I have six trustfire flames, 4 14500s and 2 18650s, all work the best of all the cells I've tried...
Could be you got defective cells (quality control is often lacking), or maybe they sat on the shelf for too long and self-discharged too far, hence reading 0.0 on arrival.
If you just got them, report to DX that they're defective, and they'll get another pair in the mail, probably within a few days.
I have over 40 18650 Trustfire Flames all from DX I have only had 3 out of those with problem. I got a two of the bad protection circuit ones they work fine as long as you don't pull more than one amp and one with a cooked protection circuit that I took off and it works fine. I got 2 unprotected ones from Manafont that deliver 4.5amps to my UF980L. I have about a dozen of the Trustfire flame 16340s from DX only one DOA that I was not able to revive. I have about a dozen 14500 Trustfire flame 14500s from DX not a single problem with any of them. To me that is pretty good quality for cheap Chinese products.
2x 18650 flame and 2x 14500 flame have served well.
BUT these are not a recent buy, so quality of these could be going down…
Suggestions, Solarforce? Basic choice of AW? Something else
I know DX may replace the one cell or at least refund me, But its not worth the hassle. I dont hold it against them anyhow.
As to further investigate the issues i pulled the wrapping off of both cells. The Flame 14500 was reading 0.00v before and now 4.196v, So im pretty sure the protection system went bad. Im gonna cycle it on my Hyperion and make sure its good to go. Now here comes the part that irks me, Its a 750mAH cell they relabeled at 900mAH. Its clearly printed right on the side.
The 18650 cell seemed odd, I couldn't find no PCB anywhere. It turns out the cells from Ebay that i bought were all unprotected. This was one of my first flashlight related purchases so i took for granted that these would be protected. But that doesn't explain why the cell died.
If i switch to another brand i know it will be more expensive so ill just have to see what i need and can afford at the time i buy more cells.
BTW the Flame 14500 with the PCB removed is doing fine while being cycled so it must have been the PCB that was the issue, The 18650 is junk tho.
Do lithiums even go to 0v? That's basically a short so either the batteries are FUBAR (which doesn't seem to be the case) or the protection circuit is jacked.
I think your right as they shouldn't ever read 0v. As the 14500 cell i tested after removing the protection PCB tested out to: Dishcharge 784mAH and Charged 765mAH
As for the 18650 cell all i know is it would only hold a charge of 250mAh, So its been junked. Why it died i don't know, My chargers wont over charge and ive never run the cell in a light that didn't have built in voltage protection. That is my Olight M20s Warrior.
Im not to pleased TF listed this cell as 900mAH when its clearly stamped 750mAH under the pretty flame wrapper.
Got 4pcs protected 14500 flames a few weeks ago from DX, they all came in at between 3.8v to 3.85v. Gave 2 to a friend for his e-cigs - he says the 2 are longer than his older flames and run out faster too.
While mine does seem a tight fit for my TF SA-2 and UF C3, but I can't really tell since this is my first time using 14500s.
My first set is smaller and will fit in a 4xAA battery case, But these dont fit in it. Despite me being upset of the 750mAH marking on the cell under the wrapping, It did do 760-780mAH under very light testing at 4.16v down too 3v so had i pushed the cell it would have done 900mAH+ easily. Both sets are protected cells, But they cant be the same ones underneath.
The unprotected 18650 that died i bought off Ebay 6 weeks ago, And i bought 4 and the other 3 work great and test out to perfect specs.
I think im gonna chalk this up to bad luck, That 18650 was slowly going as i noticed it only holding 4.13v for a few weeks. But it should have held up to the 1.5A tests i ran on it im doing to all my cells and keeping records of. As long as nothing else flips out and keels over ill stick with the Flames, As they have been good up until this.
People have gotten counterfeit *fires on ebay... It's a sad comment on chinese industry when people are counterfeiting brands that are themselves counterfeits...
If DX is shipping them though, that'd be annoying...
