Can't mix the $4 coupon with the other discount codes mentioned in this thread?
If so, I might look into buying a xintd x3
It’s not same with IO’s XinTD X3, may be same with Wallbuys’s.
Now you're mentioning that, anybody has both? How are they compared quality wise?
what’s different? i ordered 2 from wallbuys groupbuy, but haven’t received them yet, and i don’t have IO’s to compare to anyway…
the only difference I see in the pictures at io website is the 3AA carrier.
At least the driver is different. From wallbuys supposed to be Nanjg driver not Qlite like IO’s.
About the quality I can’t compare because not order wallbuys’s Xintd.
Thats true, but for most of us, that wouldnt be too much of a problem to buy the same driver from Intl Outdoor, and change them.
That’s true too, but I think this comment about Xintd C8 interesting,
https://budgetlightforum.com/t/-/21872#comment-477762
“She informed me that apparently XinTD is not a registered brand in China and as such I take it anyone can slap that brand onto a light. So essentially XinTD does seem like the new ultrafire.”
So I prefer wait for someone that have both version and willing to make comparison if want to buy the other version
I see your point, but at the same time for $30 (after the $4 Christmas coupon) it seems to be a good price...
(off topic: the christmas coupon can be won on their website.. almost everybody wins)
So what are the principal differences between the two drivers for somebody who will just use this light stock from the factory?
I got one of those lights. A solid 3.A on high. The beam is absolutely immaculate. I like it so much, I’m not even going to mod it.
Ouchyfoot.. which one? from Intl outdoor or the wallbuys one?
Wallbuys! I’m very happy with it. Hi-med-lo.(no PWM)The blinkies are hidden in a different mode level. It has an eight chip NANJG driver. Qlites are great if you want moonlight mode, if not, who cares. The reflector does not screw into the head, but unless your running at 5A, I don’t think it’s needed for heat management at 3A.
My personal theory is, if the reflector is screwed directly into the pill…great. If it’s screwed into the head itself, then my theory is that the pill moves the heat to the head for dispersal. With the reflector screwed into the head, it will absorb heat from the head, and move it back inside the light. That’s just my personal theory.
Thanks Ouchyfoot..
Now I`m really considering getting one..But I think I should first clean up a few that I have no use for....
About the same with different firmware, standard Nanjg without option for moonlight mode.
For firmware, there is this Nlite version.
Sorry, is this referring to Wallbuys’s XinTD C8 or XinTD X3?
I am confused as well.....
Wallbuys’s XinTD C8
What about these stainless steel light? I don’t like the 3AAA compatibility but I like the side switch…
I won a 4$ coupon :bigsmile:
But as it is not suitable for the sales items it is a bit useless to me…
I would order the baton for 14$(Instead 12.60$ with coupon) and buy for 6$(respectively 7.40:money_mouth_face: more a item what then would only cost 2$(or 3.40:money_mouth_face: more…
Any recommendations for a 6$ item?
Looks horrible
Yeah you are probably right, so I just ordered one ugly light I don’t need in this order:the extendable baton. Along with some fimo canes I will gift away.
I used my coupon so it was not much more…
The coupon was: 5b9870
4$ of 20$ order or more, not sure if it is a universal code…
