MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
It’s not like I’m on a different continent. Look up, I’m right over your head.
Ouchyfoot, your’e on Mars! What do mean, continent? With customs, you may as well be on another planet! lol
Gah, wish I could afford a big box of 20Rs... :~
(BTW, that pricing schedule requires far too much poking at a calculator, might be better to list it by quantity = price each so the math is easier) :glasses:
If you can ship to Canada, I’ll be ordering a substantial batch today.
It gets bloody dark up here this time of year!
Actually, we have a free trade agreement. If customs does check it, which is rare, I only have to pay HST tax, which I’d have to pay anyway if I bought them just down the street.
Hey guys, looks like I can’t ship to Canada using USPS unless they are shipped inside of a device. I will be working on a solution to that problem. Looks like you can ship I am also looking into UPS, Fedex, etc. but it sounds like they have been charging too much for customs services.
comfychair, thanks for the feedback. I will update the OP and pricing schedule to reflect the overall price/cell breakdown.
Oh come on Comfy, you’re freakin brilliant, what’s a little math? Even I can keep a running total in my head as I go down that list. :wink: (Ok, in all fairness, I chose the groups with even numbers, 20+20=40) :stuck_out_tongue:
Will you accept delivery by slingshot or trebuchet?
Canadian, devout catapult most likely. :stuck_out_tongue:
It’s funny. USPS will deliver cells within the US, but not to Canada, even though we don’t have any laws against them and Canada post has no bans. Packets go to border hubs like JFK and Chicago, and then are trucked accross the border so no planes are involved. After 911 both post offices discovered that was cheaper and faster to send mail by truck than it was by air.
You’re talking government bureaucrats, nothing is supposed to make sense. They figured out long ago the best, most devious ways to waste taxpayer dollars.
The biggest problem with the government is the lack of transparency.
This means problems only surface when they are simply too big to hide, and smaller problems are left to fester. Further it leads to a complete lack of accountability.
You can rest assured that the money is not wasted. It is safely deposited in bank accounts. Whether it actually ever re-enters the economy (in so far as 99% of the population is concerned) is another question altogether.
Please stop, before this ends up in chemtrails/gold standard/ALEX JONES!!!!1!111 territory.
What’s the best way to ensure ground between the copper pill and ground ring on the driver? I’ve not had much luck soldering between the large copper pill and that narrow brass trace on the driver. Is there an easy way to do that to ensure a good solid ground? I’m actually thinking about getting a drill bit and tap to put a screw into that wide lip, use a piece of brass to clamp the driver down with it. Would that work?
Here’s a method I sometimes use on P60s.
I don’t have as much experience as many of you here, but I’ve had good luck using 60/40 vs. 63/37 solder and turning the temperature down a bit on my iron after adhering the initial solder to the star and outer ring. It seems like the 60/40 is easier to form bridges with; I’m assuming that it’s because of the increased plasticity range vs. 63/37 eutectic but you know what they say about assumptions! :stuck_out_tongue:
This was done with 60/40 solder (don’t mind the extra flux):
The joint may not be ideal (perhaps a bit cold) but it seems to be stuck on there well and it’s not a high current joint anyways.
I just realized that I misread your question when I posted earlier. I have also used a little bit of solder wick to fill that gap when needed, although usually if it’s just a hairline gap 60/40 and a little work usually get it done for me. In my very limited experience I’ve found that 63/37 is much harder to bridge gaps with.
Can you get the driver without low voltage warning/shut-off for use in non-Li-ion lights?
Ordered some 20Rs, gotta see how they compare to the 4.3v 28As...
All it takes is removing the resistor at R2 (marked '4701'). Since RMM offers an add/remove 7135s service I think that would be well within his capabilities. :)
Not at the moment, but I know that the program can be altered to remove this function. Is there much demand for this? I know that lifepo users might find this handy, I guess that it might also be useful to drain the last bit of juice out of NiMh and Alkaline batteries.