They may not be 100% counterfeits per se, just very lowly specced batts. They still work in a P4/Q5 which is the majority in which the masses in China can afford...few bucks light, you probably would not notice the drop. Actually that is already high-end, when I was in YiWu which is sort of the distribution centre for 70% of EVERYTHING common/commidties that you get in Americas/Europe, there are much simpler stuff there for the locals. Because that place is for "commoners", Shenzhen is more for electronics and apparels.
With a high powered cutting-edge light that the rest of the world plays with...woah. The might have come out from the "true trustfire appointed factory"....same line/same workers. Why is it so much lowered in performance? Someone paid the line to do it, everyone....perhaps the workers do not even get the share, just act on "manager's orders". 1 single run of 5000 batts - a lot goes to the manager. $1 cost price per batt becomes 20 cents per batt. I'd be surprised if there is much lithium inside. This happens when you have the "connection", everything works on connection in China.
Like that Sky Ray STL-V2 and Fandyfire STL-V6 (coz Fandyfire STL-V2 became the 3 x T6), prob from the M3X line. LOL! Even the models are mixed up, so they just conveniently choose a higher number.
The few times I've been to China, there are many rich man/woman who comes out to play. Audi S8, Merc S500/600 zooms by so regularly that it makes me as a SG citizen "blush". Have you been to a luxury restaurant in which 1 dozen man and woman whose job is just to stand there at the entrance, look pretty and bow to you and say "Welcome"? Or they light fireworks, BIG mofo 1.3G firework cakes (very illegal in USA I think), to welcome you? But at the back end, there are so many "peasants" that their saliva spit alone would make us drown.
Well the 14500 with the bad pcb and low marked cell came from DX, This one was much larger the set i bought off ebay weeks earlier. But it checked out spec wise and if pushed too 2.5v on a discharge would easily max +900mAH capacity.
I have or should say "had" 4 unprotected cells from ebay and the guy sold them with a charger deal from a USA location for $30 and another $10 for a second set of 18650's. That matches and almost beats DX prices from a USA seller. So very possible they are fakes, But i can test them today and see how the other 3 are doing.
My cells see little use since im so new to this and have about 7 flashlights ive acquired in 6 weeks and have no legit use for them except i just enjoy them and pray the electricity goes out so i can play with my toys. Ill test all 3 from the batch i got from that USA seller which are all btw all unprotected, But that was my fault for being a newb and not knowing they made Flames in both varieties.
2100- China is a world away from the USA and most likely imitates a time in our past when we were industrial giants like China has become. Cool fireworks, But thats crazy close to many flammable things and a person here would be arrested before they even stopped and sued for damages i couldn't even imagine.
Ill post back some capacity graph tests of the other three 18650's.
Ive got really bad news for myself, All 4 18650 cells i bought off Ebay cant even hold a charge to handle 1.5 amps for more than a few seconds and under a few minutes at .5 amps.
Im testing the 2 TF Flame protected cells i just got from DX and the first one is handling a 1.5 amp discharge just fine. Ill post those results later as they will take a while to finish the cycle, But the results look promising.
I used a few of the cells with no issue that i could see, But the charger tells me different. Im gonna stick each cell with a full charge into a single 18650 light and see how long it lasts. Ill charge all 3 cells on my Pila charger so i cant blame the Hyperion for any odd reason.
Cell #1 @ 1.5amps
Cell #2 @ 1.5amps
Cell #3 @ 1.5amps
Cell #4 @ 1.5amps
Cell #4 @ .5amps
This cell was tested when i first got the charger, I never tested the unprotected ones above until i decided to do a cycle test on every Li-Ion cell i own. Cell #5 is in the Hyperion now and is doing fine just like the one below. Note i didnt have a temp probe when i ran this one.
So, to make sure I'm understanding you right... the DX trustfire flames are good cells but one had a bad protection board, while the ebay trustfire flames are garbage?
