A lot of people will find this review interesting. I used to buy generic plain jacketed cells from eBay out of Hong Kong that were sold as OEM Primary Lithium Energizers and cost about a dollar each. I was dubious but bought a few and when they arrived weighed them, and then ran them in a few devices of varying current draw. Their weight was the same at 14.8g, and their capacity seemed to be the same, so ended up buying hundreds of them, and they performed like regular energizers in the field. Then more than a year ago, they disappeared. I tried Google to see why, thinking perhaps they moved their production plant to another location, etc., but never did find out why.
I have a couple of devices that perform better with the higher voltage primary lithium cells provide - such as a VHF Radio with double AA cell battery pack that needs the higher voltage to produce 5 watts, and a Spark SD52 headlamp that needs it to support Turbo mode. Plus avalanche transceivers that need cold weather ability. So while these may cost a little more than a buck, and they are not quite up to the Eveready’s performance, I’m sure lots of people will be happy to see an alternative souce of AA Lithium Primary cells like this available again.
I like this battery and will probably replace some AA eneloop and alkaline batteries with it, in my less used lights. This will reduce the risk of leaking alkaline and give me a pile of eneloop to use in my new lights.
