DenBarrett certainly shows the proof and then some. It’s a FandyFire UV-S5 (SRK clone) mated to a polished Defiant Super Thrower (DST) head. Remove that o-ring and it looks like it could be almost factory.
Now who’s capable of making this thing sing? I mean you know, there’s only 4 x 18650’s in that tube. :bigsmile:
This is a little tuffer. It will run off a 26500 if you bore out the tail cap and side clicky housing a bit otherwise a 18500 with a sleeve goes in without boring. OAL is coincidentally to the Fandy/DST is also just
6 1/2”.
Feels really great in the hands which IMO is helped by the side clicky. Everyone that picks this up goes, Ooooooooooooh!!!
Yup, he nailed it. Almost. It’s a 5C. So all ya gotta do is somehow find a 5C Defiant that can actually be taken apart from the tube and then just thread the tail cap to the side clicky part which threads perfectly. And voila! You now have a compact little blaster. Especially de-domed. :bigsmile:
Most of the 5C Defiants btw are stuck together with nitro glue.
I had an unfair advantage. You recommended that combo here. I remember because I purchased the SG-R13 on that recommendation. I have not performed the recombination yet though.
