isn’t a bad light despite my numerous complaints with it, but I don’t think I would buy it again.
Hello IClight
I think most of your complaints relate to issues that you should know before you buy. Specifications and photos on the web of Xtar are simple and well explained.
If I do not like red cars, and I bought a red car. Is it fair that I’m complaining then “do not really like the color of my car”?. I think I should not have bought the car ….
