Yes. A sphere means the light is spread evenly across the inside. So unless the ball is tiny or it's a massively bright light, it's more than enough.
Thanks
If you had to choose. think it really matters?
If you're planning on building a sphere like I did, I'd go with the Mastech simply because it'll make it easier to mount.
They're actually both mastech. I have orange trim one and it works really well. The "head" on it is smaller and more precise than the other one.
thanks guys, i went with the one with the smaller sensor. Measures higher, even though I dont need it really, has a smaller sensor so I could make a smaller baffle. most importantly it has the ring around the sensor for easier press fitting. wouldnt have thought of that
Happy to have helped. Let us know how your I.S. turns out.
The guy who invented paper mâché. What was his problem?
The paper mâché ball is going well. I have no idea how many coats I have on it. The first few coats I used wallpaper paste because I had some. I didn’t read match’s OP real close the first time I guess and now I see that is what he used first. So I really am following his directions exactly. I think I put too many layers on at once in the beginning. I’m not sure the inner layers are completely dry. After the first layers with wallpaper paste I switched to the 50/50 mix Match used. It’s going good. These layers are drying faster. I have no idea how many layers are on there but it’s getting pretty solid. When I cut it open the those inner layers can dry if they are not already. It has been cold here, if I could let it bake in the sun I could go faster I think. Bottom line is it’s going good. Nice project for the kids to help with also.
The lux meter is coming from amazon and should be here real soon. Great project, can’t wait to achieve my new level of geekdom.
Gotta think about paint jobs also. That will be special , I promise.
Nice work, Langcjl. Keep us updated on how it turns out. The good thing about using the wallpaper glue first is that it contains an anti-fungal agent in it, which will prevent the project from molding before it's complete. As far as the number of layers, I lost count. I just kept adding, then performing a "squeeze" test the next morning. Once I was no longer able to squeeze and feel the ball underneath, I called it good (no need to squeeze too hard though).
I don't think I've asked before...what part of Wisconsin are you in?
Match, I’m in the southern part below Madison. Right in the middle of the huge cornfield.
Very nice. My folks are near the Twin Cities, and I still head over to River Falls/Ellsworth every now and then to visit some old friends.
Okay Lang, I hope you're happy - you did it again. I just ordered this meter for use in my upcoming Match inspired IS project. Now, off to the drug store to find a bouncy ball. This project will remove all doubt from those around me about my being a worthy candidate for some type of institutional psychological rehabilitation.
Foy
We knew you would come around soon.
I finally cut the ball apart. It was pretty cool when I punctured the ball. I used kitchen plastic wrap and that worked nicely. No sticking or anything. I used a hole saw to cut the holes. I made the flashlight hole as big as my SF Masterpiece because it is the biggest one I have. For the Lux meter hole I only made a 2cm because I don't know how big the sensor will be. Hopefully it will come in the mail today. Match, how did you cut your holes? I used a hole saw but don't know how I am going to fine tune the sensor hole. I tried a sanding bit and a stone grinding bit on the dremel but they didn't do anything. Maybe the hole I already made will be perfect. It could happen.
http://www.lightglassoptics.com/Newport-819-IS-2-Integrating-Sphere--2-inch_p_709.html
$1100 for a two inch lab grade one!
And the detectors (meters) are expensive!
Looking very nice, Lang! I cut and trimmed my holes using a very sharp razor blade.
The only light I have that has a known lumen value is the UF 3 mode dropin. I know these values from Matches numbers.
Using my lux numbers
H 3600 lux
M 1250
L 210
And Matches lumen numbers
H 838
M 280
L 49
I came up with correction factors of
H 4.30
M 4.46
L 4.28
So if I take the 3600 lux reading and divide by 4.35 I get 827 lumen.
After I figured all of this out I remeasured the high and kept getting 3800 lux. I’ll have to do more measurements and figure it out better.
Using the numbers I have now, I measured the SF Masterpiece pro1 with one cell @ 202 lumens which seems spot on to me.
ITP EOS A3 XP-G R5 w/10440 333 lumen
XR-E Q5 14500 252 lumen
These seem pretty close with the Cree charts, a bit high maybe.I think I’m going in the right direction. I know I was a bit off on my initial figures, I get hyper sometimes, so I’ll go back now and try to refine things.
If I’m doing it all wrong, let me know
Just tested the Tmart 502B Q5 AK47A driver @ 223 lumen. The Cree charts show 233-251 @1A
It looks like my 202 reading for the Masterpiece is in line with what this review reports http://www.lumensreview.com/reviews/1-led-flashlights/104-solarforce-masterpiece-pro-i-review.html It says aprox 200 with 1 cell and I got 202. By the way, have I reported how sweet the Masterpiece is? It is.
Looking good, Lang. I'd definitely say you're on the right track. I used both of my zebra's (H51 and SC60) since they've been tested out the wazoo and seem quite repetitive. My only concern with using the UF 3mode xml drop-in is that the high isn't current regulated, and dependent on the battery quality.
Your right about that P60 Match. I think I got lucky with the one I started with. I tested a couple of others and got different readings. It is very battery dependent. Everything seems to match up now with the two lights I have good numbers for.
This has been a great project. It’s so much fun to play with. Thanks for sharing this one Match.
All I have to do now is the final paint job.
