MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
Gosh, and I remember when jayrob recommended Novae 32650’s, which is why I have 4 of them and they’ve served me well. Not the most potent cell I have, but fantastic capacity.
I tested Trustfires 32650(thread about results soon,maybe even today),and all I can tell,don’t buy feilongs or others so fast :slight_smile:
Here's some tests on the 6000mAh rated cells both 3.2V and 3.7V types:
http://blogs.yahoo.co.jp/utena0705/archive/2012/10/22
Thanks for the link Hikelite,
It looks like I’ll be staying with the King Kongs for now.
Got my last order, #100, everything is packed perfectly and just as ordered. Already putting some of it to good use! :wink: I like the use of the little boxes, neat to see they have padding and all! Have yet to see anything even remotely out of place, all the Qlites are perfect, as are the optics and triples with emitters. Bunch of goodies there! Hope to get a triple made for my Aunt for Christmas.
yeah sounds like good advice. I thought the old Feilongs were really good, but I could be wrong. I'd like to do more research and see what's the best.
Trustfire review by led4power
Received my Sanyo 14500 flat top to be used in ZL-SC52. Nice easy fit in battery tube (no rubbing at all, better fitting than Nitecore.) SC-52 can be picky about batteries. No problem with these flattop Sanyos.
I had only ordered one to see how it would fit. Glad I did. I’ll be ordering more of these in the future.
The packaging is superb. Almost OverKill. :smiley:
I thought I had jewelery sent to me by mistake.
Even has foam inserts. What a package!
Great Going RMM! :open_mouth: :open_mouth: :bigsmile:
Definitely like the packaging. Cute little box :wink:
I’ll be placing a larger order most likely pretty soon once I stop being indecisive about the batteries I want.
Been super busy with everything but here are a few updates:
New at the store:
  • Efest 1100 mAh 18500 IMR, Button Top (V2)
  • Efest 700 mAh 14500 IMR, Button Top (V2)
  • Efest 800 mAh 18350 IMR, Flat Top (V1)
  • TP4056 4.2V CC/CV Micro USB Charging Boards (DIY)
Upcoming:
  • Unprotected Panasonic NCR18650B 3400mAh
  • Unprotected Sanyo UR18650FM 2600mAh
  • Restock on a lot of items!
Dude.
I’m just not purchasing anything from now on until it gets put in your store. Seriously.
1 hour 40 minutes ago I ordered some TP4056 boards from China.
Micro USB TP4056 boards! Nice!
I’ve recomended them a bunch of times. Now I can direct people to your site even more then I already do!
With a D cell battery holder you can make a 32650, 26650 charger for $3. Use dual TP4056 boards for 1.7A charge current.
~ Edit ~
RMM, tp4056 doesn’t seem to actually do a full 1A. More like 850mA.
I would like to think most people wouldn’t complain about a 150mA difference tho.
HKJ review.
You're right, it probably doesn't do 1A under all situations, but that is the manufacturer's rated output (i.e. under ideal conditions). I can imagine that the power source, quality and length of USB cord, etc. all make a big impact.
HKJ tried 4.5, 5 & 5.5v.
Heatsinked to a large piece of aluminum.
Thicker gauge wires then any usb cord soldered to input skipping any issues with the usb jack or usb cord quality.
!http://lygte-info.dk/pic/ChargerTP4056/DSC_0609.jpg !:Review / Measurement: Charger module with TP4056 controller
Its a very good CC/CV chip, it just doesn’t do the claimed 1A. Slight exaggeration in current. Nothing like you see with chinese lumens or anything. :smiley:
Thanks for HKJ's link on the charger.
Added a few CC/CV LM2596 boards. They are pretty nice, I use them to charge my 4.35v D1s and my little 10440 cells.
just placed a order for 4pcs of 20R battery’s
Just added to store: (pictures upcoming, but I think you know what these look like)
  • Panasonic NCR18650B 3400mAh (unprotected, flat top)
  • Sanyo UR18650FM 2600mAh (unprotected, flat top)
Also, more unprotected PFs.
Looks like by this weekend there will finally be some more hosts in stock, namely Convoy S2, M1, and S6. Convoy C8 are also coming soon.
Are you getting more drivers in ?
Ran out of parts, need to resupply :slight_smile:
Does it show that I'm out on your end? My end shows that I still have plenty.
I see “Out of Stock”
OK Just checked and you have 33
Thanks
