Personal favorites are Robacco and Crimson Cow (Red Bull :D) from BlueMistVaping.com and Gorilla Juice (ridiculously addictive!!) from avejuice.com
Yes, ECF is probably the most hospitable forum to learn about vaping. Only problem is that the "fanbois" can get a bit rabid over their own personal favorite device/mod. I personally spend more time at http://www.vapersforum.com , but the users there can get a bit rowdy.
Been vaping for over 2 years now and is probably the best choice that I've made in a long time.
new vaper on the forum here too. vaping exclusively almost 5 months. i use the prodigy v3.1 from puresmoker @ 6v. like my rcr123a's in my lights, and in my ecig :P fav vape is the old CashCap... they also discontinued and i only have about 20ml's left on reserve...
something about a hunk of steel full of potential explosives in your hand makes you feel all warm and fuzzy... oh yeah collect guns too
I bet I would try if only I was addicted more to nicotine. They seem very interesting, far more interesting than regular smokes (which I have never smoked).
Over cigarettes I prefer cigars but only about once /month (see avatar).
Hmm, might just start cigar-thread over offtopic...
I haven't had one die yet so I haven't pried one open, but my usb powered ones say ICR10440P 360mah on them so I assume they are standard protected 10440 Lion batteries.
The sealed factory batteries have built in over-discharge protection... So they are at least partially protected. When it gets down to a certain voltage, it will not work anymore :)
they are mostly Li-ion, some lifepo4, some use regular ol nimh (they call it the puck). they all use rechargable batteries. unless you get a mod, the batteries are not easily user replaceable. mods usually use anything from a 10440-26650. my mod uses 2 lifepo4 rcr123a for "6v" vaping. some people are happy with 10440s, they make for a small mod, and you can carry a few extras to make it a day. i think the usual is 3-4 hours vaping on one. ill usually make it a day on my lifepo's. they even have a custom nimh "5v" battery for vaping
if any of you smoke and is interested, http://www.e-cigarette-forum.com is great. i think the ecig and flash communities could merge quite nicely
edit: almost all the ecigs that you cant easily replace the batteries are regulated and have protection. i believe the ego is regulated to 3.2v if i remember correctly. and most ecig users recommend "safe" usage of batteries, either it be a safer chemistry or protected cells
The batteries used depends on the e-cig (or "mod"). They're all either Li-ion or LiMn (with an occasional LiFePO4). At this point they are all protected. Were a few chuckle-heads building "mods" with CR2's, but that crap pretty much stopped after a few explosions/rockets/3rd degree burns. Was never real big on the Egos, but a 10440 doesn't quite seem right performance wise. At only 360mAh, they shouldn't be able to handle the draw on the Low Resistance atomizers. The "mod" that I use is a custom built using 2 UF 18350 XSLs with a switching regulator.
LOL....yeah, looking like a new sub-forum is being born. :bigsmile:
what switching regulator does it use? ive been messing around with the kis-3r33s module some. i tend to try to reinvent the wheel, so most of my mods are fails... but someday the new wheel will roll like a mofo... i also have a couple ti modules im waiting to play with. got a ti 4050 booster, im going to power with a couple 650mah rc heli batteries in parallel, with USB charging. just got my batts today from china
