All those pimped out lights look awesome. I’d be scared to leave the house with most of those. Anything in my pocket is subject to getting bashed, beaten or just plain lost. I will be getting the Ti S10 though, which should have a warmer tint than a stock S10. I just got my S15 in Ti and almost wish I would’ve got the S10 instead. Now I have an excuse for both.
I bought two when they were available from Solarforce.
You might try Flashaholics A U.K. seller, they seem to have a stock, it’s how I bought mine, with the “offensive” bezel attached. A bit on the expensive side but they do seem to be very hard to come by. It went through to checkout when I tried it so there’s a good chance that they have some in stock.
I like 1xCR123 sized lights. I always run mine on li-ion 16340 rechargeables. Here are some of my more notable ones:
D25C and D25C Ti - great lights. They come with great tint and acceptable, though unexciting, UI. Very small for what they do. Bright on IMR 16340.
Spark SF3 neutral white - fantastic tint and UI and the light looks great. All around great pocket EDC. Better UI than the Eageltac, but not quite as bright. This is my favorite unmodded CR123 size EDC light.
XTar WK42 - super-small size and nice sideswitch. UI isn’t perfect and tint is very cool white. Makes a great host for a 3.04 amp DrJones Lumodrv driver and neutral white XML2. This is my favorite mod host in the 1xCR123 size, and fully modded it’s my favorite CR123 size EDC light.
Olight S10 - ultra-tiny CR123 size light. UI lacks shortcut to max power, but this is fixed on the L2 version. Tint is slightly greenish due to poor choice of tint and coating on emitter. Easily fixed by replacing emitter and lens.
Jetbeam RRT-01 - nice interface and feels nice in the hand. Larger than some of the other lights though. This is really a 1x18350 light due to the wider battery compartment.
Thrunite IC - one of my older CR123 size lights. Larger and longer than some of the newer models and with a dated emitter. Long reflector gives larger halo, but poor spill.
Lenslight mini - Huge and heavy. Built like a tank. As large as an SC600, but with a fraction of the brightness. Not recommended.
To be honest, the build quality is great, but I'm not impressed with the tint nor the brightness. The Olight S10 Baton blows it away in both areas. The C10 is a bit too green for my taste...
