hkequipment added a code for the reflector for $8
code added to OP
code added to OP
I’m tempted by the SG5 but I already have so many headlamps including a Spark 18650 model. I use it everyday at work.
Thank you sir.
Comeon Sirius, $15 for a $59 lamp?
What! Is that too much J)
Zebralight and Spark (among others like Armytek) are seriously overpriced + chinese carbon is really cheap especially because you don’t need high strength and thickness carbon like for bicycle components/frames…
A year ago or so I was really excited about bike light that they were getting ready to release (SDB100) and when they finally did, price was like $160+ and I was like:
Only had I not ordered the Armytek Wizard pro from hkequipment two weeks ago…
Long time lurker, first time poster…
Great forum!
Count me in for one (SG3 in NW). Thanks.
Welcome to the Forum!
Thank you!
I have a Zebralight H502d (as well as many other flashlights), which is a good flashlight and one I use nearly every day, but the fact that it starts off in High1 or H2 is a negative. I like the fact that the SGx has memory mode as Medium will provide enough light and has quite a long battery life.
-Is the only difference between the SG SF the head mounting hardware?
-For $44 are you guys essentially buying it because it is a good headlamp or because it serves as a good torch also?
I believe the SF series comes with both flood and spot reflector. But its a flashlight form factor, light comes out the front.
The SG series only comes with a flood reflector (spot reflector is extra) but it is in Headlamp form-factor, where the light comes out the side. I also like the SG3's small size personally, as it takes 16340 batteries. This is all I know between the SF and SG series. Maybe others can chime in about more differences.
Ahh I see, I was confused by the switch on the SF, thought it was the light coming out the side also.
Doesn’t the SF3 also use 16340 batteries? And also the SG and SF look to be identical size.
Ya, the SF3 takes 16340 as well, but is not a headlamp, like the SG3 is.
Thank you!
Sorry for the off-topic, but you know your Zebralight can also start in Low (several low available), if you do a ~0,6s press on the switch? It can even start on medium if you do a longer press (the light will switch on in low then go to medium)
My Zebralight H31fc is currently my favourite EDC…hope the Sparks will replace it!
PS: welcome aboard!
I couldn't wait so i went ahead and ordered the SG3 / reflector with the coupon codes, thanks so much!! They are already shipped :D
Count me in.
Will get 1 SG5-NW. This will be my first headlight.BTW, does the package include the head strap? Or you need to buy it separately?
Mine was with strap included but bought on ebay.
Guys, Wallbuys will be having a sale on SF5 NW for $42.99 starting on April 30th. This is a good news for those interested in SF5 if this GB doesn’t happen.
well we need 10 more pieces still for this to fly
chibim has been talking with WB as well to see if they can get their typical sale/GB for $43 for all 4 of these lights/headlamps so maybe if we dont meet the minimum required pieces we can just order from wallbuys individually.
Think I’d rather go with HKEquipment than Wallbuys, even if it is a dollar or so more. Stanley is a good honest dealer.
I’m in for a SG5. Nice work, jmpaul.
i agree - ill add you to the list
+1
I have only good things to say about HKEquipment.
