C8 addicts thread
got my first c8 the other day, the banggood 8.88 xml t6, and i like it.
its bright, throws well and has usable spill, the only downer is a hollow pill?? star only sits on a small edge so i wouldn’t run it on high for a long time. oh and the next mode memory, i hate it its s frustrating its my first light with it |(
i also have the convoy c8 on the way. im very interested to compare the 2
I have both the C8 from Banggood and the Convoy. You will be much happier with the Convoy. The quality is much better.
for 8 bucks i like it :bigsmile:
i just posted in the bangood 7.99 c8 thread, im interested to see weather yours has a hollow pill and what amps yours pulls on high?
I agree it’s not bad for 8 bucks. The pill is hollow and I pulled the switch out and it looks kinda cheap to me. I tried getting measurements on high and the best I got was .87A but my DMM is a turd from HF so I have no idea if thats acurate.
The XM-L2 U2s finally arrived so I stuck one in direct drive in a C8:
Stock C8 (Ultrafire, XML on Alu board) was ~22K lux (700-750 lumen)
With XM-L2 U2 on copper:
Before de-dome was ~42K lux (1300-1400 lumen?)
After de-dome is ~85K lux
After de-dome without the front lens is ~95K lux
Current reading was ~3.5 amps but probably closer to 4 without the DMM… I will try compare lux readings with and without the MM.
Over 10% is lost due to the front lens alone, time to get some AR coated lenses (99% transmittance) for them I think as well as better switches (shorted the battery and got a puff of smoke from the one I was using)
Will stick up results for the C8 XP-G2 once I get around to piecing it together.
Manual,
When you say direct drive, meaning VBat+ on LED+ and VBat- on LED-?
and wow! 42K, 85K and 95K lux! Is that 1 meter to a Lux meter readings?
:beer:
Yip… other then the switch and contact board the battery is connected strait to the LED. Measurements were taken at 4.56m so multiplied by 20.8 to give lux @ 1m.
I've gotten about 100 kcd on a full mod'ed C8 (XM-L2 U2 de-domed, Nanjg driver w/extra 7135's), and up to 142 kcd with a de-domed XP-G2.
Did anyone noticed this:
UltraFire C8 SST-50
wow. u doing any custom work again? :slight_smile:
I'm trying to catch up - still got a TN31 and 3 Shockers to do, not to mention so many of my own lights/projects... The magic #'s are at or close to 100 kcd for C8 class, and at or class to 200 kcd for HD2010/SS T08 class lights. It's been pretty consistent like this for the full set of mods -- maybe 95-100 or 190-210.
I don’t think there’s any point to that esp considering the cost, the XML2 is brighter for any given drive current.
The LM XML2 U2 and xintd XML2 U2 are both brighter than my 6P with DD SST90.
cool - thats fine i wont have money for about 3 weeks anyways hehe… that hd2010 200k mod sounds cool too
Littte off topic, here's the last HD2010 I did, and I'm thinking, if this was a U2 1A from KD, these #'s could have been better with a real U2 1A or 1C. Wish I had tracked vendor sources of the LED's to the lights I built...
lumens: 1,149 at start, 1,125 at 30 secs, throw: 200 kcd (894 meters) — all on a fresh KK ICR 4000 cell
It just barely made 200 kcd measured at 4.3 meters, so may be 205-210 kcd if measured from a longer distance of 10-15 meters. I think it came out pretty well, really right there where I expected. The light’s body is clean and I like the look in black. Summary of mods:
- UCL/p lens
- XM-L2 U2 1A de-domed on a 20mm Noctigon copper star
- Nanjg 2.8A, added 4 7135’s to bring it up to 4.2A
- 3 copper discs of 18 gauge, 5/8” diameter added for heat sinking to the pill
- brass ring added for mounting the driver, press fit in, dremel’ed the pill to fit
- both + and – springs wired with copper to reduce resistance
- Nyogel on threads, special pricey thermal conductive grease used on pill threads
  • Please note the pill is intentionally loose – if it’s full tightened, the emitter sits too far out of the reflector, resulting in much lower #‘s. So if for whatever reason you need to take it apart in the future, count how many turns it takes to tighten the pill down, and re-seat it the same way. Though it’s not tightended down (screwed from the reflector side), the reflectorr sits on it very tightly — must keep the bezel tightened well, and with the expensive grease, both thermal and electrical conection to the pill is strong.
From the owner:
Tom, my flashlight came in on Friday but I didn’t get to play with it until sunday night when I got back home from vacationing with the family and man am I impressed! THIS THING IS INSANE! I think I told you before that I have an LED maglite, and I thought that thing had some power, NO SIR. This HD is FREAKING UNREAL! And talk about how great the flashlight looks just sitting there. Man I am blown away! I honestly didn’t expect this thing to be that powerful.
I played around with the modes and you were right; I really like them. The cycle through is cool with the half click, or if i cycle full clicks fast, but has memory to where if i let it sit for a while, itll stay on the last mode I had it on.
cool! pm sent about the hd2010
the only c8 i have right now is the supfire x5 which i swapped the emitter to a nice xml2 t4 80 cri… it still has the stock driver which gets around 2.2-2.5 amps on high… dont think having a 3 amp driver would make a huge difference, but it would eliminate the strobe modes
been debating the new c8 v4 from intl outdoor for a while now
K - can't go wrong with a XinTD C8 v4 - I got one stock, and an older v2 mod'ed. The X5 I mod'ed was sold/traded, and actually I got a stock one - sitting, waiting for another mod...
i just got the x3 today i think it needs a v4 c8 for a buddy lol.
I got the X3 too, so it has twin brothers . I'm really liking the warm tint of the 6A1, but I'm think'n it's a real nice little thrower as well, so want to beef it up - the kcd # was pretty impressive, considering it's a T3 on alum and at 3 amps.
i went with the cool white myself on the x3
i just ordered a c8 v4 with the t4 80 cri :slight_smile:
I’ve got to get me a hd2010 to play with……more to the point, I need to have a play with my light meter, want to see what my l2 is doing before I go full retard on it and its twin…….
I too got an x3 hi cri……mrs gords loves it as a bedside/spotting light, its the first one she’s taken an interest in, guess she’s a tint/hi cri snob, who knew? I’m now wanting to get “her” an xintd c8 v4 same driver/emitter as the x3, I’ve put it off for too long.
Worryingly, I have a supfire m6 inbound, I’m already looking at hi cri xp-g2’s on copper for it, I figure a doctor Jones driver and two 3.1a slaves to match should be good in there……I’ve not even got the damned light in my hands and I’m already modding it lol. And that’s ignoring the small pile of cheap lights I already have to mod, this place is a bad influence lol
