Thanks for the review koyotee. Am I just being selfish hoping for a UI comparable to zebralight’s?
Im not familiar with the zl ui, but i can tell you i like this one
Beamshots added
Beam shots are with 14500 battery? Maybe adding some with AA would be helpful.
This sounds like a really interesting light. On the outside it looks like it was modeled after an Olight S15.
I wonder what the internal construction is like. Is there a pill? If so, does the pill screw in or does it simply slot in with an alignment tab like the S15?
I might get one of these. I like the styling. I’m a fan of small sideswitch lights.
Yes, with 14500, i was thinking about AAs but i’ve forgotten them at home, i’ll do that today
nice review… but surprisingly 3.8A Convoy C8’s spill is so dim, I thought it would light up the garage even more
Maybe it’s just me, i’m not that pro at taking beamshots yet
FT has its sibling, the Solarstorm sc01, for a lot less... not sure if its the same or not,
(just saw it posted in the FT deals thread)
You should pull the trigger and do a review
If all goes well I'll let everyone know in a few weeks.
Mine has cooling fins under the switch, this one doesn’t.
so yours must come from Hawaii ;)
Be great if they came with an extension tube, and a black reversible deep carry clip.
Would you want a Sex on the beach also?
You have to ask?
That’s just a cocktail tho
So on AA, 0.8A is about what, 150 lumens ?
And on li-ion it’s far from even 500 lumens I think
What is your estimate in lumens ?
Actually XM-L2 @1,3A may produce around 450 otf lumens.
i noticed you never mentioned the hidden “extra Low” mode, ( hold the swttch on from “off” and it turns on a lower Low with only 0.02 amps draw on a 14500.
I modded mine with a Nichia 219, and its now my favourite single AA/14500 non-zommie EDC light.
