Just checked…most of the dome came off with some residual left…but the gas had evaporated who knows how long ago. Put some more gas in there to soak off the leftovers.
And thanks, mfrey, that DS-2025 looks like it was made for dedoming. Let us know what happens!
Well the Defiant 2AA light was a semi-successful dedome. It came off but the light it puts out in VERY blue. However, it still works!
Buoyed by the sweet scent of near-accomplishment (and LOTS of gasoline smell) I decided to dedome my S5 Convoy w/XML U2 1B emitter. After slicing into the dome then soaking in gas for 4 hours the dome fell off with just a touch from my fingernail. Next it went into a bath of rubbing alcohol for a while with some swishing around mixed in there for good measure. Then it hung by a ziptie to dry for an hour or so. Before pushing it back into the pill I put some Fujik-like white stuff behind the board…probably way too much, it came out around the edge and made a bit of a mess!
Anyway, after reassembly the darned thing WORKed! The beam was much warmer in color and narrower, with a tiny bit of a donut shape to the hotspot. Upon ‘testing’, which involved visually comparing it to another S5 that has the same 2.8A driver and an XML2 U2 1B in it, it doesn’t seem to throw any farther and puts out noticeably less lumens.
Any ideas on how to improve it from here? I assume the presence of the donut means the focus is a bit off…how should I attempt to rectify this? It has a SMO reflector in it. I’m a little disappointed that it didn’t do much for the throw, I knew it would lose some lumens and warm the beam tint up a bit. I tried spacing the emitter back a little and it didn’t seem to help.
Thanks to Tom E. and everyone else who has posted their results here!
Thanks for the reply Tom. I figured it must be the loss of the phosphor on the one that went blue. I have no idea what kind of emitter is in those 2AA Defiants….XB-D maybe?
Yes, the center was a little darker than the rest of the hotspot on the other one. How in the heck do you get the emitter farther in the reflector?
Does the S5 reflector have that lip around the base? If so that will bottom out against the pill and thinner insulators won't actually change the focus any. Trim that lip off and it'll start responding to different thickness spacers.
LOL, I use tin snips. Cuts much easier than you'd think. Needs only very little cleanup with a file afterwards to knock off the sharp edge, the whole thing doesn't have to be filed down perfectly smooth.
I tried to dedome a dead xm-l in gas for about 16h, but it failed. I hanged the star sideways in the glass, i thought the dome will slip off by the gravity. It actually worked, but a lot of silicone remained near the wires. I tried to remove, but i broke the wires.
Is there a way to trick out that situation? Dissolve the silicone, or anything? Because i think if i do the same thing again it will also broke, and it is a bit pricey to waste the xm-ls to me.
Oh boy - I got a ton of XML T6's laying around, all from upgrade mods. I always do it on a dis-connected board though, never wired. I use a toothpick now with a 20x lighted magnifier to clean up the silicone, but I won't try for 100% around the wires. You have to use something soft with a magnifier, even then, I don't take the risk getting too close to the wires. Very important though to have good visibility.
For “wires” i meant those hair-thin copper wires on the led die. Mine is also disconnected. The problem was that a silicone chunk that remained on the die with the copper wires in it were loose, so i thought it released the wores, i could simply push it away from the led.
I burned up an XM-L (& driver) while bench testing a driver recently (thanks to RaceR86! - just kidding man) and so I was about to toss it in the trash when I had this idea to try and dedome it by soaking it in gas. I had not brushed up on the technical details on what to do and didn't have time to so I just threw it in a plastic cap with some gas and set it aside (cap was about 1 inch wide and 1 inch tall and I only put about 1/4 to 1/2 inch of gas in it). I checked on it every now and then and finally plucked it out about 2 hours later. The dome just fell off and it looked fairly clean. I then doused it with some rubbing alcohol to rinse it. I did try applying power to it to see if the gasoline brought it back to life, but no such luck . I'm sure if this LED had been a working one I would have failed.
Do we have a guide as to how far tint shifts based on the tint you start with before dedoming? I know generally speaking that dedoming will move you to a warmer tint, but how far? What is the "best" cool white tint to start with so as to end up near a nice neutral white tint (i.e. 4C tint)? Start with a 1C? 1A? Or is it not this simple?
I saw a nice post of maybe 3 different tints, and their resulting de-domed tints - not sure where this was. I like the 0D and 1A's de-domed - 1A turns neutral but not too much yellow - much like a 3C or little less. 1C's definite more yellow, I'd say more so than a 3C. I accidentally de-domed a 3C and wow - ton of yellow but looked nothing like the T3 6A1 and T4 warms I've seen - the de-domed 3C was much more yellow than the warm tints, in fact the warm tints seem to me to be more of a true pale white while the 3C is more yellow.
Well thanks to RaceR86 i know that de doming of cold white emitter(6500) upper neutral white color appears(around 4800) which has little greenish tint visible in aspheric and not so visible in reflector. This de-domed tint looks much better to me than cool white but don’t ask me; you decide.
Guys if you are not familiar with tint colors it looks something like this:
I would say its beneficial to start with 1A/1D instead of 1B/C.
On the tint chart, most emitters seem to end up 1300-2100K to the left, and then some up (towards the green/yellow spectrum) You will not end up with anything as nice as a 4C no matter where you start in the CW range.. A 2A would probably get you "close" to a 4C in terms of temperature. But it could still not compete in color rendition or color tone IMO. I have not measured this stuff, so I dont have hard factual numbers. I have seen texaspyro show some stuff on temperature change, but I have never seen any numbers on color tone.
Luminarium, your are learning. :) Although the pictures you are showing are for describing temperature (kelvin), not hue.
:and again mounted in an identical DD zoomie, I got the green tint… everso slight on zoomed in mode (again a nice sharp die image), but quite visible on flood!
