The original v1 had a lock-up issue.
Now all bugs are fixed and some changes are made in the temperature indication:
when it increases to +60°C, the color LED shows the warning level once a second.
After +70°C the main LED flashes 5 times. After +75°C the light output decreases to Main4 mode (550lm).
Critical level >+80°C is color indicated twice a second and light output decreases to Firefly2 mode.
It is fixed v1.
The new version 1.5 is being prepared for production now. There will be some UI changes.
There are realized 4 sections of modes and multiple clicks for an access to them.
Section 1:
Mode 1 = .5 lm
Mode 2 = 7 lm
Mode 3 = 30 lm
Section 2:
Mode 4 = 115 lm
Mode 5 = 250 lm
Mode 6 = 550 lm
Section 3:
Mode 7 = 1010 lm
Section 4:
Battery Voltage Indicator
Fast Strobe
Beacon
When the flashlight is turned OFF:
Click: Will put into the last memorized mode (from Section 1 or Section 2).
Press and Hold: Will put into Mode 1 of Section 1.
Double-click: Will put into Section 2.
Then will switch between the last memorized mode in Section 1 and the last memorized mode in Section 2.
Triple click: Will put into Section 3.
Quad click: Will put into Section 4.
When the flashlight is turned ON:
Click: Switch off.
Press and Hold: Will cycle the modes of actual Section.
Double-click:
Will put into Section 2 from ANY section.
Triple click:
Will put into Section 3 from ANY section.
Quad click:
Will put into Section 4 from ANY section.
The battery type changing:
10 clicks from OFF-state. The headlamp will flash about 3 times a second.
Now you can specify the battery type:
- 1 click for unprotected 18650 Li-Ion battery (without PCB) or LiFePO4, default value.
- 2 clicks for protected 18650 Li-Ion battery (with PCB).
blf8 discount: open official website www.armytek.com. When you place an order and add it to the cart, you will see promo code field. There you need to enter this code – blf8.
Social media discount: leave a link to us at your social web page And get а 7% discount for an order! This discount can be applied together with CPF and BLF promo codes discounts. To obtain the discount please send us a link to your web page, we’ll check it and add to you to a special user group. This discount can be used for 1 order whenever you want and can be applied together with CPF or BLF promo codes.
P.S. These discounts do not work during the current promotion on October 29-31.
CCT is 4000K, color - neutral white. The differences between warm and non-warm versions are the following:
- color
- brightness (warm version is less bright)
