Can’t wait to see its beam profile.
Nice!
Beam is OK. It's not as tight as it could be, I have a S3 using the same TIR but with an added .030" insulator (the common butterfly style) & the square hole in the TIR's holder bored out to locate on the insulator's 7mm ring, and that one has a spot about half the size compared to the TIR without the extra spacer. But there's just not enough room for that in the F6.
Yes, beam shots please. Nice looking light.
DISREGARD! Yes, there can be enough room - the bezel is super thick, I can shave about .035" off the rear face that sits against the lens and end up with the same spacing as with everything stock. Essentially just moving the lens forward, and shortening the stainless bezel by the same amount.
Maybe it's true calling is with a 90 degree TIR, lol. I love really small floody lights!
I shortened the front lip of the white plastic holder a bit (not too much, there needs to be an air gap between the TIR & lens, otherwise it screws up the beam) and the rear of the bezel only needs to be shaved down by .018-.020". The only remaining snag is that the o-ring no longer sticks up higher than the TIR holder, so doesn't seal against the lens. I need to add a small spacer under the o-ring to move it forward a bit so it touches again.
Adding the butterfly spacer (.035" thick) did tighten up the center spot, it looks identical to the one in the S3 now.
I was hoping there would be room to just stack a 20DD on top of a switch board. :~
Well a 20DD wouldn't fit, since the switch holder board would be 20mm also and sits on a lip inside the head. You'd have to use a 17DD, that itself is no big deal, but it would be a very tight squeeze. 17DD height is right at 5mm, and only 5.5mm space available. Probably not even enough room for the LED wires.
Still interested in a DD Roche F6 driver? :bigsmile:
Someone showed a set of vertical pushbutton switches on another thread…modifying the 20DD would probably be doable, adding those 2mm tabbies are doable
Just need the drawing .lbr of the switch and see how that goes
Button is at 6 oclock 180 degrees out from 12oclock 0-degrees
I think it would be doable
Is the nub 2mm diameter/thick
These TIR’s snap smooth onto the XM-L package w/o spacer
15 degree TIR
30 degree TIR for a little wider flood
on the 2-602C XP-E builds I did I used the adapter, had to remove a little of the lip around the top to get them to fit…but they dropped right in, I like the beam profile on the 15mm, makes a semi decent thrower but still floody enough to be useful, I think the 30 degree would open the beam profile nicely
Thread?
Sorry, I meant the switches. :weary:
Doh….sorry
I am not sure where they are…maybe someone can come in and show us…might be in the OSHPark Project thread
Searched the oshpark thread. Only mention of right angle switches seems to be by some Helios- person. Post #796 That can’t be it, right? :~
Yup yup
Just need that and the .brd file and possibly tweak it up…need a .lbr file for those switch pads on the board
interesting that
Oh its much too easy using those Alps SKSC switches. I rammed one of these on my board. Its huge by comparison but by adding the layout for that switch people aren’t forced to make a mouser or digikey order just for a switch.
Surface mount right angle switch: http://www.digikey.com/product-detail/en/TL3330AF260QG/EG4389CT-ND/1426859
The TIR I used is made to fit the XML without a spacer as well, it's just that adding a ~.030" spacer gives a bit tighter beam.
So I somehow managed to create a 70N02 Roche driver awhile ago. Even though I haven’t really found myself interested in straight DD yet and I don’t have an Roche F6.
Still interested in one Comfychair?
