Great review! Is there a difference between the diameter of the reflector between the L2T and L2,L2P? The L2T looks to have a deeper reflector. How about the "tactical" grip , is it rubber or aluminum? Removable? Since it has a matte finish, time will tell if it will be durable.
Grip ring is rubber .. Being rubber it should be removable , but this one fits my hands well .
Takes a standard P60 drop in .
The head is the same length as the L2P , but the bezel makes it look deeper , in one of the pictures , I have it less the bezel ring [pic9]
Ah.. that changes things. I would like it a lot more without the grip. I thought it was machined aluminum.
I like the idea of a forward clicky, but I don't like the protruding switch boot. That was the standard switch?
The story here has to be the fwd clicky w/ mode dropins. Must select mode first before turning on.
Yes sorry folks , the grip ring is very well color matched , the clicky on the L2T is standard forward switch .
A normal L2 is reverse clicky .. Im not sure if you can buy the L2T with anything else but the forward clicky , you may need to mod it if you want reverse .
Though using a forward clicky is no real issue , except changing modes takes a little more work .
Can you check if the switch circuit in the tail is the same as the l2? SF will sell you one for $2, I found out because I burned one by putting the battery backwards.
Also, is the coating HA-2/3? Ie, is it scratchproof?
I have been waiting for someone to get their hands on one of these. I think it looks real nice. I have to find a good holster, it doesn’t look like it will fit in the open holsters I use.
Anodizing ? Feels more like it were parkarised , anyhow , Solarforce description .
L2T
The L2 Series has been becoming more and more popular in the public market since it first production. In view of this, Solarforce now provides users with our newest model of the L2 Series �V L2T. In addition to the remarkable features of flexibility and wide-application of the L2 Series, the design of L2T is a combination of style and practical nature. The L2T bodies are mainly constructed of precisely CNC-ed aluminum alloy and consisted of head, battery tube and tail-cap switch as its major parts. Users may install various high-efficiency bulb modules and / or accessories to the L2T depending on their needs.
Specifications and Features:
- Consisted of head assembly, battery tube and tail-cap switch (bulb modules are not included), which are replaceable and compatible with Solarforce accessories designed for the L-Series
- Body constructed mainly of T6061 T6 aluminum alloy
- Compatible with various Solarforce LED and xenon bulb modules
- Forward click tail-cap switch
- Colour: black
- Uses two CR123A or 16340, or one 18650 battery by default
- Standard tail-cap click switch
- Water-proof design
- Size (length x head diameter x battery tube diameter): 136 x 32 x 25.4mm
- Weight: 87g (excluding drop-in modules and batteries)
Looks good, mine came also today, but I wasn't around....so need to wait till tomorrow morning to collect it from the post office.
I love the look of that new head more than any of the others as well as that awesome matte finish it has! If the body was knurled like the others but with that matte finish it would be so pimp. I think it would make me consider getting my first SolarForce light.
A Solarforce review not made by Foy?? Ok, the world is changing...
Good review old4570!
I asked the same question a few days ago on facebook and tehy wrote HA-2.
Great review old4570, swaying me more towards the order button every second! Love the look of that head!
Excellent review, Matt ;) I like this new model. Waiting tailstand version :p
My L2 are pretty much scratch proof. Unless you put them in your pocket for weeks and run around with keys beside them. So not too much worries.
Nice review, Old4570. I like this one in particular because they've done away with that awful hex-nut anti-roll ring on the head. May have to try one.
You mean the surface material? Mine gets worn down, not a huge deal but ha-iii is obviously "better".
Type-2 it is , I just got a reply from Solarforce ...
you made me buy it!
My HA stuff flakes....even for Dereelight quality, but its really a very minor flake, usually its at the edges.
The guys at CPF says that only the top few lights have HA that are good enough not to flake, their Fenix etc all flake to a certain degree with hard usage.
But seriously, this type II surface really has a confidence inspiring surface, more so than my L2P / L2X.
