Just email Hank Wang (intloutdoor@gmail.com). He’ll let you know.
Lightmall So how about the lightmalls 17mm 5a 3 mode driver? If the specs are credible then this appears useable on a P-60… Has anyone tried this version? Also if I wired the LED’s in parallel would this driver work on a triple XPG?
Those look suspiciously like the junk left over from a failed attempt at flagrant deception by lightmalls. Of the two samples I tested with 3 x 18650 in parallel (4.20V), dedomed XM-L2 on sinkpad, 18ga wire, I get about 3.3A to the emitter. Lowest setting barley illuminated the LED so its completely useless. Mode changes requires very fast half-click button presses to get it to change. Extremely poor regulation where amps began to plummet around 4.05V.
Should work with a triple xpg if wired parallel. The driver appears to be a buck or just direct drive when the supply voltage drops below the vf of the led at 5amps. Notice what it says “Constant current output when the voltage is higher than the LED VF value”. Wouldn’t be much different if you just used direct drive, like the east 92 driver with a single 4.2v cell.
If you used a XM-L2 on a copper sink pad at 5 amps the vf would be around 3.75v. Emitter Test Results pt4: XML2, XP-E2, XP-G2, and Nichia219! (along with sinkpad tests)
If you used a Panasonic 3400mah or a sanyo 2600mah the voltage would sag below the vf of the led at 5 amps in under a minute. Then it would be basically direct drive after that point. Battery test-review 18650 comparator
A 18650 IMR wouldn’t even be able to sustain 5 amps for very long. A XM-l on copper will stay in regulation longer, maybe around 10 minutes at 5 amps, just a guess.
Thanks Flashpilot and 007. Good information. Sounds like you guys think the 92 River driver is much better and I need to shop for some batteries. Thanks again for the info and links.
I bought a few from LCK LED a while back, ordered the 5a version. They came with large torroids, went to use one on the weekend, only put out 3a @ emmitter bench testing. It had 2 r200 sense resistors, so I added 2 r100 & it showed 7.something amps briefly before the xml popped. Removed an r100, & it tested @ 5a.
So, FMC, pretend I know mostly nothing about chips and components how do I identify those little buggers and do the same thing you did? I can solder passably but the identification of the components… I fall short.
I think you got the wrong driver, was it this one being discussed.
http://www.lightmalls.com/4-2v-single-lithium-5a-3-mode-led-driver-boar-cree-xm-l-t6-u2-sst50-mce-ss-p7-5-pack
We are still on the topic from here correct, maybe I’am lost. :~
Sorry to muddy the waters…. I was referring to the FL 2 from LCK LED that was in the OP.
I can post up a few pics if you like, but it’s been covered in a few other threads already.
Nanjg and stacking 7135’s is doable… It’s a bummer the Lightmall’s driver isn’t any good is a downer. I would like to put together a P-60 sized light pushing an XML at 5 amps on high preferably without stacking 7135’s. Any suggestions?
what about this Nanjg 105c with 16* AMC7135 ?
am i correct or this one cant handle 16* AMC7135 ?
Yep any 7135 based driver can deal with having more chips stacked on top, they’re all running in parallel. The only real limit ends up being in terms of heatsinking since linear regulators burn off excess voltage to do their regulation. It’s best to look at them like a smart variable resistor that can also be turned off and on rapidly (via PWM) for lower modes.
They can get quite hot when regulating on a freshly charged battery, and the more you stack the more heat you need to get off that tiny 17mm board.
Stacking is probably going to be the best way to get 5A in a p60 from a single cell. It’s not too hard once you get some practice in.
Or you could look at something like that East 092 direct drive driver mentioned earlier in the thread, if you can still find a good one at least.
Ok, that was what I thought regarding 7135 stacking. The East 92 is a crapshoot right? Could get a good one or a bad one but won’t know until you hook it up?
I honestly wouldn’t know, I only have one working one left sitting here from my HD2010s. But the ones I’ve seen have all been direct drive on high.
Haven’t ever had the urge to order any more so I wasn’t aware of there being bad batches till reading it here. It’s an ok DD driver without PWM flicker, but the blinkies got on my nerves!
I find it preferable to just stack 7135s until it’s basically direct drive but I know it can be a pain.
I would imagine there’s probably quite a few out there going unused maybe ask in the WTB if anyone has a spare they’d be willing to send you.
5 amps is hard to achieve with a XML2 in a single cell light. You would need a buck boost driver to sustain regulation, that doesn’t exist with that current output. You are basically running direct drive after the first minute unless you use a IMR cell and even then it may only extend regulation for 10 minutes or so. If driver modes with 5 amps direct drive is what you are after then use a amc7135 driver with 15 total amc7135’s. No matter which single cell driver you use, your not going to get much more than 5 amps at the led for any length of time. Use 2 li-ions and a buck driver and its a whole different ball game.
I got target fixation. Focused on the amps and did not notice all the silly blinkies. Thanks for pointing that out! My biggest dislikes in lights PWM and blinkie modes or more than 3 modes. The search goes on…
007 what would you suggest. I’m after a small form factor, 2 18350 IMR’s or maybe even 3 of them in a Solarforce L2M, a copper P-60 and which driver? They all seem to be greater than 20 mm in diameter. Thanks for all the input guys. I feel like the more I learn just shows me how very much more I don’t know.
This is about it as far as I know that might be small enough to fit. Sense resistor mod to KD Super Output P7 Driver
Its 19mm diameter, I have no idea if it will fit a P60 pill, may need some lathe work. I’am sure someone here has tried it though.
The KD driver with 2 li-ions will give you regulation through out the run time but not at 5 amps. You could do the resistor mod to gain more than stock.
If you run a single cell with a 15-amc7135 driver, you should hit 5 amps for a minute or so but it will reduce in output gradually until the battery is depleted. The main problem with the P60 is the size of driver that it will except and the heat it can get rid of. If there was enough space for a bigger driver you would have several more options. The P60 may not be able to cope with the heat from over driving a XML2 for any length of time either. Just trying to help in weighing your options and what to expect.
Thank you very much, will attack the L2M with a micrometer now.
You’ll find it’s trade-offs all over the place with flashlight modding
If it were me wanting to make a crazy bright 5A p60 I’d go the simple route, 7135s and a solid IMR cell and enjoy the fun while it lasts. The host will heat up to silly levels really fast anyway so personally I wouldn’t worry too much about extended regulation at that level of output. You’ll probably lose more lumens through heat sag in that period than from battery depletion.
But if you do build one using that driver linked by 007, boosted to over 3A and powered by 2 18350s I’ll be keen to see the results!
Good luck.