Kinda confusing as i originally started the thread with issues on a 14500 and 18650 cells that were both TF Flames.
The 14500 was from DX order i just received and was larger than my older set and both were protected cells, It came to a conclusion the PCB protection was bad and once stripped the cell works great. I will add that under the Flame wrapper the cell is clearly marked 750mAH and not 900mAH as the wrapper claimed. But my tests showed that if i did run the cell down too 2.5v it would in fact do 900mAH, But stopping at 3v it was still over 750mAH. Its still a good cell for $3 each at DX.
Secondly is the issue with the 18650 cells i bought 6 weeks ago from an Ebay seller, I bought 4 total and all were unprotected due to my lack of knowledge. But i know i didnt abuse any of these as i only had one light that runs 18650 cells and i keep 2x Cr123's in it for high power bursts. I just got 2 more 18650 protected cells in from DX the same time i got the new 14500's. These have proven to be legit and great!
I finally got around to testing all my cells as i bought 10 Panasonic 18650's that i had been charging and testing each cell. This is when i found the first of these bogus Flames that couldn't handle even a .5amp discharge. Ive since tested all four and none will hold a charge worth anything. They did seem to do fine in a light when i used one during a black-out at my house. So im recharging each cell in my Pila and then will test them in a single cell 18650 light. That should minimize the hazard of 2 cell operation.
Summery:
1. TF Flame 14500 from DX had a bad protection board and labeled 750mAH under wrapper, But still very usable.
2. Four TF Flame 18650 unprotected cells i bought off ebay are junk and cant hold a charge, FAKES!
There's lots of fakes on ebay... consider these wonderful fake ultrafires:
https://budgetlightforum.com/t/-/2359
DX shipping bad cells would seriously suck, as the flames are the best (and almost only) budget option for high-current cells... but if it was just a bad protection board, that's a minor problem.
I wonder if these fakes are the cause of some of the other bad reports about trustfires I've read? I think a few of them were ebay. I'm going to have to make a point of never buying ebay cells... the only ones I've gotten on ebay were some of the UF 3000s, half of which were DOA, and all likely are fakes like the ones above.
If your 18650s are toast, feel like cutting the wrapper off and seeing what you find?
Cell #5 just ran its discharge cycle at 1.5 amps and started at 4.2v and ended at 3v for a capacity of 2337mAH, Had i taken it down to 2.5v like most people do in tests the cell would be in the 2500-2600mAH range.
Ill never buy another li-Ion cell off ebay again as that was an expensive lesson.
Since both DX Flame 18650's tested out very well ill buy them from now from now on. Im waiting for these cells to charge on my Pila and im gonna test them in my Olight M20s as its the only single 18650 cell light i have, The other one is a double cell. But yes ill take the wrapper off if they fail this last test, I had one yesterday i took the wrapper off before i threw it away. That was the first one i found that started all this. It was just a alluminum case with a few numbers on it and nothing i could discern any meaning from. Put ill post a pic of one if i have to dump them.
BTW i wasnt thinking when i threw the one away, Ill drop the next three off for recycling like i should have done the first time. I was just so upset i wanted it out of my sight.
And I have to admit that my working cell isn't as crappy as previously stated. I did a new test on my XM-L light and got around 2.5 amps on this cell to, same as my other batteries. Don't know why I got low readings before but at the moment I'd say it's an OK cell. The other one still sucks though...
You may need to strip it and take the protection PCB off like i had to do with my 14500 TF Flame.
Im not afraid of unprotected cells as im OCD about my hobbies and id never let a cell run too low, And none of my chargers would even allow a cell to overcharge even if i tried to make them do it.
Im just gonna stick with TF Flames from DX and other Chinese shops and stay away from EBAY on any Li-ion cells. Whats bad is almost all my NiMH cells came from Ebay also and ive had no issues, But those are harder to copy due to retail packaging and most are from retailers inside the USA.
