For those unfamiliar, you can check out SirJohn's excellent review of the light here. On TF Flames you'd get ~ 1.7A on the XM-L. IMR is not recommended if you are new to the hobby and aren't aware of the SOP for pocket rocket as it gets you 2.4A.
Generic 14500 IMRs are available from bestinone.net for usd7.80 a pair shipped registered mail.
This is a very very good deal for International buyers, eg you pay 35.90 + 5.99 at tacticalhid for WW. Shipping/processing is fast as well, from what I experienced with my 2 shipments of iTP A1 EOS and NCR18650.
The thing is, there are none NW XM-L lights which put out low 600 lumens when warmed up (on IMR of course, probably you'd get low 800 emitter lumens when cool, or if you are in dead of winter @ -25 deg C LOL!), they all cost about $100. The Zebra NW headlight which Boaz recommended is 190L, well I have lots of 200+ lumens NWs. CRI 70s range. Only -ve is, its not that throwy. Some don't like the small size and 14500 batt requirement, well I just take it as it is. If Xeno comes out with a E05 which accepts 18650 and same form factor as E03, i'll take it! Something like the Fandyfire/Uniquefire UF-2100....110mm length and 25mm dia.
Too bright, well ok, just slot in a NiMH and you'd get quite low output - the floodiness actually helps in the low output by dispersing the light out. Want lower? Pop in a nearly dead AA. WOW!
Same goes for WW, and best of all the tint is really great and looks very close to incandescent, and you get 85 CRI.
You can bite the bullet and get a 3 x T5 drop-in @ 2.8A for each emitter, that's for Mags and usd135 shipped, a Maglite host (20 bucks?) and 4 IMR 26650 for 30 bucks to do 4S1P......and enjoy NW goodness for just under $200. ~$50 per T5, not too bad.
The Romisen RC- 2R4 II NW XP-G uses 18650s, yes.....and its 24.95 + 6.50 int shipping (prob 3 bucks CONUS). But it takes 0.85A only. Bleah.... Nevetheless, I have it for collection. heh heh... But pls do not drop the light, i dropped it once and it took some fiddling to get it to work. Dropped second time, more fiddling before it can work. E03, no issue pls go ahead and whack it...
PS. True to BLF tradition, allow me to recommend Generic IMR 14500s from bestinone.net, mitro tested some of the range and they are great. 7.80/pr shipped with registered mail.
Agreed. If I had the money to spend, I would probably buy another E03 for the special tint as it would be a good intro for me to WW. This is about as cheap as you can get for an XM-L E03 of any emitter tint.
Less known and less talked about feature : with a nearly depleted AA battery, you get lux lower than the ultra-low "firefly" mode of supposedly ultra low mode of an expensive branded EDC (and you know how much those cost). Even on a nicely charged NiMH it's already 2X dimmer than say a iTP A1 EOS (1.8 lumens, but this light is geared for throw relatively speaking). Eg 28 lux for E03 vs 48 lux for iTP A1 EOS (at 1.8 lumens low mode). I managed to get a lowest of 1.7 lux at 1m.
Just grab any AA in an emergency, got light! Even depleted ones you can squeeze out some juice.
And nope, no horrible PWM at these low levels, its a linear driver. Solid 0 Hz.
Super bright. :) If you want lows just pop in any AA bah.... from the remote used etc. Still will run about 1hr or so. That low is twice lower in intensity than that of the 1.8 lumens from an iTP A1 EOS.
The Sunwayman R01A works with 0.9V. The Xeno E03 works with 0.8V. Fenix E0/E01 stuff. In fact it can work on lower voltages and the light is crazy low. This is in comparison with a iTP A03 EOS at 1.8 lumens.
The brightness of 1.8 lumens is perhaps even irritating.
Super low mode with depleted cells : measured lux - 158 lux for the iTP A1 EOS @ 1.8 lumens, Xeno E03 = 9.8 lux. (more than 10X less)
Useful for say map reading at night and you don't wanna destroy night adapted eyes. Astronomy. Tactical movement etc. Or you just don't have any choice during a natural disaster and can just use AA batts which came exhausted from the radio.
The comments on the HK site say this starts on low. Everything else I read about these indicates they start on medium. That's one of the reasons I haven't tried one yet (that and the lack of a real low on 14500).
Just got my WW E03 from hkequipment today. Placed the order on the 12th, arrived on the 19th. I think that's the fastest I've received a package from Hong Kong.
