Those batteries are not good and that charger is not safe. Pick up some Sanyo 840mah 14500 batteries and a real charger.
-Jamie M.
-Jamie M.
Many of the cheap lights have high losses in the case connections.
What kind of leads have half an ohm of resistance? Seems really high, but I haven’t measured any.
I would not put Lion batteries into the hands of anybody that needed good ones. Yes the output is much higher, but Eneloops do fine and have no risk. I use cheap ones, and monitor the charging on a cheap B6 and pay attention to drooping output when in use. I don’t feel all the comfortable using Lion and maybe for now that is how it should be.
GF glovebox light, premium Alkaline or Eneloops, would be my choice.
Ceiling bounce comparison with my three seem fairly similar on high. Maybe you got some bad lights?
My view buy several from several vendors, compare them and only gift the best ones.
I just received this one: http://www.aliexpress.com/item/Upgrade-800Lumens-9W-CREE-XM-L-T6-Mini-LED-Torch-Focus-Zoom-Flashlight-Free-Shipping/997633297.html
OMG bright! Uses XML T6 led, way brighter than all my other SK68’s!!! Super nice having three modes too
My digital camera (Canon T2i with hacked Magic Lantern firmware) says the XML is 21% brighter than my brightest XRE Q5 I own!
LED:
Beam:
Brightest XRE Q5 SK68 I have:
The only kind of rings I like are Onion Rings
-Jamie M.
and I thought my sk68 cheapie was ringy.
the XML definitely looks better.
I have one XM-L SK68 I bought already modified and a warm XM-L2 that I switched into one. Better flood at the expense of throw. The total light output depends more than anything else on the current, which varies especially with three modes. I have a lithium ion only driver on order.
I just got an “SK58” from TOTO88 | Bocoran Slot Gacor Hari Ini . The knurling is much deeper than on my other three. Only the one with the Osram led actually said Sipik on it. Otherwise similar, so I like this one best. Maybe I will switch a three mode driver pill into it. The XR-E upgraded SK58s are intermediate in size between the SK68s and the 3-mode Zoom AA/1450 EXPIRED ! "Black" $1.99 Max 3ea slim zoomy. The light output is closer to the 68, because the head and lens diameters are nearly as large, but of course nothing else AA has the 68’s heat sinking ability.
Added: The swap didn’t work. The locations of the led in the pill and the locations of the lens in the bezel are different. Also the new one has the slide friction spring on the body, while the old one has it on the pill. The focus was off and the slide friction was wrong.
The knurling on the head on my example is much nicer than the one shown at the selling site. The spacing along the head is narrower and there are micro groves on top of the the knurl rectangles, similar to what I have seen in expensive lights. This makes it very easy to zoom with one hand. One of my best AA lights, and I am not aware of any expensive ones that I might like better. Because it has only one mode, I have an Eneloop in it, rather than a lithium ion.
Defnitely an Osram Emitter, i have several other Osram lights with the same emitter.
As for the original Sipik and the various clones, i have one of every variation i could find, and so far the only “real” one, and best one i have is the red one in this pic.
it cost around 9 bucks, single mode, has an EZ900 series XR-E, runs well on both AA alc. and a 14500 lithium, has a glass aspheric lens, and so far is still the brightest of them all, with the best Neutral white tint in stock form.
The others in the photo are the various clones i could find and test.
The original is found on the Sipik website here:
- http://suofulan.1688.com/page/albumdetail_29167096_855762054.htm?imageNum=22
and:
Did a quick search on ebay just now for cree t6 14500, this one is $8.14 shipped, says five mode, but that includes zoom in/out its just hi/med/strb.
Just thinking about it for now, maybe look for a XM L2 for more efficiency. Maybe not, cheapest looks like $27.
I have some marked Sipik and these are not the ones I like best, but maybe you get better ones from the Sipik Web site, for one reason or another.
Has anyone actually gotten a glass lens in a 1xAA Sipik SK68/clone?
They’re fairly often claimed in the specs on web pages but those are consistently wrong in many ways.
Mine is a glass lens and 14500’s work fine. Went from about 100 lumens[primary AA] to about 300 or 400 lumens W/ 14500 Battery. I got it off of Ebay a year ago
1600 lumens!!! lol!! I have never seen one exaggerated that much!!
Mine was advertized as 300 lumens, more like 100-150 lumens. With a 14500 I am guessing it is 300 maybe even 400 lumens.
It was my first torch!! I got it for about $7!
Who is the real Mr smith? :)
The Real one lives 3 doors down from me!! lol!
If there are glass aspheric lenses, I wonder if they are cut and polished or only molded. I suppose the plastic ones are molded and that plastic can be formed that accurately by molding, but I think you could tell molded from polished glass by how clear it is as a magnifying glass. One usually can tell how a drinking glass was made by looking at it.
anyone knows this product? i wonder.is it fake,or…pressure switch for sipik sk68?? is it possible?
http://kiev.ko.olx.ua/obyavlenie/fonarik-sipik-sk68-c-vynosnoy-knopkoy-ID74wGX.html
That does look like a remote switch. The switch is in the tail cap that screws off, so it would be easy to make a remote replacement for it. People use remote switches for lights on guns and what not.
i got a version with xml u2…its brighter.and-i love it.from kaidomain.
Do you have the link? I don’t see the u2 version on their site??
-Jamie M.
sadly not available any more…sadly but i can ask morning for it.sure they have it.
I bought and gave away one of these http://www.aliexpress.com/item/Upgrade-800Lumens-9W-CREE-XM-L-T6-Mini-LED-Torch-Focus-Zoom-Flashlight-Free-Shipping/997633297.html . One might get the light and the XM-L for a little less than that price, but not by much. It loses some throw but puts out more total light.
