Engineer Lii-260(LiitoKala) the smartest li-ion charger in a world?
Liitokala (Exocoetus volitans):
The name of this charger makes me smile, every time I see it. :)
[Liitokala is the Finnish name for the above pictured flying fish - literal translation would be "GlidingFish"]
Anyways, thanks for the review! The charger looks very nice. I'm seriously considering to buy one..
Hmm . . . seems nice! Nice and simple! Keeping an eye on this one.
-Garry
I want to know things like how the spacing and soldering of the components looks inside, as well.
HLK are any of the new chargers capable of charging D batteries?
I just bought 12 Tenergy Ds and don’t have a charger that will charge them.
I do not have any D capable charges in queue for review (One of the Soshine does C cell, it is not perfect, but useable).
The only working D cell charger I remember to have tested is the BT-C2000.
If I wanted to buy a D cell charger that could charge many cells, I would look for a Maha C808M, but it is a bit on the expensive side (I have never tested it, but my general experience from using Maha is good).
It would be very nice if it could charge all possible batteries + 4,35 to 4,2 V selection and of course for less than 20$ if possible :)
Me also... I am waiting for pro review of this little charger. But even now I trust him and for first time I am leaving charger unattended :) and it is doing everything what I need...
I just say "liito kala charge!" And he charges, and then I say "liito kala measure capacity!" And he does all that while I am gone on beer ;)
I have that problem too!
That is much more dangerous than playing with LiIon batteries
Well it is good for nerves but bad for body especially for belly :)
And sometimes doctors recommends warm beer for kidney stones(seriously I am not kidding here)
When you move around and depending on how you move around it can also be very bad for other parts of the body, especially after a large dose.
And the next morning can be bad for the head and stomach .
But if you can handle it responsible, the risk is minimal (Like LiIon)
Exactly good beer is like good li-ion battery :)
I might need to clarify something lost in translation. “Gone on beer” could be interpreted in English, Australian English anyway, as well and truly drunk. While I assume the meaning you intended was simply free of concern over the battery charging and having a beer?
But I agree with all of it. Except the charger, I have no idea until I see a review with charts and stuff. No hints yet HJK?
And you said you had an accident while testing it, what kind of accident?
I understood it without any amount specification, i.e. it could be 1 beer or 20 beers.
It looks good until now.
I simulated a battery with too high voltage, when checking the voltage readout (At least I believe that was the reason). The discharge function is gone and I believe that this problem might have spoiled the resistance measurement.
Ooops!
I am not into English language since it is not my mother tongue :). But I have thought about that as drinking a beer in a bar while Charger does all the rest...
LiitoKala R.I.P... How much high voltage? So he does not have over current protection?
Exactly. Accidents happens, even if I try to be careful. Luckily the charger was not that expensive, I get much more depressed when I blow something to a couple of 100 dollars (This happens very seldom) .
Probably around 4.5 volt, when turning the knot on the power supply it is very easy to turn a bit to high. This does not have anything with over current protection to do, but the charger is simply not designed to handle more voltage than a LiIon battery gives.
Poor little fella... I really like him...
If I had disliked the little fella, I would not have ordered a new one, but only published my current results.
But I believe it is worth doing a good job on him.
That is very promising coming from you. :slight_smile:
I’m just worried about heat. It claims it can discharge two cells at one amp each, that’s going to generate some heat, yet there’s no fan. For a $25 charger I’m not above buying a small CPU fan and cutting it into the body and circuitry, but it would be nice to see it there.
